12-17-2010, 04:51 AM | #1 |
2820
Rep 7,640
JB3 caution
For those of you who are running the JB3 on the higher maps (7 and UP ) beware..
I have heard from a friend who has been running map7 constantly that he has thrown a cel code, limp mode.. Engine check light came up with"Engine Failure" warning with reduced engine power. For those with a BT tool the code thrown was- 30FE:/30FF: 30FE Exhaust fume turbo charger,high pressure side. EXPLANATION: ECU boost over ECU target. FIX:Generally related to tuning. It may be a sign to reduce boost level or disable LAGFIX. Also can be caused by boost leaks, leaky DV's, broken vacuum lines etc. They replaced the sensor and now car good as new.. Last edited by Zuzu; 12-17-2010 at 05:24 PM.. |
12-17-2010, 07:49 AM | #2 |
20
Rep 178
12-17-2010, 09:40 AM | #3 |
Lord Captain Commander
110
Rep 3,093
Do not run map 7 on 98RON gas! Terry recommends max map5 on US 93 which is equivalent to our 98RON.
Also, this is where the advantage of PROcede comes in. It won't run the boost if the car can't handle it.
E82 135i M-sport: SGM/6MT/Black |
12-17-2010, 10:16 AM | #4 |
AKA HISSMAN
34
Rep 888
What mods did he have?
(FBO) Cobb Stage 2+, AR Downpipes, Injen DCI, AA (Sport) FMIC, ER Chargepipe/Synapse BOV, Carbon fiber bits and Breyton GTS-R Wheels.
12-17-2010, 05:28 PM | #5 | |
2820
Rep 7,640
Just a code ID post.. Map7 is safe to run on our 98RON, as he has been running Map7 for the past 18months with no probs until now. |
12-19-2010, 12:06 AM | #7 | |
86
Rep 1,993
Pretty common code if the tune is too harsh for the mods or conditions encountered.
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
12-19-2010, 02:07 AM | #8 |
44
Rep 1,359
I agree its common and it is not related to only one tune because I have had it. I cleared the code and have not yet been back to BMW as the car seems to be running fine for now and I am due for a service soon anyway.
12-19-2010, 02:47 AM | #9 |
2820
Rep 7,640
The first time this code was thrown, it was cleared with the BT tool and car was fine.. Four weeks later, same code came up, but this time, 20% in power reduction noticed at WOT, hence off to the dealer for inspection and replacement of faulty turbo pressure sensor.
12-19-2010, 03:20 AM | #10 |
44
Rep 1,359
apart from the jb3 is the car stock? hopefully mine does not come back however I think it will unless I either decrease the boost level or get some supporting mods.
12-19-2010, 03:32 AM | #11 |
2820
Rep 7,640
