02-06-2011, 12:17 AM | #4 |
rev limiter abuser
Rep 274
The only time you will have a warranty issue with an aftermarket part is if it causes an issue that has to be repaired under warranty. Then BMW may place the blame on the aftermarket part. An exhaust is safe in that regards.
Showing or promising no abatement of severity, intensity, strength, or pace.
02-06-2011, 10:41 AM | #8 |
160
Rep 466
02-06-2011, 12:30 PM | #9 |
199
Rep 4,318
Nothing Dinan is "approved." Dinan parts come with their own warranty, they are not covered by BMW.
GT3 RS | Desperately seeking the next great M car...
02-06-2011, 12:41 PM | #10 |
1904
Rep 5,678
Where are you getting this from? My dealer would say different... if the exhaust causes an issue then it isn't covered, if there is an issue that isn't related to the exhaust there is NO impact on warranty.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
02-06-2011, 01:07 PM | #11 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
No exhaust in itself will cause an engine issue, header back, catback it don't matter.
Some technicians and dealers that don't know any better will try and blame any issue that you have on your exhaust but seriously that is impossible. The only thing you are changing with the exhaust is reducing backpressure. Engines like to run with as little backpressure as possible. Reducing backpressure can not and will not damage your engine in any way shape or form. The only issue that one may have with an Akrapovic Evo system is needing to have the ECM flashed or running the Akrapovic Delete-R to prevent your check engine light from illuminating due to removal of the primary cats. Personally I chose to have the dealer flash the ECM with the Dinan racing middle exhaust software to prevent my check engine light. Generally Dealers are more friendly to Dinan mods since they install them. I would say if you have your dealer install the Dinan Software and the Akrapovic exhaust they will not give you any issue with warranty since they did the work for you. Talk to your service advisor and see what he has to say about your intentions, you may be surprised how receptive they are....... If they are not receptive then find a more mod friendly dealer to deal with. |
02-06-2011, 05:18 PM | #12 | |
22
Rep 213
I'm far from an expert in this area, but: The tech I request at my local dealership's service department has been running a Vishnu piggyback tune on his 335i for three years. Definitely a mod friendly guy. If push comes to shove, I know that whether something is covered under warranty or not won't be up to him, but he also won't be the first to point out any related components/parts that aren't OEM to those above him if there's ever an issue. Tipping your tech isn't a bad idea either; especially when having work done that doesn't cost you anything. I'm not talking about bribing your tech....just making sure he/she knows your car and knows you appreciate he/she looking after it for you. An exhaust is something I wouldn't worry about for a second though. When you start getting into suspension mods, for example, you need to research the cracked sub-frame issues folks had (are having) with the E46 M3.....some of which, I believe, were not covered under warranty due to suspension components not being OEM. Still, feeling out the manager of the service department is a very good idea. Develop a rapport with them and gauge where they fall regarding mod's that are done correctly, ideally by them, with high-quality, after-market parts.
-Stu-
2011 E90 ///M3 DCT ZCP | Space Gray | Silver Novillo | 2011 F10 550i | Space Gray | Oyster & Black Nappa | ///M Sport | 8 Spd Auto "A toast then: To the BMW M3, the greatest all-around car in the world." -Arthur St. Antoine, Motor Trend Magazine's Editor at Large Last edited by B R A N D X®; 02-06-2011 at 05:25 PM.. |
02-08-2011, 11:11 AM | #14 | |
BimmerPost Supporting Vendor
8209
Rep 18,823
Drives: BMW
I have not heard any warranty disputes from those running the Akrapovic systems, most dealers would not give a second look unless a condition or warranty inquiry (highly doubtful) was made regarding exhaust components.
