02-16-2011, 03:04 PM | #1 |
137
Rep 718
Drives: N/A
2011 clutch problem
Hi,
I got a 2011 135i. I noticed my car's clutch is acting wired... If I put it in 1st gear, slowly let the clutch out to the engagement point, the car is start to move forward without apply throttle, which is normal. But my concern is if hold it at the engagement point, i feel like the clutch is shaking/vibrate only at that point... which i dont have in my 09 135. Sometime, even in neutral gear, sometimes it's happening too... But the car has no problem accelerate. Any advise?
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
02-17-2011, 01:48 AM | #2 |
137
Rep 1,450
Try just using the clutch properly and see if anything is noticable. My guess is you are finding the extact point at which you are able to "feel" some minute vibration from the release bearing as it it under load AND slipping against the flywheel. If you keep doing it you will create a problem by either damaging the flywheel or clutch plate surface or prematurley wearing the release bearing and then it will rumble.
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
