12-02-2010, 09:49 AM | #2 |
38
Rep 815
Overkill? Wimmer RS Tunes Porsche GT2 RS to 703HP
With 620-horsepower on tap from the twin-tubo'd boxer engine for a 0-100km/h (62mph) sprint time of just 3.5 seconds and top speed of 330 km/h (205 mph), we'd argue Porsche's 911 GT2 RS is lighting quick. However, German tuning house Wimmer RS has a mind of its own when it comes to performance even if we're talking about a sports car that will be produced in a limited run of just 500 units.
The tuner's upgrades are concentrated on the 911 GT2 RS' 3.6-liter six-cylinder boxer which benefits from a remapped engine controller, optimized turbochargers, a sport air-filter, new air-intake and a valve-controlled sport exhaust system along with sport catalysts. These modifications bump output from 620 to 703-horsepower, while peak torque rises from 700Nm to an even more impressive 810Nm or 597.5 pound-feet. According to Wimmer RS, the powered-up 911 GT2 RS can now complete the sprint from 0 to 100km/h in 3.3 seconds and pass the 200 km/h mark after just 9.5 seconds (stock model: 9.8 seconds), while continuing up to a top speed of 356 km/h or 221.2 mph." |
12-02-2010, 01:47 PM | #4 |
817
Rep 7,887
12-02-2010, 02:41 PM | #5 |
38
Rep 815
This might work....
Below is custom code that allows users to embed YouTube videos. This is not favoritism: this trick can easily be adapted for other forms of embeddable content. Usually, websites like YouTube give us boilerplate code that you can insert into your documents. YouTube's code goes like this: <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/AyPzM5WK8ys" /> <param name="wmode" value="transparent" /> <embed src="http://www.youtube.com/v/AyPzM5WK8ys" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" /> </object> There are two things to note about this code: 1.<embed> is not recognized by W3C, so if you want standards-compliant code, you'll have to get rid of it. 2.The code is exactly the same for all instances, except for the identifier AyPzM5WK8ys which tells us which movie file to retrieve. What point 2 means is that if we have code like <span class="youtube-embed">AyPzM5WK8ys</span> your application can reconstruct the full object from this small snippet that passes through HTML Purifier unharmed. Show me the code! And the corresponding usage: <?php $config->set('Filter.YouTube', true); ?> |
12-02-2010, 10:23 PM | #8 |
86
Rep 2,266
Use the vB Youtube button..and only paste the ending part of the video in it.. that seems to be how everyone is doing it.
e.g. [ U2B ]L4NZSHVfobE[ /U2B ] with spaces removed
Cheers
Ben |
