01-06-2011, 08:50 AM | #1 |
123
Rep 241
cracked sump
hi
my e90 m3 (the love of my life) has 8000km on the clock. 3 weeks ago i hit a rock in the road at low speed (about 80km/h). i drove on for about 2 km when i noticed smoke from my rear mirror. i immediatly stoped (no warning lights came on) jumped off and noticed oil dripping from sump. called in bmw to tow car. i cracked the corner of sump. a new sump was ordred and put in. does any one know if there would be long term damage to the engine. accorong to the dealer the car runs on a dry sump so there is no damage. is that true? when i had to put the car on the flatbed trailer i started it to get in it N. (its a dct). since i picked up the car i did a 900km road trip.no problems yet. |
01-06-2011, 09:07 AM | #2 |
21
Rep 793
It think you should be fine. The only thing that would have caused engine damage is oil level too low, and you would have gotten a warning message if that had happened.
2017 Porsche 911 Carrera S
2019 Porsche Cayenne Past BMWs: 2015 M3, 2014 550i, 2013 M3 ZCP, 2012 535i, 2011 E90 335i, 2009 E90 M3, 2008 X5, 2006 330i, 2004 330i |
01-06-2011, 09:30 AM | #4 |
817
Rep 7,887
I have cracked a sump before on a E30 and as long as the engine was running the leak was minimal because of the crankcase vacuum.Shut it off and the oil poured out.You will be OK.
01-06-2011, 09:32 AM | #5 |
Captain of the Enterprise
101
Rep 1,424
You're fine. You did the right thing in stopping the car immediately.
2011 1 Series M Coupe VO M3 vs 1M Comparo Review 2011 M3 E90 DCT ZCP (sold) * 2010 335i Sedan (sold) 2005 M3 Convertible (sold) * 2003 325i Sedan (sold) |
01-06-2011, 09:36 AM | #7 | |
236
Rep 3,303
Don't worry, your car is fine, and will be fine for many, many, many more miles Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
01-06-2011, 09:49 AM | #8 |
93
Rep 2,528
If you stopped immediately, not a problem at all.
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
01-06-2011, 10:01 AM | #9 |
123
Rep 241
thanks all you guys for the replys
what is a wet sump? also like to mention that, the car was parked at the dealer for two weeks waiting for the sump to arrive from germany. when i picked up the car and drove for first 10min i got a warning saying the oil is 1ltr short. drove back and the dealer filled up oil. he said when he test drove the day before the oil was fine. how can the oil go from being fine to 1ltr short in 1 day. may be he not being honest with me. by the way i traded in my c63 for this baby. and will never turn back. what a great car to drive. |
01-06-2011, 11:06 AM | #10 |
M-Flight Member
38
Rep 1,085
What he said. I drives me nuts when people that make a living in the car business have no clue about the cars they sell.
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
01-06-2011, 06:20 PM | #11 | |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
No PCV system on the S65..... just two breathers with integral oil seperators that send crankcase vapor up to the plenum. You can see these on the top of each valve cover. Since the throttle plates are downstream of the plenum there is very little vacuum present in the plenum...... Vacuum will only be present in the runners downstream of the throttle plates which is where the M3 takes it's vacuum from for the brake booster. To the OP, as long as you never got a low oil pressure warning you are ok and there will be no damage.
01-07-2011, 01:51 AM | #12 | ||
258
Rep 5,012
You just described a PCV (Positive Crankcase Ventilation) system . That's all there is to it. And yes, we have 2 of those. A lot of those 'valves' let a lot of oil fumes into the intake, and that's not good. An extreme example are the ones in Vettes, where you absolutely need a catch can. When I removed the plenum, didn't feel any oily film right by the TBs, but only had a few thousand miles. Next time I remove it will be a better gauge, but with 2 'valves', we're better off than most. |
01-07-2011, 11:36 AM | #13 |
Sexual Philanthropist
Rep 319
[QUOTE=elp_jc;8635612]
You forgot probably the best feature of a dry sump engine: LOWER CENTER OF GRAVITY . You can place a dry-sump engine lower in the car, with the same ground clearance. It also helps with a lower hood line. [QUOTE] The best feature is the fact that during sustained lateral and horizontal forces the engine will continue to receive its oil supply!
