BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
EXXEL Distributions
      12-08-2010, 01:25 AM   #1
hhlou520
slow in fast out
Drives: 2005 Dodge Ram 1500
2010 Balance Sheet
Debit:
2 venues
3 track layouts
2 organizations
7 events
13 track days
20 hours track time
1500 track miles
Credit:
3 sets of front tires
2 sets of rear tires
5 sets of front brake pads
4 sets of rear brake pads
180 gallons of on track gas
1 windshield
1 rear brake disc
1 engine under tray
8 hotel nights
2200 travel miles
...in other words, what it took me to get some valuable seat time while having some fun.
      12-08-2010, 02:26 AM   #2
biglare
Bulldog
biglare's Avatar
482
Drives: BMW & Porsche
Very cool evaluation of what it takes to run these cars at the track!
Looking forward to your other track mods and updates!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      12-08-2010, 08:38 AM   #3
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
I don't understand how you use credit and debit here, but the message sounds about right. I am surprised you used more front tires than rear though.
      12-08-2010, 09:08 AM   #4
008
Sexual Philanthropist
008's Avatar
Drives: 2011 E92 M3
You used 5 sets of front pads and 4 sets of rears in 20 hours? Which pad were you using? Was this all with the AP BBK? Are you running a duct? Street tires or Rs? TNA
2011 E92 M3 AW/SC DCT, ZCV
bought 11/10 sold 9/11
      12-08-2010, 09:47 AM   #5
Gearhead999s
Gearhead999s's Avatar
817
Drives: RR Velar R=Dynamic M2C R1200GS
I am also surprised about the use of more front tires than rear.I wear the rears at about twice the rate as I do fronts and I run street alignment settings.I will get about 10 hours out of an R compound tire like the RA1 if I rotate it front to rear to equalize the wear.My NT'05's lasted 8 full days which is about 20 hours of use.On a fast track like Mosport I was only a couple of tenths off what I turned on a R compound tire with twice the life.
      12-08-2010, 09:36 PM   #6
hhlou520
slow in fast out
Front tire wear vs. rear tire wear -> track layout (TWS, MSR Cresson), driving technique (I'm not smooth enough...), incorrect tire pressure (no Longacre before October), track surface heat (TX summers) might all have to do with it.
Street tires only, so far. Started out with the OEM Conti 3's, then replaced the fronts with Conti 2's, then switched over to Yokohama ADVAN Sports. Next up is a set of Hankook Ventus R-S3's.
HAWK HP+ pads with the stock set up. Mintex Xtreme Motorsport, then HAWK HPS, then Mintex F3R pads with the APs. The Mintex F3R's are here to stay - they are simply amazing.
No ducts. Yet.
      12-09-2010, 02:28 PM   #7
008
008's Avatar
Drives: 2011 E92 M3
Ah, I see. Yeah, you'll definitely burn through street pads quickly. Do you run the F3Rs on the street as well? try a set of PFC 01s on the track sometime.
      12-09-2010, 02:39 PM   #8
Gearhead999s
817
No ducts. Yet.
Are you still running stock sizing?
      12-09-2010, 03:08 PM   #9
dnvrdrvr
Captain Obvious
dnvrdrvr's Avatar
90
Drives: 2018 VW GTI SE
This thread made me laugh out loud. I didn't have the foresight to keep track of nearly this much info (gallons of on-track gas? ).
+1, I had about 15 track days as well this summer on one set of PFC 01s (front and rear). There are 7-8mm left, enough for a few winter lapping days if I take it easy... Pricey, but TOTALLY worth it imho.
Like you, I wore through the front tires more quickly than rears (also street tires, RE-11s). Swapped them left and right to help mitigate the track layout effects. Are you running any camber? That helped me some... but I need more than the -2.5 up front I was had at the end of Oct. -2.0 in the rear was perfect.
Just a girl and her 863 ponies...
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar)
///M-Flight
      12-09-2010, 04:22 PM   #10
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
15 days???? F**k me! I got 5-6 and dumped a set when the backing plate warped and cracked the pad material. There was another day left in them I reckon based on the pad thickness and rate of wear. Awesome pad though! Going to try the pagids after hawk dtc-70s (), and then choose my brand!
      12-09-2010, 05:19 PM   #11
dnvrdrvr
Captain Obvious
dnvrdrvr's Avatar
90
Yep, between NASA weekends, various regional BMW CCA DEs and open lapping days... well, I was driving every track surface that was open when I was available. And to OP's point, it sure was fun
Next year: track wheels/tires + BBK (to make it easier to swap pads out) and I'll do it again. But better!
hhlou520, our NASA regional director & his wife will be splitting time between TX and the rocky mtn regions. I've been wondering if they'll do any 'mixers' between the two...?
///M-Flight
      12-10-2010, 06:44 AM   #12
mastek
e36s54, e70x5d
mastek's Avatar
151
Drives: slow
Don't get those Hankooks ... get a set of BFG R1 tires
The F3R are great for medium track duty ... after that its PFC01 or Cobalt XR1
      12-14-2010, 12:25 AM   #13
hhlou520
slow in fast out
...try a set of PFC 01s on the track sometime...
First I need to find a vendor to source the right size PFC's from. So far I've been working with Ryan from Stillen/AP Racing and he's helped me a lot to identify good pads for my braking needs.
...Are you running any camber? That helped me some... but I need more than the -2.5 up front I was had at the end of Oct. -2.0 in the rear was perfect...
-2.5 F & -1.3 R (I think...) I've been told before to get more aggressive with it/them.
...hhlou520, our NASA regional director & his wife will be splitting time between TX and the rocky mtn regions. I've been wondering if they'll do any 'mixers' between the two...?
"Son, I see towing, lots of towing in the cards..."
I figure I'll be ready for these ultimate tire and pad picks early next year (I hope I'll be ready...)
      12-16-2010, 10:49 AM   #14
dnvrdrvr
Captain Obvious
dnvrdrvr's Avatar
90
Hmm, the only vendor to carry PFC 01s for our car that I'm aware of is Bimmerworld. I'd be interested to hear what you end up with as BBK is on my short list for next season & have no idea how pads work into that equation. I would guess the pads would be different depending on 4- or 6-pot configurations to accomodate the mechanics of the caliper but I really have no idea...
I know this depends somewhat (okay, largely!) on the tracks you're running. I'm planning to start mine at -3.0 F and leave the rear at -2.0 next season. -2.5 F was better than -2.0. Still not enough though and I burned the markers off the corners first day out on new fronts.
You'll be ready. I'm already itchy for a day back out there. Lack of snow here isn't helping.
///M-Flight
      12-16-2010, 10:57 AM   #15
008
008's Avatar
Drives: 2011 E92 M3
Try Porterfiel-brakes.com. If you now your pad part number just send them an email. They have PFC01 for the stock calipers and carry a lot of other pad materials for bbks.
m3post
