BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > New and Preowned M3 Pricing, Ordering, Tracking / European Delivery / Dealer Reviews
Mporium BMW
      12-02-2010, 09:44 AM   #1
boarderman23
11
Drives: 2011 e93 M3
MSDs - Is This Accurate and Doable?
From some information I came across on the internet, it appears I can save almost $2600 by putting the MSDs down on my 2011 e93 lease, totaling 8 security deposits/$6000.
The MSRP of the vehicle is $80,675 and the current money factor for the lease is 0.00130. Since each security deposit drops the MF by .00007, that would drop the total MF to 0.00074 - essentially lowering my total lease cost almost $2,600 over the 36 months.
I read that MSDs are returned in an event of a totaled vehicle or anything like that. I also read that you get the amount back in full when returning the vehicle as long as there isn't excessive wear (which even if there was and I didn't have any security deposits, I would have to pay for that anyways).
Can anyone confirm that I can in fact do this? Is there anything I am missing? Any input would be greatly appreciated, thanks!
      12-02-2010, 10:52 AM   #2
comebackid
comebackid's Avatar
290
Drives: 2023 M4 Competiton, 2021 X7
What you said is all true. If you want to lower the monthly payment, MSD is the way to go, because you get it back no matter what, End of lease, car totaled, etc.
Although I did read on another post that the MSD is calculated by nearest $50 increment averaged up. In other words, if your payment is $560, then each MSD is $600. Not sure if that's the case.
By the way. Which dealer did you go to? Are you in metro NYC? I have a hook up at BMY of Tenafly in NJ. PM me if you're interested.
Good luck.
      12-02-2010, 11:16 AM   #3
geneatals
Ninja
geneatals's Avatar
390
Drives: 2019 530e
Good luck.
correct...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i
      12-02-2010, 11:52 AM   #4
boarderman23
11
Drives: 2011 e93 M3
Good luck.
Thanks, my quote right now has payments of around $790 including tax...so looks like MSDs would be $6400.
Also, PM'd you about dealer info.
      12-02-2010, 12:03 PM   #5
boarderman23
11
Drives: 2011 e93 M3
If putting down the max 8 security deposits and lowering the money factor to .00074, wouldn't that bump the MSD amount down as well? Assuming the decrease in money factor equals a savings of roughly $2,600 or $72 per month (that would bump my payment from 790 to 718, which would then equal a 750 deposit rather than 800). Or are the security deposits based on the original rate?
Sorry, that may not even make sense...
      12-02-2010, 03:26 PM   #6
bmwboi
Drives: X5
According to my dealer, the maximum amount of security deposits you can give is 7, which would lower the MF by .00049.
      12-03-2010, 12:12 AM   #7
EuroCarsOnline
23
Drives: BMW Individual M3 Sedan
+1. Assuming you are qualified previous BMW FS. If not, you are required to put down one deposit that cannot be used for MSD. The remaining six can be used to reduce the money factor by .00042.
Regards,
David
Ultimate Buying Power
BMWDavid@me.com
www.bmweco.com 202-262-2900
Call Joy for Vehicle Status 443-883-6925
      12-03-2010, 12:22 AM   #8
boarderman23
11
Drives: 2011 e93 M3
Thanks for confirming, that should save a bit of money over the course of the lease.
      12-03-2010, 04:02 PM   #9
Ty Vil
31
Drives: ///M4
Regards,
David
That's not right.
If you're required to put down one security deposit you can still do an additional 7 and get the 49 point rate reduction.
      12-03-2010, 06:13 PM   #10
boarderman23
11
Drives: 2011 e93 M3
So if you're not required to put one down, can you use a total of 8 to lower the rate? Or is 7 still the max reduction?
      12-03-2010, 08:09 PM   #11
Ty Vil
31
Drives: ///M4
7 and 49 basis points is the max reduction.
m3post