02-08-2011, 12:26 PM | #15 | |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
i was about to get one installed and then i checked with my SA before and he told me the above so i decided not to do it. what are your thoughts about this?? im not a mechanic, i have no clue how engines and all that works...i just want more sound with a rear section only..dont care about power gains...but afraid of warrnty issues and getting flagged |
02-08-2011, 12:42 PM | #16 | |
344
Rep 2,928
AND, even if you do go to a dealer that supposedly is "mod-friendly" if there ever is sucha thing, what's to say that the person or foreman who didnt care before is still there? what if he moved or transferred out? whatever and thats the day ur car decided it needed to come in?? and there's a new guy?? what if this guy flags ur car on that one unlucky day?? or u came in on your guy's day off? im mean shoot, im so confused u know.... so, is it worth it to keep removing the mufflers and reinstalling the oem everytime before u go in for service?? im debating this right now......=( |
02-08-2011, 12:49 PM | #17 |
344
Rep 2,928
i once had a K&N filter on my 330ci and H&R springs...a different dealer than my current one, started typing stuff on the screen when i came in....i looked over his shoulder and sure enough, he was noting..."customer has modified suspension, customer has modified engine intake" BUSTED! they basically want to avoid paying for any warranty work if possible....then the burden of proof will remain on me to prove that it wanst those mods that caused the issue...then i gotta hire attorneys, engineers, etc..and go fight it out in court...oh god....dont get me wrong, i REALLY REALLY want this exhaust...not sure how to get around it...maybe wait till warranty is over...but then by then, car is old, and it would just be a beater
02-08-2011, 01:39 PM | #18 |
344
Rep 2,928
02-08-2011, 01:57 PM | #19 |
Moderating
418
Rep 2,047
In south africa BMW have officially approved Akrapovic on all models.
AC Schnitzer was the approved aftermarket parts, hence the special edition M3 with all the ACS bits and previously a M Coupe Schnitzer edition marketed by BMW SA Finally they have seen the light I wonder if BMW internationally will go with an approval from factory. It would certainly help |
02-12-2011, 03:41 PM | #20 | |
Grease Monkey
295
Rep 2,646
The pre-cat O2 sensors in our M3's are heated wideband sensors. These sensors generate voltage based on a chemical reaction using air from the atmosphere and exhaust gas reacting on a Zirconia membrane. The voltage generated tells the ECM what the exhaust gas mixture is. The voltage range of an O2 sensor is 0.2V-0.8V with ideal mixture being ~0.45V (stoichiometric or 14.7-1). The post-cat O2 sensors do the same thing except their only purpose is to show the ECM that the catalytic convertors are doing their job. The post-cat O2 sensor voltage is compared to the pre-cat O2 sensor voltage. Once the cat reaches the light off point (316C/600F) and starts cleaning the exhaust gas the ECM wants to see and average voltage on the post-cat O2 sensor of 0.45V to show that the cats are doing their job and that the reaction is taking place efficiently, regardless of the pre-cat O2 sensor voltage. As the efficiency of your cats decrease over time the oxygen content in the exhaust gas stream after the cats decreases therefore the voltage drops below the 0.45V happy medium and a code is thrown. The only possible way I could see reduced restriction/backpressure causing an O2 sensor issue is due to the Exhaust Gas Temperatures are lower at the sensor than needed to effectively operate (Sensors need to be at 316C or 600F to work properly). Since our cars use heated O2 sensors not to mention they are extremely close to the engine this will never be an issue no matter which exhaust you install (cat back or full exhaust). In our cars probably 90% of all the restriction/backpressure in the exhaust system is in the primary and secondary catalytic convertors, not in the rear muffler. If the muffler was a big source of restriction/backpressure, you would make lots of power by changing it but since HP gains with an aftermarket rear muffler are small that tells you it has little effect on restriction/backpressure. Since there are relatively large gains to be had from changing/removing cats, this confirms the restriction/backpressure in the system is mainly in the cats. Finally since BMW now has a rear rear muffler of it's own for sale that is pretty much the final confirmation that changing a rear muffler has virtually no effect on the engine/performance other than increased sound. The long and short of this all is if you experience a premature failure of an O2 sensor it is due to a defect, leaded fuel, silicone contamination, or anti-freeze/coolant entering the combustion chamber, not you putting a muffler on the car. My advice to you is use a different SA/Dealer because your current one is feeding you a line. |
DIXIE NORMUS16.50 |
02-13-2011, 06:50 AM | #22 |
93
Rep 2,528
Exactly Right.
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
