01-14-2011, 12:52 AM | #1 |
52
Rep 428
Procede v5 7DCT shift/safety logic
Hi guys
We've been working on this for a while. One of the problems we noticed when adding more torque to a 7DCT equipped car (either n54 or n55) is that the extra midrange torque can result in clutch slipping during full-throttle automatic downshifts. Depending on clutch/trans oil temp, this slippage can last a second or two where you notice the revs just float high without any vehicle acceleration. If it gets bad enough, an overtemp warning will appear on the dash sending the transmission in to a temporary safety mode were it wont even down/upshift for a few seconds. So we added some logic that detects automatic downshifts and triggers a low boost mode until the clutch is fully engaged. Once engaged firmly, the Procede quickly transitions to full boost. Works like a charm. Downshifts are quick, slip-free and car takes off like a rocket. (Similarly, the Procede will trigger a low power/boost mode if it detects transmission slippage in the middle of a pull.) Below is demo video demo on our n55 DCT. Boost (0-20psi) is represented in the gas level gauge. Car is in regular D mode. For the first two pulls, all I did was stop on the gas and let the Procede+transmission control unit do the rest. On the third run, I tried to confuse the two by going 1/2 throttle to trigger a primary downshift and then quickly full throttle to trigger a secondary downshift before the primary downsnift was complete. Didn't miss a beat. This feature has just been ported over to the n54 firmware but still a bit more testing to go. Anyone in the SF bay area have a n54 DCT car? |
01-14-2011, 01:17 AM | #2 |
394
Rep 3,161
Ive been driving with this new firmware all day. And WOW is it smooth. Vishny guys did it again.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
01-14-2011, 04:13 AM | #5 |
102
Rep 1,552
Drives: '19 M2C | '20 100AE ND2
Will v4 owners get an update?
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait |
01-14-2011, 11:27 AM | #7 | |
52
Rep 428
01-14-2011, 11:55 AM | #8 |
52
Rep 428
Yep.. it happens in either D or DS. Basically anything that builds boost and downshifts at the same time. Remember that the ZF transmission in the n54/n55 aren't rated at the same torque holding capacity as the ZF transmission in the M3. And the n55/n54 naturally make more torque. So without a clutch pack upgrade, it's best to be precautionary. And in this case, precautionary means faster shifting and better performance/drivability.
After running our n55 DCT 135 at the drag strip (a few months back) with drag tires+meth at 17psi, our transmission would overheat and through a fault/limp during launch. So these transmission aren't as abuse proof as the 6MT/6AT. And upgrading clutch packs isn't exactly cheap (labor+install is over $2500). |
01-14-2011, 12:50 PM | #10 | |
141
Rep 571
I currently have the N55 V4 and wanted to know if its worth upgrading to V5. |
01-14-2011, 02:22 PM | #12 |
52
Rep 428
01-14-2011, 04:01 PM | #13 |
52
Rep 428
Here's a funny/sad out-take from two nights ago when i was doing another demo video of this DCT feature. I just happened to run over a grotesque pothole and slice a 2 inch long hole in my front passenger side tire. All captured on video :/
01-14-2011, 05:22 PM | #14 |
102
Rep 1,552
Just downloaded the v5 maps on the link... but before I do anything, just want clarification. Do we just follow the steps of your updating firmware videos and just use the "pro5v002.bin" file? Do we need to do anything with the "1-5 7DCT" etc. files?
Edit: Nevermind, the "1-5 7DCT.pcd" would be for the map update, yes?
01-14-2011, 05:54 PM | #15 | |
342
Rep 1,352
Drives: 2018 M3 CS
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
01-14-2011, 05:54 PM | #16 | |
52
Rep 428
01-14-2011, 07:08 PM | #17 | |
356
Rep 2,080
Ps. Get gas. You're on E. |
01-14-2011, 09:19 PM | #18 |
45
Rep 723
Can anyone refer me to a good technical write up or discussion on how the BMW DCT actually works. All I have been able to find is fluff and generalities. Thanks and sorry if I missed an earlier thread which covered this.
01-14-2011, 10:22 PM | #19 | |
102
Rep 1,552
edit: I think this is actually the transmission built for Porsche's PDK though BMW's DCT is essentially the same principle.
2023 Supra 6MT - Deposit and Wait Last edited by MarkR171; 01-14-2011 at 10:29 PM.. |
01-15-2011, 02:53 AM | #20 |
45
Rep 723
Thanks very cool video
I scrolled through the avaialble videos - I think ours is the ZF 7 dtc 50 - it has its own video. it says max torque input is 520 Nm Last edited by cwg; 01-15-2011 at 03:02 AM.. |
01-15-2011, 03:12 AM | #21 |
102
Rep 1,552
Does ZF make our transmission? Wiki says Getrag does.
01-15-2011, 03:36 AM | #22 | |
45
Rep 723
