01-20-2011, 02:56 PM | #1 |
285
Rep 1,289
blow off valve
I was thinking about getting a blow off valve for my 135 and wanted to see what other people were running and what the best one is to get. Also, are they pretty easy to install?
Any input is appreciated! |
01-20-2011, 04:15 PM | #2 | |
123
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
Synapse TiAL Q these are the most popular. You will need to get a charge pipe with the flange for the BOV kit. The most popular ones on the market are: Stett, which prefers the TiAL BOV but will machine what flange you prefer if you want to use another BOV ER - which has many options, no meth bung HPF BOV kit which is going to be released soon, using the synapse. Lots of it comes down to personal taste of sound vs loudness of the BOV, all have been shown to perform well. If you are running stock boost then there is no real advantage to charpe pipe/BOV. Terry has actually shown the stock DV set up holds boost well, but other will disagree. Do your homework too cause charge pipe blowing off under load may occur with some of the manufactures of charge pipes out there.
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
01-20-2011, 04:36 PM | #3 | |
4207
Rep 5,728
Drives: 2019 M2 Competition
01-20-2011, 04:43 PM | #4 |
123
Rep 1,925
cool, thanks!
01-20-2011, 09:51 PM | #5 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
Hmm... haven't heard of this before (not spending enough time in the tuning/performance forum)... are certain manufacturers more or less prone to this happening?
01-21-2011, 08:34 AM | #6 | |
285
Rep 1,289
01-21-2011, 08:57 AM | #7 | |
11
Rep 685
Drives: 91 300ZX Twin-Turbo, 2010 135i
This basically turns your diverter valve into a blow-off valve, because it will be dumping to atmosphere instead of your intake. The other option is to just remove the flex pipes all together and cap off the intake side, would look cleaner that way. |
01-21-2011, 09:37 AM | #8 | |
123
Rep 1,925
01-21-2011, 09:39 AM | #9 | |
123
Rep 1,925
Meth bungs are for if you are running meth, not the ideal set up but works. Ideally you want your meth on your manifold.
01-21-2011, 02:09 PM | #10 | |
285
Rep 1,289
04-25-2011, 11:49 PM | #11 | |
Freshman RaceR
Rep 92
The Overall Picture!
With the help of YouTube, of course. Search up BurgerMotorsport JB3 install vid and it will show you how to take off the top cover in the engine bay ( its the cover closest to your windshield and this gives you more space to work with more than anything, as it is not necessary to do so to install it) then snap off the air filter box (if you don't have something aftermarket already), for me, i took off the stock plenum also. Now the stock diverter valves should be clearly visible, and just just go on and detach them and the stock "chargepipe" and remove the TMAP sensor which is a microchip looking thing thats sorta shaped like a 'T' and place it onto your new chargepipe and remove stock vacuum line (the ER setup had a vacuum line on the BOV already), then go on and install the aftermarket chargepipe into its place, and plug in the vacuum line, and cap off the open slots where the diverter valve was once connected..and put everything back on....thats the overall picture, but its not too bad when its in front of you, and the ER set gave me detailed instructions..no pictures though but you'll live. OH and one last thing get a Oil Catch Can because you'll have oil leaking out of the BOV : other than that the BOV sounds good and if you like something thats more of a mid range pitch when it releases boost then you'll like it. Go HKS if you like the higher pitch sphhhhshshshshpppppp! |
04-26-2011, 02:58 AM | #12 |
48
Rep 711
Drives: '04 E46 M3
I'm running the ER charge pipe with Synapse BOV, couldn't be happier. Also ordered it with two meth bungs and had it hard anodized in black. This is a great part and throttle response is much better.
04-26-2011, 08:28 AM | #14 | |
285
Rep 1,289
04-26-2011, 09:25 AM | #15 |
112
Rep 969
What if you got the Cobb AP first... or any tuning solution that ups boost and maybe then this is a better investment.. Plus.. with more boost and the intake you have.. you'll hear the blowing off noise the stock diverter valve makes since it re-routes it through the intake and you not having the stock intake box you'll hear that.
04-26-2011, 10:10 AM | #16 | |
285
Rep 1,289
04-26-2011, 02:54 PM | #17 |
52
Rep 652
I have the Active Autowerke BOV and LOVE IT. Its really easy to install. The sound is alot of fun. I love the quality of Active Autowerke's parts. Very nice and well built.
-Malcon http://s22.photobucket.com/albums/b3...t=5ac43ce5.mp4 |
04-26-2011, 03:53 PM | #18 | |
WTF was that, Was it your car?
39
Rep 433
06-02-2011, 04:39 PM | #19 |
Rep 28
Looking very nice, glad to see another satisfied customer.
Kenneth Hartley
Active Autowerke | 9940 SW 168 Terrace Miami, Florida 33157 www.activeautowerke.com | Khartley@activeautowerke.com Phone: 305.233.9300 Ext. 232 | Fax: 305-253-8921 Become a Fan on Facebook |
06-03-2011, 12:43 PM | #20 |
33
Rep 494
Our charge pipes are guaranteed not to blow off and come with either the Tial or Synapse blow off valve. All come standard with 2 meth bungs and are hand-fabricated here in the US!
06-03-2011, 09:50 PM | #21 |
31
Rep 409
Drives: 2008 Montego Blue 135i
AA BOV what i got and I love it!
There are no impossible deeds, only incapable men.
Eibach frontsway,BMS JB4,AFE Drop InBerk Street Axleback, H&R SPORT SPRINGS,Active Autowerke DP's ,Active Autowerke BOV,Active Autowerke FMIC , BMWPEDALS.COM, JB SPEED Black Grills,Alpina B3 TCU Flash |
Tags |
woooosh |
