01-27-2011, 08:27 AM | #1 |
37
Rep 615
1M comes with Valvetronic?!
Did I miss something?
I thought the N55 was the only engine with valvetronic. But according to http://www.1addicts.com/forums/showthread.php?t=481113 see attachments, 1M has valvetronic?!? I've been lurking on the forum and I thought I knew it all..
VO 1M - everything except sunroof
RIP BSM 135i 2009-2011 |
01-27-2011, 08:30 AM | #2 |
37
Rep 615
ok must've missed it. It's equipped with the N55?
I thought all early indications pointed to N54
01-27-2011, 10:34 AM | #7 | |
37
Rep 615
http://www.1addicts.com/forums/showthread.php?t=463733 It also says N54. But it also says TwinPower Turbo. Something is seriously wrong. Scott said Hybrid... but if hybrid meaning N55 turbos and valvetronics... then it's just N55 since the block makes no difference!
01-27-2011, 10:41 AM | #8 |
381
Rep 2,926
Drives: Cayman GT4, 135i
you guys are confused
Its an N54, the same n54 used in Pre 2011 135i's. Take a look at the engine bay. It is NOT A Twin Power turbo(n55).
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
01-27-2011, 10:43 AM | #9 | |
37
Rep 615
Everyone's confirming N54s. But the BMW release docs for Canada says TwinPower Turbo, WITH valvetronic. Also if you look at south's published data it ALSO says TwinPower Turbo. Someone in BMW is confused. I'm trying to straighten it out
01-27-2011, 10:47 AM | #10 |
Rep 129
But TwinPower Turbo means only that it has 2x Turbos. In case of N54 there are 2 separate Turbos and in case of N55, the 2x Turbos are in one housing and attached with TwinScroll Technology (Turbo layout).
I think, the N54 motor of the 1M has 2x separate Turbos BUT it uses Valvetronic. Or just dreaming... hehe.. it may have 2x separate Turbo housings using TwinScroll Technology.. so it would have 4 Turbos :-P |
01-27-2011, 10:49 AM | #11 | |
37
Rep 615
01-27-2011, 11:14 AM | #13 |
Rep 129
Ok, sorry... you are right. They call it TwinScroll also. I rechecked all the terms now and its like that:
The definition of "M TwinPower Turbo" is used also for the X5/X6 M and there it also have TwinScroll. TwinScroll means they use one turbo with a patented tube to from the motor exhaust into the Turbo. The TwinScroll Turbo has 2x main rotors which get the exhaust from half of the cylinder each rotor. In case of X6M they have 2x Turbos with TwinScroll Technology which means there are 4x Rotors which get the exhaust from 2 cylinders each. The 1M uses M TwinPower Turbo but it does not say that it uses TwinScroll Technology. Here is some interesting info: http://www.vanguard-performance.com/...mw-n54-vs-n55/ |
01-27-2011, 11:25 AM | #14 | |
Ed
18
Rep 298
The N54 has NO valvetronic.
01-27-2011, 11:30 AM | #15 |
103
Rep 1,417
It looks as though BMW's press people are as confused by the words "TwinPower Turbo Technology" as we are.
From the BMWUSA web site http://www.bmwusa.com/default.aspx Look at the US Spec for the Z4is which we know is the same engine as the 1M. At the top of the Spec page explains the engine with Double-VANOS steplessly variable valve timing, but not Valvetronic. The BMW Press release for the 1M did not say the 1M engine included Valvetronic as well. http://rawautos.com/2010/12/press-re...orld-meet-1-m/
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles Last edited by Redadair; 01-27-2011 at 12:03 PM.. |
01-27-2011, 12:00 PM | #17 | |
103
Rep 1,417
Thanks
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
01-27-2011, 04:05 PM | #20 |
417
Rep 6,968
Thought the goal of N55 was better fuel efficiency therefore the single turbo and twinscroll design. Maybe valvetronic helps?
- There's nothing in my pocket other than knives and lint
01-27-2011, 08:13 PM | #21 |
Moderator / European Editor
1540
Rep 6,754
BMW uses the term TwinPower Turbo for most if not all of their turbo engines, it's not a term indicating a certain technology. It can be either two turbos (N54 for the 1M, N63 for the 550i) or one twinscroll turbo (N55 for the x35i, N20 for the x28i), or even a sequential turbo as found in the 535d.
Finally, the 1M engine does not have Valvetronic. Best regards, south
01-27-2011, 09:15 PM | #22 | |
7908
Rep 11,785
Kinda like an M badge doesn't indicate a certain technology... |
