KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
12-22-2010, 01:05 AM | #1 |
394
Rep 1,519
How about 295 rears w Dinan stage III?
Just read in the thread below that 295/30-19 rear PS2s on KW v3 suspension rub a bit on bumps. Does anyone have this size rear tire on a 19x10.5 et20 wheel with a Dinan stage III suspension? Any rubbing? I'm assuming the Dinan's drop is a bit less than the KW's...
12-22-2010, 02:57 AM | #3 |
58
Rep 1,084
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
Your wheel offset is a bit agressive you will probably rub! I run BBS 19x10.5 ET25 on KW clubsports with Yokohama AD08 tires and had to trim some plastic from the outer rear inside edge of the fender and have no more issues!!! This includes ops checking my suspension on the Nurburgring with zero rubbing on 295 rears. When I run on the track my Camber is very agressive Negative 3.6 up front and negative 2.3 on the rear.
