12-24-2010, 11:00 PM | #1 |
200
Rep 2,799
Question about exhaust rasp
This could be a really stupid question but I have 2.5 inch catless downpipes leading to my stock midpipes with the cats removed, a resonator delete, and the stock exhaust. There is an extremely annoying rasp between 1700-2000 rpms when the engine is under a load.
My question is if I put the resonator back in, do you think the rasp will disappear?
thanks to MGallop |
12-25-2010, 12:22 AM | #2 |
734
Rep 3,274
Quoting Berk Tech:
"The exhaust system as a whole will sound a lot smoother if you have resonated midpipes vs. non-resonated. The resonators mellow out the system for for a smoother overall tone." if the overall smoothness of the tone is what you're talking about with the rasp, then yes they definitely help
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
12-25-2010, 05:18 PM | #3 | |
200
Rep 2,799
thanks to MGallop |
12-25-2010, 06:35 PM | #4 |
734
Rep 3,274
looking forward to seeing / hearing it!!
12-25-2010, 08:39 PM | #5 |
85
Rep 1,609
The rasp that you desribed is drone. The resonator only minimize the drone but cannot completely get ride of it. Almost all after market exhaust has this problem and just a matter of degree. I guess this is the penalty that you paid for louder exhaust.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
12-27-2010, 03:45 PM | #6 |
200
Rep 2,799
I put the resonator in today and walah, the rasp is gone. the car sounds mean completely catless with the stock muffler, i'll put up a video a little later
thanks to MGallop |
12-27-2010, 09:05 PM | #7 | |
734
Rep 3,274
can't wait to hear it!
12-27-2010, 11:16 PM | #8 | |
127
Rep 4,732
12-28-2010, 09:19 PM | #10 |
200
Rep 2,799
You can't have a catless car in cali hahah but i'll have to change it up before emissions, but the initial cost of the resonator delete for me was $30 from a local mufflershop, and it was $40 to put back on. Pretty cheap
thanks to MGallop |
03-24-2011, 12:41 PM | #11 |
200
Rep 2,799
found the source of my rasp, I had about two exhaust leaks in my midpipes due to shitty welding, I just put on my agency power midpipes that I ordered, and now the car purrs so perfectly
thanks to MGallop |
07-24-2015, 09:22 PM | #12 | |
124
Rep 546
I had a similar setup as you and mine rasped like crazy at lower rpms AR DP + secondary cat delete + PE Y-Pipe + PE Muffler Recently put in vibrant resonators and took away all the rasp Kinda too quiet now =/ (Unless i got use to the loud rasp lol) so if its really exhaust leak I might cut them again and check welds |
