      01-28-2011, 11:23 PM   #1
scott135i
scott135i's Avatar
356
Drives: 2020 X5 M50i
Moaning Noise coming from N54 Engine (On and off...) What could it be??
Please check out the video below. It is from tonight, from my mother's 2008 135i with 22k on the odometer... . I pulled over to hear what the noise was, popped the hood, and heard the noises.... WTF could it be? Something common or obvious? There is no check engine light on, and the car seems to be running perfectly.
I need to check for codes later this weekend...
Experts.... anything?
Last edited by scott135i; 01-28-2011 at 11:27 PM.. Reason: Link added... video embedded
      01-28-2011, 11:24 PM   #2
scott135i
scott135i's Avatar
356
Vid embedded above...
      01-28-2011, 11:28 PM   #3
tyorll
tyorll's Avatar
Australia
Drives: 135i
Originally Posted by scott135i View Post
Can anyone see the vid?
vid works fine. I'm not sure what that sound is though. But I am sure someone here with loads of experience will likely know the cause.
      01-28-2011, 11:36 PM   #4
ErvGotti
No_Country
124
Drives: 2008 135i 6MT
2008 135i  [6.00]
Hmmm never heard that sound before from any N54. If I had to guess since it seems to be coming from the exhaust side is maybe a pinched or leaking vacuum line leading to the solenoid for the wastegates since that was what you were pointing to. Just my guess.
      01-28-2011, 11:39 PM   #5
scott135i
scott135i's Avatar
356
Sounds like it was coming from that general area, but I couldn't tell exactly where....
      01-28-2011, 11:47 PM   #6
moveswiftly
moveswiftly's Avatar
381
Drives: Cayman GT4, 135i
2012 335iS  [0.00]
DAMN!
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi
      01-29-2011, 03:37 AM   #7
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
Solenoid might be on its way out. Take it to your dealer
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
      01-31-2011, 10:52 AM   #8
ModBargainsTech
ModBargainsTech's Avatar
Drives: E92 335i/E90 335i/ E82 135i/
I would say take it to the dealer as probably none of us can really diagnose your problem by watching that video.
-Frank
      01-31-2011, 04:02 PM   #9
scott135i
scott135i's Avatar
356
Going in on friday... just was looking for feedback from someone if they had a similar noise/issues...
      01-31-2011, 04:19 PM   #10
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
477
Drives: Topless Brute/Hybrid Boogaloo
Originally Posted by chesterfan1230 View Post
DAMN!
If you keep saying that Mo, you better bring free RedBull.
      01-31-2011, 04:43 PM   #11
135ITT
135ITT's Avatar
Drives: SGM08
turbo empeller free spinning or bad bearing in the turbo. hope not
      01-31-2011, 05:14 PM   #12
neech
Drives: "11 M3
Is the sound still there when you rev it up a little, does it change at all (pitch) or remain constant? From the title of the thread it sounds like it's not RPM dependent which would rule out anything mechanical inside the turbo, sans wastegate.
      01-31-2011, 07:20 PM   #13
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Australia
110
Drives: a sleeper
I love how you give the engine cover some 'technical whacks'
No idea OP, never heard something like that before. Good luck at the dealer!
E82 135i M-sport: SGM/6MT/Black
      04-11-2011, 10:19 PM   #14
scott135i
scott135i's Avatar
356
SOLVED....
Details from worksheet:
Faulty Pressure Converter
Duplicated Noise. Found coming from 2nd pressure converter.
Checked all vacuum hoses for leaks. All okay. Replaced pressure converter and tested. Noise Gone.
PRESSURE CONVERTER Part #11747595374
-It is part of the 'vacuum control system'
      04-12-2011, 01:50 AM   #15
Si-M240i
137
Drives: M240i LCI
I get a moaning noise too but mine is inside the car and only there when the wife is in the car with me......
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
      04-12-2011, 08:41 AM   #16
burger16b
burger16b's Avatar
13
Drives: 135i
      04-12-2011, 11:37 AM   #17
infinitekidM2C
infinitekidM2C's Avatar
4207
Drives: 2019 M2 Competition
I would have guessed a kitten purring..guess i wouldve been wrong
      09-27-2015, 02:06 AM   #18
trap
Australia
16
Drives: 135i AW '09
I have the same noise, pretty sure it's the Pressure Converter. No other symptoms or codes. Can this affect something else if left like that?
Tags
135i, bmw, engine, moan, noise
1addicts
