01-26-2011, 10:39 PM | #1 |
Rep 40
To supercharge or not to supercharge?
I was wondering about your thoughts on supercharging and E9X M3. I know the power advantages are obviously tremendous but the pressure it puts on the engine are great too. Plus isn't that one of the things that makes and M3 so special the naturally aspirated motor. So what do you think because I'm having a hard time deciding what would be best looking at every aspect. What would or did you do?
01-26-2011, 11:03 PM | #2 | |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
01-26-2011, 11:07 PM | #3 |
10816
Rep 27,599
^^ from what i have read the guys with the SC kits are actually doing pretty well. I guess its safe to say if you are baller enough to afford a SC chances are you are not worried about MPG.
Jeff you should get a kit! haha
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-26-2011, 11:14 PM | #4 | |
344
Rep 2,928
Ohhh man am I tempted hahaha... Id have to devise a plan to slip this one past the wife! |
01-26-2011, 11:15 PM | #5 |
10816
Rep 27,599
hahahahah classic.
01-27-2011, 12:05 AM | #6 |
344
Rep 2,928
01-27-2011, 12:14 AM | #9 |
167
Rep 1,159
One of my concerns is also how this affects the life of the vehicle? But honestly, this is a M3. If this is your super car then you know what? Go for it. However in my case, the car is very fast by its self no? It sounds tremendous, if anything maybe just get an exhaust, and cut yourself some money?
But hey, the supercharger is effin badass. If you have money to throw the why not?
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
01-27-2011, 12:42 AM | #10 |
342
Rep 1,805
MPGs increases with the blower when driven normally (not flooring it). I was able to get around 25mpg on the freeway and 17 in the city when cruising. I had the Gintani kit. I know the ESS guys have experienced an mpg increase as well.
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
01-27-2011, 01:34 AM | #11 |
344
Rep 2,928
how is this possible? isnt it More power, more gas?
01-27-2011, 01:44 AM | #12 |
M-Flight Member
38
Rep 1,085
Wıth the blower you now have more torque whıch allows you to stay lower ın the rpm range when acceleratıng normally whıch allows you to shıft sooner. Durıng hıghway cruısıng you would be a the same rpm range, so I ımagıne your hıghway mıleage would stay about the same.
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
01-27-2011, 01:47 AM | #13 |
501
Rep 2,391
Do it! Car becomes a whole other animal
Currently: 2019 991.2 GT3 RS Lizard - 2016 991.1 GT3 RS Lava - 2019 991.2 GTS
SOLD: 2022 BMW M5 Competition - 2016 GT3 RS UltraViolet -2018 GT3 Chalk - 2016 GT3 Lava - 2015 GT3 Guards Red - 2018 Audi RS7 - 2016 F80 M3 - 2015 GT3 Black - 2015 GT3 Carrara White - 2016 991.1 GTS - 2012 997.2 GTS Cabriolet - 2011 E92 M3 - 2006 E46 M3 |
01-27-2011, 01:51 AM | #14 |
30
Rep 1,789
While cruising, you can get close to stock mileage with proper tuning, but at other times, you will always be adding more fuel versus NA.
And if larger injectors are used, there's no way it can be more efficient than stock. |
01-27-2011, 02:16 AM | #15 |
342
Rep 1,805
it is...but it has to do with efficiency. Hopefully someone smarter than me can chime in. But it is a fact that if driven with a light foot the gas mileage will be better.
01-27-2011, 02:35 AM | #16 |
441
Rep 3,668
I think about getting a supercharger so much. Im at the point where I think the m3 is slow , probably because im use to the power.
However there is a couple things that concern me: warranty issues( Im a 2011 model ) Engine lifespan money ($10,000-$15,000) is it really worth it? I can care less about miles per gallon, I get 12mpg now how much worse can it get? I didnt buy a prius. However there is other expenses also. For example you need a big brake kit ($7,000+/-). If your going to go faster you need better brakes. Is gets to the point if your going to spend this much money on a m3, its just better to get a gt3. |
01-27-2011, 08:59 AM | #17 | |
31
Rep 1,460
01-27-2011, 10:44 AM | #20 | |
923
Rep 15,818
I've seen plenty of S/C M3s without a BBK
01-27-2011, 11:09 AM | #22 |
44
Rep 436
I've been debating this too....
One the one hand it would be great to have a SC's power with the M, it really would. But then at the same token, I spent $62k on this car (minus T&L) and for me to spend $13k alone for a supercharger kit, that's 21% of my entire car's value. Just from a numbers standpoint, to me that doesn't make sense. But then again, I was crazy enough to spend $5k on an exhaust system, but $5k is considerable less than spending $13k(and voiding the engine warranty if you still have it). I think if I need this kind of power out of an M, I'm better off finding another vehicle with a turbo or sc platform. We as car enthusiasts are always searching for more power, when is enough enough Granted, folks who have SC's on their M's do so for their own reasons and that's perfectly fine. But at the moment I'm leanining more towards picking up a brand new leftover 2009 or 2010 model sport-bike and having the best of both worlds, an M and a bike . I've been without a bike going on two years now, and with summer coming up I'm getting an itch. |
