12-11-2010, 09:35 PM | #1 |
28
Rep 1,035
With the new 135i M running the M3 diff, anyone know what other parts are req'd?
Is the M3 rear subframe required? Rear axles? I read in Roundel that the 135i M (or whatever they're calling it) is utilizing the M3 bearing housings, but I'm just wondering what else you need to run the OEM M3 diff.
12-12-2010, 12:50 PM | #5 |
140
Rep 2,234
Wonder if it will be priced competitively. I will be down if that's the case
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
12-12-2010, 01:33 PM | #6 |
124
Rep 1,362
12-12-2010, 03:46 PM | #7 |
140
Rep 2,234
Isn't the wavetrac going for $1100 800 for the kit? Add another 4-6 hours of labor you would be looking at $2500. Isn't this what a wavetrac installed run?
12-13-2010, 02:08 PM | #8 | |
28
Rep 1,035
12-14-2010, 02:40 AM | #9 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Alternatively, you can turn it in for a $800 credit. However, we are thinking to make the credit $1000 so we can sell more units and offer Quaife low mileage DCT final drives. |
12-14-2010, 06:56 AM | #10 |
159
Rep 5,689
Man I really want a lsd but, like the others, its just so much money...
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
12-14-2010, 12:09 PM | #12 |
3847
Rep 54,376
Drives: F80 M3
12-17-2010, 09:07 PM | #13 |
323
Rep 1,804
I might be delerious, but if the BMW Performance LSD is under $1500 I'm onboard.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
12-18-2010, 01:45 AM | #14 | |
223
Rep 1,565
From the spy shots I've seen it looks like the 1M uses the complete M3 rear end. Here's a cost breakdown from what I can see: $1800 - M3 diff $800 - L/R axles $700 - M3 driveshaft which you will have to cut in half $500 - labor for custom franken-shaft ~$3800 before labor to actually bolt everything in. So don't let the lower cost of the diff seduce you just yet since there's $2000 in "support" parts you need to put that in your car. |
12-18-2010, 05:37 PM | #15 | |
124
Rep 1,362
12-18-2010, 07:56 PM | #16 | |
34
Rep 522
rear diff has nothing to do with the "type" of engine, it works the same in ANY engine configuration........ |
12-19-2010, 02:54 AM | #17 | |
223
Rep 1,565
Just speculating on from what I can see from the spy photos. It looks like the 1M uses the M3 subframe, and from the pics the M3 diff case. Which leads me to deduce the M3 diff as well. Again, all speculation on my part but that's what I can see from the photos. I feel like we're scientists looking at pictures from Mars and trying to figure out what we're looking at. |
12-19-2010, 08:25 AM | #18 | |
124
Rep 1,362
So my theory is that because the new 1M has the N54 with the M3 diff then the drive shaft should be the same length between the 1M and 135i. Meaning we might not need the frankenshaft as suggested by Berk. |
01-03-2011, 05:11 AM | #19 |
38
Rep 565
I have done the M3 diff mod on my car and as Berk has commented you will need to fabricate a shaft or mate the rear M3 shaft to the 135/335 front portion after the universal joint. In the case of the 135i the shaft will obviously be available for the manuals and the auto will need some modification as its slightly longer. The diff and its housing bolts straight in and you will need to source M3 driveshafts although I have suspicion that the driveshafts might not fit as the 1 series has a smaller track than the 3. Best bet is a Quaife system or wait till the 1 series M is released and compare part numbers.
I know a competing tuner has attempted the mod on the 1 series locally and it seems without success as there was no news after the attempt.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
01-04-2011, 12:12 AM | #21 |
Rep 44
ok this is what i dont get .. y do most of you guys always fall back onto the oem bmw stuff?? if the m3 diff bolts right in y doesnt someone look outside the box and call dss and other places here in the usa to have custom axles made that will in the end be stronger .... the cost of a custom drive shaft is nothing 1500 for carbon fiber and like 500 for steel..
axles arent more the a grand from dss as i have already called ..
WHEN LIFE SLOWS DOWN... DOWN SHIFT !!
01-05-2011, 12:57 AM | #22 |
23
Rep 194
Just to make sure people know that there are more options out there for the current 135i.
We have a custom LSD from Performance Gearing (Jim Blanton)....who has been building custom race diffs for all BMWs for years...we've been using his stuff in our race cars for over 11 years. We have the larger rear diff case, and the 3:46 rear diff ratio from the automatic version, with custom LSD ratios and ramp rates....and the price is reasonable to us ($2450 from us or from Performance Gearing). We drive our unit on the road on a daily basis, and ran this unit in our BRracing BMW E82 135i project car at the Global Tuner Grand Prix with great success. So, you can get all the same type of features and more now, and for a lesser price than the Quaiffe or the new 1M / M3 version. Bruce BRracing |
