BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      01-29-2011, 06:28 PM   #1
CBS
CBS's Avatar
87
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
Head and Neck Restraint
If this has been previously posted, then please excuse me. I’m new to the forum so I would welcome some advice. In my previous 2008 M3, I had attended (5) HPDE’s through BMW Chapters. These events taught me that I have a lot to learn. At my last HPDE an instructor advised our class to invest in head and neck restraint equipment. They specifically mentioned the R3 Rage. Assuming I will use my factory seat belts, can someone advise me on my options and if this is something I should invest in? Thanks.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      01-29-2011, 08:10 PM   #2
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
I've been using the R3 device. Fortunately, never had to test its performance, but I am happy with the way in restrains my neck when in a car with regular seatbeats. You can take it with you to any street car you might be in. It's worth it IMO. My only criticism is that the designers seem to have forgotten that the human spine is not straight; the flat element that runs down the back literally presses against your verterbra and over time it hurts. I simply stuck some padding in there, and it's much better...
      01-30-2011, 06:46 AM   #3
CBS
CBS's Avatar
87
2011 M3 E90  [9.74]
1990 M3  [9.50]
1988 M5  [10.00]
Thank you! I will make sure to get this before the season starts. This may be a dumb question since I am not familiar with the R3 but I assume holes will need to be drilled into my helmet? I'm guessing the R3 comes with instructions on how to modify my helmet? I have an Arai GP-5W.
      01-30-2011, 07:26 AM   #4
lucid
lucid's Avatar
374
It depends on the type of helmet you have. Some/most are predrilled these days, but if it is not, then you need to drill your own. I had to do that with my old helmet. Yes, it comes with instructions for that. Also, you need to make sure the chest belt fits. I was in between sizes, so I had to send mine back and they modified it free of charge. Their customer service was pretty good. The only other minor thing is that the top horizontal part doesn't fit very well with some seats. It's not as if you can't use it with those, but I've found it to be more comfortable in some seats than others. It worked fine for me in the E92 M3. It does come with padding that has a T shaped hole in it act as an adaptor for the seat, which helps, but I don't know that you want to fix it to your nice leather seat.
http://www.safetysolutionsracing.com...s/r3-rage.html
I am moving to a Hans system for my track car because of the somewhat minor comfort issues I mentioned, but I will keep the R3 for street cars for sure.
I am not affiliated with safetysolutions in any way btw...
      01-30-2011, 07:53 AM   #5
M3 Pilot
M3 Pilot's Avatar
Australia
74
Drives: 17' F80 M3 ZCP
I have recently started using a Hans device. I went with the 20 Deg, sliding tether which allows me to look side to side.
Unfortunately no one in Australia wants to drill my old school helmet for fear of implications, hence I ended purchasing a helmet that came with a predrilled hole.
Installation is relatively easy and quick.
Do take note of the type of harness that needs to be used in conjunction with the Hans device. Some requires different sizes of harness. If you are using a 3" harness, make sure your Hans device is suited for 3".
Here's a website which can explained in more detail than I do.
http://www.stand21.fr/hans/hans-2.html
2013 E92 M3 ZCP
2014 F06 M6 GC
2017 F80 M3 ZCP
      01-30-2011, 08:34 AM   #6
CBS
CBS's Avatar
87
2011 M3 E90  [9.74]
1990 M3  [9.50]
1988 M5  [10.00]
Thank you Gentlemen! You have given me the advice I was seeking. As previously mentioned I am new to this Forum and Sport and I'm hooked. I'm sure I'll have other questions.
My Wife thinks I've lost my mind (mid-life crisis) but our 4 Teenagers are interested, 1 Teen has already gone through the BMW Teen (Car Control) School in Spartanburg, SC. Our remaining 3 will be going this summer. Good, safe driving is important.
Kind regards!
Chris
      01-30-2011, 08:55 AM   #7
Jaypod
Jaypod's Avatar
No_Country
125
Drives: Frozen M3, AM V8V, 991 GT3
This may be another alternative. Looks more comfortable than the R3 and not as expensive as the Hans:
http://www.defnderneckbrace.com/index.html
Edit: just realized you mentioned the factory belts, not sure if this is compatible or not
      01-30-2011, 10:31 AM   #8
lucid
lucid's Avatar
374
When I bought the R3 device, there was nothing else on the market that did not require a harness. I don't know if that is still the case.
