01-21-2011, 10:58 AM | #1 |
145
Rep 165
Cooling 1M vs 135i & Z435is
The E92M3 and M1 have an extra coolant / air heat exchanger and utilise an 850W electric fan, whereas the 135i and Z435is use a 600W electric fan.
Well that's just a guess you understand, it certainly hasn't come from inside BMW! ;-) |
01-21-2011, 11:03 AM | #2 |
European Editor
10589
Rep 22,992
The 1M and Z4_35is (I think) will have the same cooling system. You can see this when you look up the coolant capicity 10+L vs the 135is 8L's. Both should have the same higher output PPK radiator fan. 1,200+ watts(?)
I am not sure about what the M3 has for cooling. Apples to (Valencia)Oranges if you ask me. |
01-21-2011, 11:04 AM | #3 | |
145
Rep 165
01-21-2011, 01:12 PM | #5 | |
292
Rep 2,898
Neil |
01-21-2011, 01:17 PM | #6 |
European Editor
10589
Rep 22,992
01-21-2011, 04:08 PM | #8 |
292
Rep 2,898
01-21-2011, 04:45 PM | #10 |
European Editor
10589
Rep 22,992
01-22-2011, 08:06 AM | #12 |
Rep 51
6-speed manual transmission with dry sump cooling system and 3.15:1 final drive ratio
Does the Z4 35is also have a dry sump for the transmission?
I've seen cars with dry sump systems for engine oil, but not for the transmission. Can someone describe and explain BMW's transmission dry sump? |
01-22-2011, 03:45 PM | #13 |
132
Rep 1,898
nope, it doesn't. The Z4 35is is only available with DCT if I am not mistaken. The 1M is only available with a manual.
01-22-2011, 03:50 PM | #14 | |
132
Rep 1,898
01-22-2011, 06:08 PM | #16 |
Rep 51
1M dry sump
01-22-2011, 07:16 PM | #17 |
48
Rep 711
Drives: '04 E46 M3
I don't think either has a dry sump: http://en.wikipedia.org/wiki/BMW_S65
"A conventional wet-sump lubrication system with two oil pumps replaces the three-pump dry sump system used on the V10, further decreasing weight."
01-23-2011, 09:25 AM | #19 |
Rep 51
1M dry sump
From http://www.1addicts.com/forums/showthread.php?t=463733
6-speed manual transmission with dry sump cooling system and 3.15:1 final drive ratio, with M gearshift knob So far, people have stated that the 135i 6-speed, M3 6-speed, and Z4 35is do not have a transmission dry sump. I am wondering if the 135i 6-speed had a problem with lubricatin and that is why the dry sump was added to the 1M. I believe dry sumps are more common for engine lubrication than for transmission lubrication. It was mentioned that the S65 engine had a dry sump. I used to have a C6 Z06 which had a dry sump for the engine. But I have not heard about cars with transmission dry sumps. So why is there a dry sump for the 1M transmission |
01-23-2011, 10:17 AM | #20 | |
7906
Rep 11,785
01-23-2011, 11:02 AM | #21 | |
132
Rep 1,898
The rest I agree to. I think this is a way to put less stress on the existing cooling system. |
