KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-12-2011, 08:10 PM | #1 |
Rep 139
Removed ZCP's and installed Apex ARC-8's
I wanted to try to soften the ride on My ZCP Sedan, so I removed the 19'' ZCP wheels and installed 18'' Apex ARC-8's.
It was a success ! ,ride quality is much improved. Front's are 18 x 9.5 ET 35 with 255/40/18 PS2's Rears are 18 x 10 ET 25 with 275/40/18 PS2's |
02-12-2011, 08:23 PM | #2 |
408
Rep 2,171
did you notice any improvemments in acceleration? the apex's are about 6lb lighter per wheel compared to the ZCPs... i can't wait to mount my APEX ARC 8's too..
02-12-2011, 08:32 PM | #3 |
15
Rep 751
The ZCP front wheel is ET 31. Seems, between the greater offset and wider wheel and tire, you would have to be very close to the strut. How much clearance do you have? I might consider running that wheel on all corners, with 265/40 tires and a rear spacer.
02-12-2011, 08:56 PM | #4 |
10817
Rep 27,600
Looks awesome!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
02-13-2011, 12:19 AM | #5 |
892
Rep 9,032
It's a little tight up front, but it works. OP may want to consider using a 10mm spacer for better looks and strut clearance.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
02-13-2011, 02:08 AM | #7 |
76
Rep 3,178
Perhaps the front looks like its not quite filling up the arches (relative to the 359Ms) but as long as it achieved the desired outcome! Overall looks great!
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
02-13-2011, 04:25 AM | #8 |
Rep 139
02-13-2011, 04:35 AM | #9 |
Rep 139
The new ET 35 front and wider tire combo is only about 1/2 " closer to the strut than the ZCP combo.No rubbing issues Here. A spacer would bring the outside tire edge even with the fender edge for a better look, but Im OK with it set in like this.
02-13-2011, 04:48 AM | #11 | ||
Rep 139
The 255/40 is actually taller and wider than the 245/35 ZCP, so it fills the fender arches even more |
02-13-2011, 05:58 AM | #12 |
5234
Rep 10,616
How bad are the roads in southern CA? I am buying 18 x 9.5/10.5 ARC8s and have to decide whether to squeeze the 245/40 and 265/40 from my stock wheels or buy wider tires. 255/40 and 275/40 would certainly be a gentler ride. I was leaning towards 265/35 and 285/35. I am in NH, where we have frost heaves in winter, but I have snows in 235/40 and 255/40 to soften the ride then.
02-13-2011, 06:17 AM | #13 |
15
Rep 751
Thanks. And regarding the looks. if you have sufficient inside clearance, I'd leave it as is. I tried my OE ZCP rear wheel/tire up front, since it is also a 10", ET 25 wheel, which is what I was considering on all corners. I would never be satisfied with that size up front on the street. I believe the description of an "aggressive" wheel fitment must have been the result of someone wanting a kind term for it. But it reminds me of all the Hondas driven by 18 year olds who stick a large spacer up there. Your car looks fine.
02-13-2011, 06:27 AM | #14 |
1904
Rep 5,678
Looks great.
I have found that you can also get better comfort from changing tire brands and staying with 19s if that's someone's goal. The PS2s are not bad at all but if someone wanted to stay with 19s they could go with Hankook V12s or Continental DWs. I have found that the ride quality can be improved quite a bit that way too. You sacrifice a bit of side wall stiffness but definitely improve ride quality IMO.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
02-13-2011, 11:48 AM | #16 | |
Rep 139
I would have used 245/40 and 265/40 if I had them,but because I needed to buy new , I went the next size up. I think the 35 series tires would ride too rough. |
02-13-2011, 11:54 AM | #17 | |
Rep 139
I am buying another set of 10" ET 25's for the track though. |
02-13-2011, 11:58 AM | #18 | |
Rep 139
02-13-2011, 11:59 AM | #19 |
892
Rep 9,032
They're pretty similar, but the APEX wheel has a large center opening since it was mainly designed for the track. The large center allows easier access to the lugs. Just depends on what you're looking for.
02-13-2011, 12:34 PM | #20 |
15
Rep 751
02-13-2011, 12:54 PM | #21 | |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Contrary to what others have told you, ride quality won't be improved much over the PS2's in 19" sizes. The PS2 has soft sidewalls and they ride quite good!!!
02-13-2011, 05:32 PM | #22 | |
312
Rep 1,041
Did it stick out past the fender edge? |
