11-29-2010, 09:36 PM | #1 |
24
Rep 109
Any chance of BOV Kit for N55?
I understand that the N55 is having MAF unlike the N54(MAP). Any experts that can enlighten me whether there is a possibility that there will be a BOV kit for N55?
Thanks. |
11-30-2010, 11:12 PM | #3 |
51
Rep 281
Drives: F30 MSport 328i
I think Synapse already has a BOV out for the N55 I'll try to find a link
Current: 2014 F30 M-Sport 328i
Retired: 2008 E92 335i (GiAC Stage 2), 2008 E82 135i (Cobb Stage 1), 2007 E90 328i |
11-30-2010, 11:13 PM | #4 |
51
Rep 281
12-01-2010, 02:19 AM | #5 |
52
Rep 524
Drives: 2011 135i 6M, AW, CR, MSPORT
Id like to see this installed on an N55, someone jump in and give us a peek...
12-03-2010, 06:11 AM | #7 | |
24
Rep 109
Thanks for the link. Hopefully this is the kit for the N55. However, I am alittle sceptical because from the threads that I have read so far about BOV, it seems like the design is totally different from the N54 and the MAF is really restricting the use of BOV(I hope this is not true). Maybe someone can correct me? Thanks. |
12-04-2010, 08:44 AM | #9 |
AKA HISSMAN
34
Rep 888
Is the MAF sensor upstream or downstream of where the BOV would be?
(FBO) Cobb Stage 2+, AR Downpipes, Injen DCI, AA (Sport) FMIC, ER Chargepipe/Synapse BOV, Carbon fiber bits and Breyton GTS-R Wheels.
12-04-2010, 09:30 AM | #10 |
34
Rep 522
The maf is in the beginning of the intake
System and the stock DV is atached to the turbo compressor housing witch is behind the water pump so no dice for now.... |
12-04-2010, 10:44 AM | #11 |
124
Rep 1,362
The only wat to run a BOV on the N55 is to have a tune that will compensate for the loss of air because it has a MAF sensor, just like on evo's n STi's. If you just throw a BOV on it your car will run crappy.
12-04-2010, 11:15 AM | #12 | |
52
Rep 524
Not to sure about the N55, ill have to re look, but most engines come factory equipped with a recirculation valve that does the same thing as a BOV so there shouldn't be any problem with adding a bov to the car in general all you are doing is replacing the stock recirc unit with an dump to atmosphere. |
12-04-2010, 11:51 AM | #13 | |
AKA HISSMAN
34
Rep 888
Wrong on this one. Did you catalog and check A/F ratios between shifts? And a recirc system or DV does not do the same thing as a BOV. it is possible that the cars you ran a BOV on had the MAF downstream. If that is the case then there would be no issue.
12-04-2010, 02:30 PM | #14 | ||
124
Rep 1,362
If your MAF is before DV it accounts for that air and that's why it's recirculated, but if it's after the DV then it's not accounted for because it's vented before it hit's the MAF only then is it safe to run a BOV and according to Black E the N55's before the DV. Not sure which cars you had you had daniel you probably had one with the MAF after the DV. |
12-04-2010, 03:50 PM | #17 | |
52
Rep 524
http://en.wikipedia.org/wiki/Blowoff_valve And the cars I have worked on all had the MAF on the intake side... Also used stand alone engine managements, so that is more than likely the reason it works. Last edited by Daniel135i; 12-04-2010 at 03:56 PM.. |
12-04-2010, 04:34 PM | #18 | |
124
Rep 1,362
12-05-2010, 03:35 AM | #20 |
24
Rep 109
Will the n55 accomodate a change of the DV alone since it is built into the compressor housing? Will the stock DV withstand increased boost?
