01-01-2011, 10:27 AM | #1 |
892
Rep 9,032
Important Battery replacement info
Saw this on the E90 side. Apparently, you need to program the car when you change the battery or it'll blow up!!
http://www.e90post.com/forums/showthread.php?t=468750 .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
01-01-2011, 10:53 AM | #2 | |
236
Rep 3,303
Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
01-01-2011, 11:16 AM | #3 | |
87
Rep 725
2016 340i M-Sport 6-MT(on order)
2013 335is (still have) 2011.5 M3 ZCP (traded in) |
01-01-2011, 11:36 AM | #4 |
371
Rep 4,167
+2 Ja das is korrekt
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
01-01-2011, 12:10 PM | #5 |
Dntlvet
11
Rep 447
Ok, seriously ...
I like to work on my cars. I just finished the Besian Vanos procedure on my E39. Personally rewarding procedure to diagnose, research & complete. Battery replacement doesn't really need to be a dealership only procedure. Think of the back log of work if every blasted car needed the dealer service dept. |
01-01-2011, 12:13 PM | #6 |
8 tracks of madness
62
Rep 2,735
There is no way you have to "tell the car you're putting in a new battery". None. It defies basic electronics. If you had to reprogram the car for a new battery you'd have to do the same thing any time you disconnected the battery and I've disconnected and removed mine a number of times. What? There's some malicious code in the ECU that tells it that OEM electrons are different than non-OEM electrons and in that case blow the battery up? Give me a fucking break.
Typical M owner superiority complex. It's a car, not rocket science. |
01-01-2011, 12:22 PM | #7 |
Dntlvet
11
Rep 447
So I read over the link and realize this battery replacement is a really big issue. I too have a 2006 330XI and I also replaced the battery "without registering it". Now I got to look further to determine if I need to visit the dealer to reprogram the car.\
Thanks for the post!!!!! |
01-01-2011, 12:25 PM | #8 | |
Dntlvet
11
Rep 447
01-01-2011, 12:39 PM | #9 |
80
Rep 803
I get that if I change battery types or ratings I might need to have the superduper electronics reset to whatever the specs are, as crazy as that actually seems.
However, if I'm replacing the OEM battery with an identical OEM battery of the same ratings, why in the world would this still be necessary? I understand they would tell me it was, but in this instance is it actually?
Objects in mirror are slower than they appear.
01-01-2011, 12:57 PM | #10 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
Registration is not necessary. This is just another example of poor service training and corporate brainwashing so that they can charge you $400-500 for a $150 battery.
01-01-2011, 01:53 PM | #12 |
2288
Rep 13,001
Well, this is slightly more complicated than it seems.
The reason of the battery registration is that BMW uses an "intelligent" alternator variable algorithm that monitors the battery condition (charge, rate of discharge, etc) and simply shuts on and off depending on this condition. That reduces engine load thus increasing efficiency -power and economy. When you replace the OEM battery you in fact are not telling that algorithm that the battery adapted values stored so far no longer apply -they were collected over a period of time from the old battery condition. So the "old" algorithm continues to do its job although the variable values changed. This could either under/over charge your new battery just because its charging/discharging characteristics not necessarily will have to match the old battery's. So the sole purpose of the battery registration is to update that algorithm to the new values, by starting over the collection of adaptive values from the new battery so it is charged/discharged exactly -or close to it- to its most particular efficient capacity. Sometimes it seems that the battery registration was not necessary when there are no problems with the new battery install. That's most probably due to the new battery condition pretty much matching the current alternator algorithm and that you are not asking too much from that battery... in other words, just luck. Sometimes it really messes up the new battery after awhile as the current algorithm keeps the battery under/over its real capacity. My suggestion is simple... try to find an Autologic shop and get the new battery registered just in case. It takes less than 5 minutes -just press "Register" in the screen and that's it- and most probably the guy there will do it for free if you ask nicely (I did that). In the worst case is half an hour job or even less. The dealer as always is making this like a big job which it isn't. By the way, I'm using a Sears Die Hard battery instead of OEM. |
Merlin_83473.50 |
01-01-2011, 02:41 PM | #13 |
258
Rep 5,012
Using the same battery type and equal or higher rating should pose absolutely no problems, just like your Die Hard. And I'm pretty sure all such data gets erased with battery disconnection anyway. Maybe if I was switching to those lightweight ones I'd look into it, but as it was mentoned, there're no BMW-coded electrons that I know about . Same with light bulbs and other parts; just use equivalent specs and car will run fine. But you'll still have to 'initialize' the auto feature in windows and sunroof.
01-01-2011, 03:46 PM | #14 | |
2288
Rep 13,001
Again, you can assume or you just don't. I know for sure that before registering my new battery I used to have "increased battery discharge" errors often as soon as 5-10 minutes after turning my radio on with the car off, something that I never had with the OEM battery before it started acting up just because I like to play loud music with the car off -which kills my batteries in a couple of years. The new battery was fully charged and there was no problem with it or with the charging at that particular moment according to Sears. After registration the error disappeared. |
01-01-2011, 05:18 PM | #15 | |
Butters
Rep 88
01-01-2011, 11:49 PM | #16 | |
892
Rep 9,032
Do we have AGM batteries? I'm pretty sure the start/stop cars have them. I would imagine it would be bad to replace an AGM one with a non-AGM battery.
01-02-2011, 01:16 AM | #17 | |
126
Rep 4,144
Yes, I'm bored tonight. Cheers.
2017 F80 YMB.
01-02-2011, 06:29 PM | #18 |
14
Rep 263
over engineered crap. Also BMW should give away their tools for free or for a nominal cost. Someone could probably go after them over that legally, but I know no one will so *shrug*.
Imagine youu could only by Exxon Mobil gasoline and you had to recode the car for new gas. Of course, there are clear laws against this...
2011 E90 M3 ZP2 ZCV ZCW ZCP (for teh fastAr)
2005 LGT, AVO380 Turbo, a zillion other mods, ECU tuning by me. |
01-02-2011, 07:01 PM | #19 |
98
Rep 525
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
Interesting thread. So would using a trickle charger (such as the Battery Tender) be bad?
What if the battery goes close to dead one day? Can you simply charge it up using a battery charger? Any issues with either?
Drives: '11.5 Interlagos Blue E92 M3 Comp, '21 F95 X5 M Comp DIYs: Enable Rear Fog | Easy Side Gill Replacement | Front Grill Replacement |
01-02-2011, 08:17 PM | #20 |
892
Rep 9,032
If a lead acid battery is drained, even once, it's never the same. It's meant to be slightly drained and recharged regularly.
The AGM/Deep Cycle/marine battery's can be drained and recharged over and over again.
01-02-2011, 08:53 PM | #21 | ||
BimmerPost Supporting Vendor
8209
Rep 18,823
Drives: BMW
More info can be found in this post: http://www.e90post.com/forums/showpo...5&postcount=24 Quote:
http://www.fronius.com/cps/rde/xchg/...1_ENG_HTML.htm Most trickle chargers are fine.
01-02-2011, 09:23 PM | #22 |
98
Rep 525
Thanks for the replies on my questions pertaining to charging however what I was really after was what effects will that have on the adaptive values being stored? Thanks.
