02-09-2011, 11:23 AM | #1 |
Rep 63
1200 mile service
Apparently the 1M will require the 1200 mile service like all M cars - probably because of the M differential rather than the engine which is similar to the Z4 35is.
02-09-2011, 01:43 PM | #3 |
31
Rep 515
Maybe because it's also an M car? Why everybody keeps doing as if the 1M Coupé isn't a true M car? And don't come with : because it's not an NA engine...
02-09-2011, 02:24 PM | #4 |
Rep 353
02-09-2011, 03:11 PM | #6 |
119
Rep 771
Drives: LBB M2C, VO 1M, GSA 1200
Garage List 2021 BMW X3M Compet ... [0.00]
2019 BMW S1000R [0.00] 2019 M2 Competition [0.00] 2018 BMW 1200 GSA [0.00] 2011 1M Coupe [9.75] |
If they do in fact require a 1200 mile service, I suspect it is mainly due to marketing and not necessity. Basically a way to further separate M cars from regular series vehicles.
The different piston rings arguably require a break in oil change from tighter tolerances, but otherwise there is no meaningful hardware difference between a 135/335 and 1M powerplant. I don't recall if the M differential requires a fluid change on the M3 at 1200 miles, although somebody could check this out over the M3 website. |
02-09-2011, 03:19 PM | #7 |
69
Rep 658
It's not an M car cause it rides to high and the exhaust note isn't right. I'm going to go cross shop a WRX
02-09-2011, 03:30 PM | #8 | |
Moderator / European Editor
1540
Rep 6,754
Best regards, south
02-09-2011, 04:00 PM | #9 |
119
Rep 771
Thanks for the clarification South. The tranny change on the M3 is only for the 6MT as I recall (bad things happened when a few dealerships changed the fluids on the DCT).
I am unclear why the M3 6MT would require a fluid change whereas our regular 3 series manual tranny does not (and in fact there is a written warning on the tranny indicating it is lifelong fluid). I can't imagine the differences are that substantial. |
02-09-2011, 04:05 PM | #10 |
European Editor
10589
Rep 22,992
^^I also think on the M3 trans you need to clean the trans filter too - when you change the fluid. I don't remember on which trans though!
I also think both trans (DCT and 6MT) need a trans fluid change though. Some dealers just do not know this - they think its only for the 6MT. I hope BMW would splurge for an engine oil change too @1,200 miles. Dackel |
02-09-2011, 04:16 PM | #11 | |
119
Rep 771
Anyway, it sounds like the M diff needs a change. This topic is of concern to me since my dealer is far away, and I don't want to have to drive hundreds of miles to simply get an oil change that I can do myself. |
02-09-2011, 04:21 PM | #12 | |||
1540
Rep 6,754
Best regards, south
02-09-2011, 04:23 PM | #13 |
110
Rep 1,291
If it's covered under the free service program, then there's nothing much to worry about except you gotta hope that the techs will do things right. My M was overfilled with oil on that first service because they had no idea how much oil it really need back in 2008. Ridiculous but true. In fact, I was overfilled twice over my service history via 2 different dealers.
Must stop eating..............
02-09-2011, 04:24 PM | #14 | |
European Editor
10589
Rep 22,992
YuP! Just did a quick search on the M3 forum and you are right. http://www.m3post.com/forums/showthr...0+mile+service http://www.m3post.com/forums/showthr...0+mile+service I guess the trans filter taht needs to be cleaned is on the 6Mt M3's. I wonder what the 1M tranny will entail for service. Dackel |
02-09-2011, 06:05 PM | #15 |
16
Rep 242
Humm this is interesting because it would (for me at least) put a serious question mark on the feasibility of a European or Performance Center Delivery. I live much more than 1200 miles away from South Carolina and having to schedule a 'pit stop' for the break-in service in the middle of the trip back home would definitely complicate things! . It may be less of a problem with ED but could still be depending on the size of the 'European tour' you would want to do...
02-09-2011, 06:39 PM | #16 |
Rep 51
I didn't realize that transmissions are so sensitive to the type of gear oil used. Maybe I should stop using Mobil 1 in my chain saw and follow the manufacturer's recommendations.
02-09-2011, 06:50 PM | #17 | |
SMSgt
11
Rep 239
Drives: AW 1M Coupe
In addition to allowing the fiction materials to maintain a precise amount of friction, it has to eliminate friction in the bearings and between the drive and driven gears. |
02-11-2011, 06:49 AM | #19 |
Ex-Blighty
16
Rep 333
Well the X5M/X6M's dont require a 1200mile (2000kms) running in service, so im not so sure this will get it either!
Rumour has it that the N54 (is) block in the 1M is a 'de tuned' version of the 450bhp unit that'll find its way into the F30 M3!!! That one will no doubt need the 1200mile running in dervice because of the different internals it will recieve...............to cope with the extra output |
02-11-2011, 09:33 PM | #21 |
Ex-Blighty
16
Rep 333
02-11-2011, 10:07 PM | #22 |
BMW Client Advisor
1000
Rep 3,526
you do that