2011 E92 M3 AW/SC DCT, ZCV
bought 11/10 sold 9/11 |
01-07-2011, 03:55 PM | #14 | |
Grease Monkey
295
Rep 2,646
Correction: Although my description of and the difference between a crankcase breather system and a PCV system that as explained below were correct, my information stating that the S65 does not have a PCV system was not. The S65 does indeed use a PCV system in tandem with the oil separators/breathers, I just never noticed the PCV line/check valve when the plenum was off of the car. I apologize for the misinformation. http://www.realoem.com/bmw/showparts...17&hg=11&fg=15 A PCV System is not an open breather type system like we have. A PCV system has a one way check valve in it and uses engine vacuum to provide "POSITIVE" crankcase ventilation. This type of system pulls the crankcase vapours into the intake manifold using manifold vacuum. The reason for the check valve is under full throttle engine vacuum is lost so this check valve closes to maintain vacuum in the crankcase until the throttle position is decreased and the engine starts making vacuum again. The Vacuum is what makes it positive. The only place you have vacuum in a gasoline engine is downstream of the throttle plate(s). Our breathers are vented into the plenum where there is no significant vacuum present (except the extremely minor vacuum of ~1 in Hg or less that is created by the air filter restriction at maximum power) so the system is not a PCV system, but rather a crankcase breather system like a diesel engine uses (diesel engines make no vacuum since they have no throttle plates). The only reason the pre-2010 MY cars had the carbon layer integrated into the air filter was to stop the crankcase vapor from escaping to atmosphere. I am not sure why the US EPA allowed BMW to stop using it but it is a benefit for us 2010 and later M3 owners who get the larger/better flowing Euro air filter on our new cars. Maybe it slipped through the cracks
Last edited by BMRLVR; 01-07-2011 at 08:35 PM.. Reason: Correction in information |
01-07-2011, 04:07 PM | #15 | |
755
Rep 2,736
The true dry sump as in my gt3 and the Mezger engine GT Porsches to date should not be over filled as you state above. There has been well documented damage to this as a direct result of over filling. |
01-08-2011, 10:14 AM | #16 | |
236
Rep 3,303
Cheers, e46e92
01-08-2011, 10:22 AM | #17 | |
236
Rep 3,303
Cheers, e46e92
01-08-2011, 03:13 PM | #18 | |
Grease Monkey
295
Rep 2,646
The reason PCV systems haven't caused issues up until now is that fuel and air is flowing through the inlet ports and the detergents and solvents in gasolines wash the oil residue from ports and inlet valves. Any crankcase vapour that is in the cylinder gets burned in the combustion process and doesn't pose any issues since the volume of vapour is so small compared to the volume of fuel and air. Now with direct injection, many manufacturers seem to be having issues with carbon/oil residue build-up on intake valves and intake ports. Since the injectors inject fuel directly in the cylinders on Direct I injection instead of in the ports on Port Injection there is no longer fuel flowing through the ports and over the valves to wash them clean. It seems Audi and VW is having the biggest (or at least most publicized) issue of all manufacturers with build-up on their FSI engines.
01-09-2011, 09:42 AM | #19 |
258
Rep 5,012
Depends who you ask, but it's between those 2 which one is the 'best' . But both center lower of gravity and uninterrupted oil supply are the main reasons for dry sump.
01-09-2011, 02:18 PM | #20 | |
Grease Monkey
295
Rep 2,646
The S85 V10 runs a dry sump system with 3 oil pumps but the S65 V8 (which was a further development of the S85 albeit with 2 less cylinders) runs a wet sump system which is lighter and is obviously able to handle acceptable g-forces considering the M3's tracking/high performance driving intentions. |
