02-09-2011, 08:12 PM | #1 |
19
Rep 92
ESS Supercharger Advice
I am thinking about having IND install a supercharger on my 2009 e92 M3, and I have a few questions that I am hoping to get answered:
With DTC, what ESS version is best? Are there any results related what the 0-60 times are for an ESS enhanced car? What changes in driving characteristics should I expect? Do all of the modes and functions work the same as stock? Thank you in advance! - David |
02-09-2011, 08:23 PM | #2 | |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
It is probably best to just call and talk to IND...... they will tell you what is best based on what you are looking for and will be able to answer all of the above questions. |
02-09-2011, 08:34 PM | #3 |
BMW M3 E90 addict
Rep 58
Question: "With DTC, what ESS version is best?"
Answer: VT2-625 + RPI GT Race exhaust = 650HP++ Question: "What changes in driving characteristics should I expect?" Answer: http://www.youtube.com/embed/_OECt4wNydE <--- Russian VT2-625 http://www.youtube.com/embed/WZ1lTGmzgxs <--- Red Russian VT2-625 M3 E90 DCT. http://www.youtube.com/embed/UV8EoXDdwA0 <--- Swedish 6-Gang Getriebe. He says 5+ car length in the end.
Regards
//Arthur Last edited by Arthur; 02-09-2011 at 08:42 PM.. |
02-09-2011, 08:53 PM | #4 |
Rep 147
IND will give you the straight scoop on the kits. Everything they told me was spot on reality, no sales pitches, just straight facts. I have a VT-2 600 with 6MT and zero changes in driving characteristics. I took my 75yr old Dad to dinner in the car and it was smooth as silk. We jumped on the turnpike and I told him I was going to jump on it to show off, we were literally doing 100mph effortlessly before you knew it. Power when you want it, smooth drive ability when you don't.
2022 F93 M8 - Barcelona Blue
2019 991.2 TTS - Night Blue 2011 F-150 SuperCrew (Winter Transportation) 1986 Buick Grand National (10.8 @ 122mph) 1987 Buick Grand National (stockish) |
02-09-2011, 09:14 PM | #5 |
808E90
233
Rep 4,047
I think ESS has a DCT software for those that are looking to do the VT2 600 and up. From what I understand the software is there for the added TQ ... Again I am not 100% sure and recommend you contact Roman or Nate
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
02-09-2011, 10:17 PM | #6 |
876
Rep 3,450
this is my understanding:
VT2-575 is recommended for DCT cars. ESS recommends you get their DCT software for running the 600 and 625. (it's worth noting that 93+ AKI octane is required for the 625 - something to consider depending on where you live). for cars that don't get the DCT software, ESS makes a minor tuning adjustment to the ECU that reduces the amount of torque the engine makes while shifting just slightly. I'm told it's completely imperceptable, and that it is just to reduce the amount of heat that builds up in the clutches from the added power. driveability and functionality of everything remains the same. it should drive and feel just like stock, but much more powerful. |
02-09-2011, 10:21 PM | #7 |
122
Rep 1,202
i would also like to know the answers to these questions, I too have a DCT and would like to know what spec (given we get the dct software) that we can run safely without any slipping, etc...
02-10-2011, 01:59 AM | #8 | |
BMW M3 E90 addict
Rep 58
Regards
//Arthur |
02-10-2011, 07:29 AM | #9 |
125
Rep 4,971
I believe you are talking about 99 RON, In the US, Octane Ratings are in AKI. I believe 99 RON would be closer to 94-95 AKI.
02-10-2011, 08:17 AM | #10 |
BMW M3 E90 addict
Rep 58
aha, okey!!
Regards
//Arthur |
02-10-2011, 08:56 AM | #11 | |
144
Rep 1,440
02-10-2011, 09:09 AM | #12 | ||
BimmerPost Supporting Vendor
9587
Rep 10,878
We really try to stick to facts when we speak with clients about modifications they're considering. It's easy to speak highly of ESS kits because the car really does work that well. Other than the almost absurd acceleration, there really is no difference in how the car operates, especially on a day to day driving level. The VT2-575 kit is ideal for the DCT transmission. The engine's power is reduced between shifts to allow for the transmission to operate properly.
02-10-2011, 09:52 AM | #13 |
5234
Rep 10,616
A centrifugal supercharger typically makes the square root of peak boost at half peak rpm. Peak boost is at peak rpm with a centrifugal. If peak boost is 6 psi at 8000 rpm, you are looking at about 2.5 psi at 4000 rpm and less below that. Expect very small gains on the low end. Consider other mods that might improve low end power, if any, whether instead of a centrifugal supercharger or in conjunction with it. The centrifugal actually works well with a high compression motor like the S65 by not producing much boost in the midrange where cylinder pressure is highest. You could not run as much boost with a twinscrew that would have a better low end or with a turbo that would have a better midrange, without lowering compression.
PetrolFumes351.00 |
02-10-2011, 09:53 AM | #14 | |
122
Rep 1,202
02-10-2011, 09:58 AM | #15 | |
876
Rep 3,450
02-10-2011, 10:37 AM | #17 | |
51
Rep 530
02-10-2011, 10:38 AM | #18 |
51
Rep 530
I think IND would be your encyclopedia in this case. They wont bullshit you, and are not the type of company looking to make a quick buck. If anything they will talk you out of a big purchase if they feel as though it wont help or isnt smart. IND is the way to go, give em a call and you wont be dissapointed
02-10-2011, 10:52 AM | #19 |
253
Rep 2,091
How much slower are the 6MT cars with the ESS 575 kit than those with DCT? I need to do a search on some dyno numbers and actual 60-130 times versus theoretical ones.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
02-10-2011, 10:59 AM | #20 |
51
Rep 530
02-10-2011, 11:10 AM | #21 | |
13
Rep 84
I know that ESS recommends their DCT software for 600 and 625 but on the 575 it's optional. |
02-10-2011, 11:10 AM | #22 |
125
Rep 4,971