      02-02-2011, 08:25 PM   #9
Kenny@VS
Kenny@VS's Avatar
11
Drives: White E92 M3
This is my recommendation. Stilo is what were going to start to carry. their great helmets. they already have the hans mounts and 2 side ports for drink or radio. and you can add a air port as well. All most all other helmets you have to drill for the accessories. And Hans for Neck. Pm if you have any questions. Hope this helps.
      02-02-2011, 08:48 PM   #10
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Question: are most racing seats on the market compatible with Hans? Or only the ones that say "Hans" on them? For example, Recaro Pole Position vs. PRO RACER HANS® SPA.
      02-02-2011, 09:54 PM   #11
M3 Pilot
M3 Pilot's Avatar
Australia
74
My understanding was that Hans compatible seats merely allows more space between your head/neck area and the seat to cater to the Hans device, as well as enlarged slots for your harness.
If you find the seat uncomfortable due to lack of room between your head and the seat, you may need to either adjust the angle of your seat or buy a Hans compatible seat.
I would be more concerned about the location in which the harness is anchored/wrapped relevant to the height of your shoulders.
2013 E92 M3 ZCP
2014 F06 M6 GC
2017 F80 M3 ZCP
      02-02-2011, 11:19 PM   #12
Kenny@VS
Kenny@VS's Avatar
11
The seat has no affect on the functionality of the hans. But I would definitely get Hans style seat belts so the straps fit right on the device.
      02-03-2011, 10:30 AM   #13
turbo8765
61
Drives: very fast
The Hans device fails to limit significant lateral movement of your head. This is a limitation of the device. The "Hans compatible" seat has wings for your head to limit lateral movement.
The seat also has larger ports for the harnesses, I don't know why. I believe the key feature of the seat is the limitation of lateral movement.
      02-03-2011, 02:53 PM   #14
BRDHNTR
Ground Pilot
BRDHNTR's Avatar
41
Drives: e92 BMW M3
2002 M3  [0.00]
2008 e92 M3  [0.00]
+1
I have a Cobra containment seat (wings like the Recaro HANS) for the driver side and a Cobra "standard" racing seat on the passenger side of my track car. The containment seat is really only good for dedicated track cars as you can't really check blind spots. I am very pleased with my seats. I was going to buy the Recaros, but I couldn't get anyone explain to me why they cost hundreds more than Cobra. I use a HANS, but I also have 6pt harnesses. NOTE: if you plan to buy harnesses for use at DE's, remember that the HANS can be used with 3" belts but it isn't considered safe to use the 2" HANS restraints w/o a HANS. So buy the 3" belts for the passenger side in case your instructor doesn't have a HANS.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
      02-03-2011, 03:22 PM   #15
lucid
lucid's Avatar
374
I can't offer insight as to why the Recaro SPG Pro Racer Hans costs $500 more than the Cobra Sebrin Pro. However, I did walk away with the Recaro after sitting in both, and it was strictly a fit consideration. My shoulders were making contact with the halos on the Cobra, and I felt like I was floating on top of the bottom cushions. The Recaro has a much different countour at the bottom and you literally sink into to it, and it also offered much better lower back support. My old seat was a Cobra seat (can't remember the model) and I was happy with it.
      02-03-2011, 08:22 PM   #16
dhoggm3
dhoggm3's Avatar
269
Drives: 850i C, Gated R8 5.2, E63
If this is the Hans for regular-seatbelt cars, I highly recommend it. I use a regular Hans but I've spoke with lots of BMW CCA instructors who use these and swear by them. It's really cheap life insurance.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune
Alpina B8, zero performance mods
      02-06-2011, 06:50 AM   #17
Feffman
23
Drives: M3
I've been wearing a Hans for over two years and wouldn't do another track day without it. Simpson Racig (www.TeamSimpson.com) is an official Hans supplier. Give them a shout for information.
Feff
m3post
