KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-03-2011, 01:05 AM | #1 |
Rep 22
19x9.5 et 22 front 19x11 et 33 rear will this rub ?
planning to put the AG m310 19x9.5 et 22 for front and 19x11 et 33 with 15mm spacer for the back so the rear will be 19x11 et 18. Now im concerning will this setup rub ? The car is lowerd on RD sport spring, and the tire size might be 255/35/19 F, 285/30/19 R.
Any of you guys have the similar setup ? any thoughts about the rubbing ? |
02-03-2011, 01:09 AM | #2 | |
808E90
233
Rep 4,047
19x9.5 et22 265/35/19 19x11 et22 295/30/19 Car sits on H&R ... No problems at all
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
02-03-2011, 05:22 AM | #3 |
141
Rep 4,903
Drives: '08 E92 M3
My front set up is exactly the same as yours. No rubbing on H&Rs. The rears however... 19x11 +25 295/30/19 do rub from time to time. Always rubs with a full car(I rarely ever have a full car). Also I believe the brand of tire plays a factor, I'm running 295 on AD08's while a friend of mine is running 305 PS2s on the same wheel set up, yet he doesn't rub. I would think that 10mm in the rear is as aggressive as you can go and that may possibly rub as well.
'08 E92 ///M3 - AW/BLK/CF, M-DCT, 19's
H&R, Vorsteiner, Eisenmann, BMC, BBS More to come... |
02-03-2011, 09:08 AM | #4 |
876
Rep 3,450
I have same exact front setup. definitely won't rub there.
rear sounds pretty aggressive, even for a sedan. btw, the 285/30 will look a bit small and stretched. 295/30 would be much better, but I don't even think the 285 would fit without rubbing. |
02-04-2011, 06:09 PM | #6 |
BimmerPost Supporting Vendor
1768
Rep 7,652
this is what we like using.
19 - 9.5 et 22 -> 265/30-19 19 - 11.0 et 33 -> 305/30-19 on certain tire brands, the 295 would be the route to go.
02-08-2011, 05:47 PM | #7 |
52
Rep 321
I am running the following :
Front - 19x9.5 ET22 with a 245/35/19 Hankook K110 Rear - 19x11.0 ET25 (ET33 with an 8mm spacer) with a 285/30/19 Hankook K110 Lowered on H&R... No rubbing Yuji |
