View Poll Results: Weight of New M3? | |||
3299- | 3 | 3.85% | |
3300-3399 | 6 | 7.69% | |
3400-3499 | 27 | 34.62% | |
3500-3599 | 26 | 33.33% | |
3600-3699 | 10 | 12.82% | |
3700+ | 6 | 7.69% | |
Voters: 78. You may not vote on this poll |
02-13-2007, 09:37 AM | #1 |
15
Rep 471
How much will it weigh?
Everyone has been tossing numbers around as far as weight goes, so let's put it to a vote!
Please vote for what you think it will weigh instead of what you would like it to weigh. We could make a seperate poll for that if there is interest though. -Adam |
02-13-2007, 12:18 PM | #2 |
For the love of ///M3
19
Rep 660
Between 3500 and 3599. That means nada to me, lets get me conversion widget out...
For the Kilo fans... (rounded to nearest whole number) >1496 1497-1542 1542-1587 1588-1632 1633-1678 1678> Actually I guess what I chose would be a good weight to expect.
02-13-2007, 01:55 PM | #3 |
611
Rep 10,407
Good poll
I am surprised by the results and how optimistic folks are. < 3500 is a popular vote. BTW you should have made the votes visible. I like to peek at who votes for what. Can you update that?
02-13-2007, 02:41 PM | #4 |
Rep 15
I do not recall where read this from but I will try to find it but I remember reading that although the new M3 will have a V8, the block itself will not way more than I6 it used to have. My guess is that the m3 will weigh in almost as much as it does now if not a liiiitttle bit less.
02-13-2007, 04:04 PM | #5 |
Rep 369
From what I read sometime ago, the engineers stated that the E9X M3 will not weigh more than the E46 M3.
The E46 M3 weighs 3415 lbs The E60 530i weighs 3472 lbs The E60 550i weighs 3803 lbs The E60 M5 weighs 4012 lbs. I see the engineers pulling this off. |
02-13-2007, 04:31 PM | #6 |
611
Rep 10,407
Source (or fantasy)
Sounds great to me if they can achieve this, however given the weight of the 335i (3570 lb), which is the chassis the M3 is based on, it seems unlikely. The engine may be the same weight or even lighter but bigger brakes, wheels and other stronger components will not help. Do you happen to have a source for this information? If it is true the power to weight will be truly stellar, better than E60 M5 and the same as Corvette C5 (8.0). Again this assumes 426 hp.
02-14-2007, 07:44 AM | #7 | |
26
Rep 580
http://www.m3post.com/forums/showpos...2&postcount=21 |
02-14-2007, 10:06 AM | #8 | |
Rep 369
I can't remember the source where the assertion is made with regards to keeping the weight not more than the E46 M3, but I will send the link if I do find it. With RCF use, I can see them pulling it off. |
02-20-2007, 01:15 PM | #10 | |
1759
Rep 1,668
The amount off HP will be more or less the same ( apr 400 HP minimum- 450HP maximum) in comparison with direct competitors. So the weight will be conclusive. It wouldn`t surprise me that the weight of the new M3 is around that of the E46 M3. If it is too havy, what would be the point off bringing out a new M3? The weight/HP ratio would be worse, now that is not a verry bright thing to do IMO, you come up with a new car, so it must have a better weight/HP ratio than it`s predecessor. |
02-20-2007, 04:47 PM | #11 |
63
Rep 185
In a world where the 5-series weighs less than the 3-series, I am pretty confident that the M3 will weight LESS than the 335i even with a V8 and stronger (heavier) engine components to deal with the power delivery.
02-20-2007, 05:04 PM | #12 |
Moderator
7512
Rep 19,368
I can't imagine the car weighing less than a 335i, but I suppose its possible if they employ weight saving materials. Of course, that will add more to the cost too though.
02-20-2007, 07:11 PM | #13 | |
26
Rep 580
There's that M weight-saving magic at work! |
02-20-2007, 09:20 PM | #14 |
23
Rep 515
Wow I can't believe we are hoping for a 3500lb car..what a joke. Im done with the M3 and GT cars...2007 S2000 for me, followed by boost. 350rwhp, 2700lbs and independent F&R suspension, no McMuffin like the M3.
02-20-2007, 10:03 PM | #15 | |
Moderator
7512
Rep 19,368
It will take some serious measures to keep the M3 under 3600 lbs. |
02-20-2007, 11:01 PM | #16 |
611
Rep 10,407
What happened Pete?
You were such huge fan/die hard supporter. You knew the weight +/- 150 lbs probably from the time of your first post. I saw your enthusiasm fade as knowledge about the price went up. Then you removed your signature "waiting to be me" or whatever. All this along with enthuiastic posts about other cars. Sounds like you have really thrown in the towel. I have to ask - were you ever seriously going to buy one?
02-20-2007, 11:04 PM | #17 | |
611
Rep 10,407
550i: 3803 M5: 4012 +209 lb, ugh. |
02-26-2007, 07:13 PM | #18 |
15
Rep 471
Since we're looking at comparisons. What may be more telling is the weight increase between E39 M5 and E60 M5.
E39 M5 Manual - 3957 lb E60 M5 SMG - 4012 lb Weight Difference = 55 lb Let's assume that SMG vs. manual accounts for 15lbs. that's a 40lb increase on a 3957lb car or 1.011% roughly. Applying that to the E46... E46 M3 Manual - 3415 lb E92 M3 Manual (EST) - 3450 lb Just another take on it, but only time will tell. -Adam PS - I found a few different weights for the E39 M5 and E60 M5, but those two numbers seemed to be the most common so I went with them. |
02-27-2007, 06:11 AM | #19 | |
50
Rep 503
For those who are suggesting the M3 will be heavier than the 335i, bear in mind the 335i is carrying all the cooling and ancillaries of a turbo installation. The E46 M3 only weighed slightly more than a E46 330i Sport, so it would be reasonable for that to be the same with the E92 especially since the BMW quote on record was that the new V8 would be 'lighter' than the S54 straight six (which had an iron block). E92 compared to E46 is around 40lbs heavier, so it just remains to be seen how much standard equipment comes loaded on the E92 M3. Sub-3500lbs should be quite achieveable though. |
02-27-2007, 08:22 AM | #20 | |
20
Rep 1,504
I'll have me a stripper please. Last edited by RandyB; 02-27-2007 at 09:16 AM.. |
02-27-2007, 08:59 AM | #21 | |
11
Rep 184
no sat nav for me please...
02-27-2007, 09:45 AM | #22 | |
50
Rep 503
Since I have my name down against an E92 CSL, I suspect it will come out and with BMW bringing out the 'M2' with a high-revving straight six they might well choose to position the M3 as more of a 'junior' M5/M6. Hopefully that still allows the M3 to be around 3500lbs, but I really doubt it will be any lighter than that. |
