KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-01-2011, 01:14 PM | #1 |
30
Rep 182
air pressure measurement adjustment based on outside temperature
Do you adjust your air pressure measurement based on outside temperature?
I remember hearing that if you've been driving around all day then the air pressure measurement for your tires will be skewed. So what if the outside temperature is freezing? Like 20F? I measured the air pressure in my front tires this morning and they were at 20psi but I'm not sure if this low measurement was partially due to the freezing outside temps. So would you expect this air pressure measurement to be higher if the outside temp were 80F+? |
02-01-2011, 01:27 PM | #2 |
19
Rep 561
All your tires were at 20psi?? Is the car garaged? Obviously pressure increases as temp increases and same with cold(decreases) but it's usually not more than a few lbs.
02-01-2011, 01:38 PM | #3 |
M3Post Supporting Vendor
87
Rep 964
Not exact, but a good rule of thumb: every 10 degrees will roughly equal 1psi. So if your tires are at 20psi at 20 degrees, they'd be at ~26psi at 80.
For street cars (circuit racing is a whole different subject), air pressure is properly measured when the tires are 'cold', meaning at whatever the current ambient temperature is. This will often mean adding air when the weather turns cold, and sometimes bleeding air out if you move rapidly from a cold to a hotter climate.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
02-01-2011, 01:50 PM | #4 | |
30
Rep 182
