12-24-2010, 09:48 AM | #1 |
86
Rep 1,430
Limp mode
Hey guys will putting an axle back exhaust on and cat less mid pipes throw my car into limp mode without a tune? Ordered the axle back exhaust and the deal was too good too pass up with the mid pipes included. I plan on getting a tune as soon as spring rolls around where I'll drive my car a lot more (Pennsylvania winter). I just don't know if it's okay to put the mid pipes on now? Thanks!!
e92///M3
TT Lamborghini Gallardo INSTAGRAM: CHRISTIANPERLES Lamborghini-Talk.com: Christian. |
12-24-2010, 01:52 PM | #4 |
86
Rep 1,430
Exhaust
Im out near Hershey...what are they charging?
e92///M3
12-24-2010, 02:52 PM | #5 |
44
Rep 687
Holiday pricing $750 flash. Its in the regional section.
http://www.m3post.com/forums/showthread.php?t=467664
2008 Alpine White E92 ///M3
12-24-2010, 03:41 PM | #7 |
44
Rep 687
If you run a catless x-pipe then you need a tune.
12-24-2010, 06:11 PM | #8 |
86
Rep 1,430
Its cat less mid pipes... http://www.agency-power.com/catalog/...8-p-48052.html
12-25-2010, 12:57 AM | #9 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
I think the question is if youhave to get a tune or otherwise the car will be inopperable.
Others can chime in, but I believe without a tune you'll just see a check engine light (cel). Otherwise car runs ok. Have in order to take full advantage of the xpipe and turn off the cel you'll need a tune. Someone else can confirm.
Current Rides:
2022 ///M8 GC Comp Much enjoyed: 2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i |
12-25-2010, 05:03 AM | #10 |
yodog
197
Rep 5,025
Your car will not go into limp mode from a catless x-pipe. What you will notice is a huge torque dip in the low rpms which can be greatly helped by a tune (plus you'll receive a huge bump in power everywhere).
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
12-25-2010, 10:40 AM | #11 |
97
Rep 3,246
will drive just fine, had the akra evo, cel came on, car ran great, but just have this light mocking you. got the tune and the car runs awesome now, no light, just the road ahead to devour.... enjoy
mods: track ready stuff
12-25-2010, 12:56 PM | #12 |
86
Rep 1,430
Great glad to hear that! I got these O2 sensor spacers I guess you can call them, they move the sensors back which trick the system so my CEL wont come on. I plan on getting my car tuned but like i said in one of my previous threads is Im still in college so Im basically doing everything on a budget. Thanks for all your help guess...ps MRHarris your car convinced me into getting an alpine white e92!!!!!!! all your mods are sick keep up the good work on the car
12-26-2010, 03:18 PM | #13 |
62
Rep 764
If you are getting ONLY an axleback exhaust, you will not have any problem at all since all emissions related "things" are by the primary cats (O2 sensors). Even the secondary cats can be removed without affecting anything.
When you say "mid pipes" are you speaking of the connecting pipes that connect to the OEM x-pipe right after the secondary cats? Or are you speaking of an actual x-pipe? For the former, connecting pipes will not affect anything and you will not NEED a tune, as nothing emissions related is touched. For the latter, it depends on which type of x-pipe you are going with. If the primary cats are eliminated, then you will need some type of tune to get rid of your CEL. It won't go into limp mode though, so you're fine with that.
12-26-2010, 03:25 PM | #14 | |
I like cars
329
Rep 5,052
12-26-2010, 03:52 PM | #15 | |
86
Rep 1,430
exhaust
01-04-2011, 06:18 PM | #16 | |
Rep 1
Where to get O2 sensor spacers?
01-04-2011, 08:40 PM | #17 | |
I like cars
329
Rep 5,052
01-06-2011, 05:41 PM | #19 | ||
86
Rep 1,430
e92///M3
