02-03-2011, 05:35 PM | #1 |
83
Rep 1,461
Only dynoed 304.9whp on DD
Got my car dynoed for the the very first time at Rogue Engineering (thanks for getting me in Ben ). I've seen most cars dyno at around 320-340 stock. Best results with my car was 304.9 on a dyno dynamics. I'm stock except for my eisenmann race and running 93 octane.
Fan was running but the hood was closed if it makes any difference. I asked for the file, but Ben said it's not available, so this is all I have: Is this normal? Should I be concerned? I'm getting a compression and leakdown test soon. Last edited by gixxer_kidd; 02-03-2011 at 05:40 PM.. |
02-03-2011, 05:41 PM | #2 |
141
Rep 4,903
Drives: '08 E92 M3
Hmm, this is definitely the lowest that I've seen.
'08 E92 ///M3 - AW/BLK/CF, M-DCT, 19's
H&R, Vorsteiner, Eisenmann, BMC, BBS More to come... |
02-03-2011, 05:44 PM | #3 |
196
Rep 1,231
I had my '99 M3 dynoed on that exact machine not too long ago. The Dyno Dynamics machines tend to read on the low side... I put down 220.7 WHP and was AMAZED. I was guessing more like 185-195.
02-03-2011, 05:50 PM | #4 |
83
Rep 1,461
Yea, it's got me concerned.
Either you car is a beast, or my car is a dud |
02-03-2011, 06:08 PM | #6 |
83
Rep 1,461
02-03-2011, 06:13 PM | #7 |
167
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
My car dyno'd 320whp when it was heat soaked in summer, and 335whp a week ago when it was nice and cool. I talked to one of the Active guys and he said their stock M3 dyno'd 333whp before they put on their blower. So it seems like 330-340ish is the norm with good conditions at sea level.
02-03-2011, 06:13 PM | #8 |
196
Rep 1,231
The dyno could have been setup differently the day that I made my runs. After I made my runs I saw a bone stock F10 550i put down ~360 WHP/391TQ. A few E9X M3's made runs too but I don't recall their numbers. :-/ I want to say they were in the 340-360 range, but I'm not 100% sure.
02-03-2011, 06:15 PM | #9 | |
83
Rep 1,461
02-03-2011, 06:16 PM | #10 | |
83
Rep 1,461
02-03-2011, 06:17 PM | #11 |
167
Rep 2,736
This was on a dyno-jet.
02-03-2011, 07:31 PM | #14 |
Scared money don't make money.
67
Rep 1,448
Drives: 2009 E92 M3 DCT
My guess is that your car is just fine . Rogue probably isn't running a large correction factor. FYI, Gintani's dyno dynamics reads stock e9x M3's at 300-305 since they updated their software.
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
02-03-2011, 07:38 PM | #15 |
2760
Rep 5,483
The racecar in my signature consistently dynoed 104-105whp on a Dynapack, and consistently competed with and won races against cars with 120-125 dynojet whp, with very little to choose between them on the track. The one time I put that engine on a dynojet, it made 118whp. On the dynapack by varying a few parameters like run length, gearing, I could make the car put out 90 to 120+whp. Go to the track and if it traps in the 109+mph range in the 1/4 mile you're probably fine, or get a Vbox and compare to other people's results if you're really worried about it. Dynos are dynos and the track is the track. One is a tuning tool, the other thing is a place where you can determine the performance of the car.
02-03-2011, 08:01 PM | #16 | ||||
83
Rep 1,461
Okay, I'm reading a dyno-jet can read 15% higher so it makes more sense now.
02-03-2011, 08:20 PM | #17 |
All I do is Win... Eat Race Sleep
152
Rep 2,184
Drives: 2018 Range 2011 M3 2019 600lt
Bad gas could be a possibility.
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888 F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires |
02-03-2011, 08:45 PM | #18 |
196
Rep 1,231
Good luck!
02-03-2011, 08:49 PM | #19 |
30
Rep 1,789
What have other M3s put down on that dyno?
Others might not agree with this, but I think the easiest way to test your car is to do a few friendly runs with other M3s. You'll quickly find out if your car is on par or not. |
02-03-2011, 08:50 PM | #20 | |
Ninja
390
Rep 4,014
OP: hood down is important IMO, as I don't see anyone driving around hood up, so that little bit of extra air flow can sometimes/most of the time inflate advertised numbers/gains. Just make sure you perform your next dyno on the same DD as well as same operator (if possible)....think of this as your "pre-dyno"
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
02-03-2011, 08:51 PM | #21 | |
Ninja
390
Rep 4,014
02-04-2011, 02:44 AM | #22 |
BimmerPost Supporting Vendor
92
Rep 1,064
Hi
Don't do anything yet. First thing is that you have a very very natural power delivery / perfect power curve. It's most likely the dyno correction factors that are playing their hand here. Without knowing the correction factors NOTHING should be said!! I can guarantee you there is nothing wrong with you car and if I have some time today I will use this example to show how important correction factors are and how useless it really is to talk about power output without these. |
