02-04-2011, 05:01 PM | #1 |
39
Rep 194
MS stage 2 intake w/ scoops
I just installed all the bits and peices, just thinking about the scoops now.
Are there any dyno proven results that say these scoops work? I'm guessing you are going to need a pretty powerful fan to push sufficent air into the scoops to simulate 70mph - any thots? |
02-04-2011, 06:26 PM | #3 |
430
Rep 4,650
RPI, the original tuner that developed the intake scoops, have dyno tested and proven their scoops to gain power at wind speeds of over 70mph. If you've ever seen their dyno shop, you'd notice their HUGE fans that can simulate these wind speeds...
so to answer your question, yes. |
02-04-2011, 09:16 PM | #4 | |
BimmerPost Supporting Vendor
8209
Rep 18,823
Drives: BMW
Comparison of Upper Intake Charge Pipe (OEM on left, Macht Schnell ICP on right): Comparison of lower charge pipe (Macht Schnell ICP on left, OEM on right): The stock airbox is awesome in the M3, but the dyno shows there is definitely some room for improvement for those looking to modify. Here is a graph that shows Macht Schnell's own test results. [/QUOTE] Let me know if you have any further questions.
02-04-2011, 11:17 PM | #5 | |
Ninja
390
Rep 4,014
and RPI uses a DD to dyno w/ hood down...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
02-05-2011, 09:16 AM | #7 |
31
Rep 708
The Macht Schnell Stage II looks pretty good for the money and 10HP gain. Wonder how it sounds?
Think before I pop for this, going to run it past my SA on how mod friendly they intend to be with my car. Don't want to have to remove this every visit.
2015 335i
02-23-2011, 02:29 PM | #8 | |
27
Rep 495
Drives: 2008 Alpine White M3 Sedan
I would like to know if this equipment will void the car's guarranty. It looks tempting
2008 Alpine White M3 Sedan, 6 speed manual, extended Red Novillo Leather, Navigation. |
02-23-2011, 02:39 PM | #9 | |
8209
Rep 18,823
Drives: BMW
Paranoia about your M3's warranty with modifications can ruin your overall experience with your M3 - dealers do not have a primary objective to void warranties whenever possible. That being said, most will not question simple filter and/or intake upgrades. When installed, the pieces look very similar to OEM in both color and texturing.
02-23-2011, 02:43 PM | #10 |
Advansolosis
218
Rep 1,448
i have the aFe kit with MS Scoops, car sounds diff, not sure if its really a big noticeable diff, my gf noticed a diff apparently. I didnt
2011 E90 M3, ESS VT2-650, 2015 GL550 |
02-23-2011, 03:22 PM | #11 |
923
Rep 15,818
if you have the MS filter without the CP... is that still cool?. or would a CP be needed?
02-23-2011, 04:34 PM | #12 |
430
Rep 4,650
IIRC the MS filter w/o the CP is different than the MS filter w/ the CP. This means if you buy the MS dropin filter w/o the CP, and you decide to buy CP later on...you'll have to buy a new filter from MS.
02-23-2011, 04:40 PM | #13 |
Putcha ang ganda...
281
Rep 5,441
To the OP i have ran my Envy intake ever since i got the car and serviced it 4 different times for oil change and other things and not 1 bit they complained about me modifying the car just put that thing on... We all get paranoid cause of warranty issue... As long as ur ECU is intact ur good
02-23-2011, 07:58 PM | #14 | |
27
Rep 495
