01-05-2011, 12:49 AM | #1 |
394
Rep 3,161
Whipple
I was curious why we havent seen any whipple super charger kits?
something like this Your Thoughts?
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
01-05-2011, 01:01 AM | #2 |
249
Rep 3,157
I think because it makes crazy boost at low rpm and the engine needs to be built
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
01-05-2011, 01:24 AM | #3 |
44
Rep 436
Awww yes, the Whipple. Nothing but the best. I replaced my oem supercharger on my 03 Cobra and the thing dynoed 590rwhp with only 15-16psi and most bolt ons. That Whipple was good I think, up to like 24psi?
01-05-2011, 09:47 PM | #6 |
76
Rep 2,304
god if whipple could make something for our car like they make for the new GT500...i had a chance to drive one of those and its such a monster with the whipple sc....
01-06-2011, 10:20 AM | #8 |
153
Rep 5,780
One problem is the throttle control. Typically, roots or screw type blowers work on the vacuum side of the throttle. In this case, you may be able to feed the individual TB's, but it would need to bypass quickly when the throttles closed. Or removal of the individual throttles would be needed and a plenum/adapter would be added and then a single throttle on the blower entrance would need to be created. But then the electronics would need to be handled as one of the TPS would be ineffective as well as one throttle stepper motor.
Not impossible but certain more cumbersome as opposed to the centrifugal styles being utilized. |
01-06-2011, 01:33 PM | #9 |
Sexual Philanthropist
Rep 319
And they're heavey. I also went through a ton of sc bearings in the late 90s on my off road race truck as they couldn't handle the heat.
2011 E92 M3 AW/SC DCT, ZCV
bought 11/10 sold 9/11 |
02-22-2011, 01:39 PM | #10 |
394
Rep 3,161
I dont get it, this kit, smog legal, great power and looks well built... $6500 installed. These $12K+ supercharger kits is crazy. BMW tax i guess.
02-22-2011, 02:12 PM | #12 |
286
Rep 6,007
This, and the fact that there are very few SC'd M3's so they won't be making their money of quantity.
02-22-2011, 02:39 PM | #13 |
M-Flight Member
38
Rep 1,085
I had a whipple on my 03 Cobra before I went turbo...loved that thing. I'm not sure how the tranny would hold up with all that low end torque...or how a twin screw blower would hold up at 8300rpm...lots of heat.
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
02-22-2011, 08:20 PM | #14 | |
394
Rep 3,161
How many more Supercharged M3's do you think there would be if there was a sub $8000 kit? Id have one.
02-24-2011, 04:51 AM | #15 | |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I can remember ESS tried to fit their Twinscrew kit onto the E46 and they couldn't get it perfectly right...had something to do with the ITBs I think.
How many LS engines are in use today? Now, compare that to the number of S65 engines in service. You'll think that $13k is cheap.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
02-24-2011, 06:08 AM | #16 |
5234
Rep 10,616
Both AA and Eurosport made twinscrew kits for the E36M3. ESS also made one for the non-M E46 and E39. These used tiny 1.6 and 1.7L blowers. Aftermarket parts for a BMW are lower production and more expensive than for a domestic car, and despite the "universal" platform of OBD2, the ECU themselves are still proprietary and not as many tuners attempt to crack the BMW version. Those who do guard their intellectual property closely and charge a lot for it.
The positive displacement superchargers make full boost at very low rpm. Very high compression engines like the S54, S62, and S65 cannot handle this -- they will detonate. Centrifugal superchargers, that make very little boost at low rpm (or even mid rpm) actually work pretty well to protect the high compression engines. At high rpm, cylinder pressure is lower due to the faster action of the valvetrain and the boost is not as destructive. If you did it, you would have to run very low boost, which might not be worth the cost. The built engine would resolve the compression issue, but at a cost equal to the supercharger kit itself. A thicker headgasket has worked on the S52, but is not a ideal a solution as lower compression pistons. VFE attempted to fit one on an S54 but found insufficient slack in the timing chain for the spacer. They did not play around with modifying the chain. Superchargers drag off the crank, sapping power and adding heat. They still make great power, but not as good as a turbo. On a 5 liter V8 that starts out with torque to spare, it is not a big deal. On a smaller engine, it becomes more of an issue. The turbo, in comparison, adds more torque than the supercharger (either centrifugal or twinscrew) -- once the turbo spools. The twinscrew will always have the low rpm advantage, but the turbo will out-torque it in the midrange -- often substantially. The centrifugal is not even a remote competitor in this rpm range, though it is close or equal in the top 1/4 or maybe even 1/3 of the rpm curve. |
