11-19-2010, 03:42 PM | #1 |
Rep 25
Newer e90/92 ZCP too wide for Z4MC?
Hello all, just picked up my 07 Z4MC and first thing in order is a nice wheel/tire upgrade. I've searched and can see the CSL/ZCP questions have been beaten to death, but I'm trying to find out if the newer ZCP's are too wide to run (especially in front):
19x9 et31/19x10 et25 http://www.turnermotorsport.com/html...-WHEEL-PACKAGE Thanks for the help, much appreciated! |
11-19-2010, 04:50 PM | #2 |
17
Rep 409
^ those will not fit unless you put in a lot of neg camber up front.
**********s.com has reps that would work... frt 8.5" et35 perfect fit rr 9.5" et35 and needs a 10-15mm spacer to make flush
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
12-05-2010, 09:03 PM | #3 | |
DHS
203
Rep 4,013
Drives: 2023 M4, 2020 Land Rover
I am also running a 19x8.5 +29 and 19x9.5 +22 OEM setup and they work fine as well with OEM size tires. Just try some wheels out for yourself. When the S2000 first came out I was the first back in 2001 to run the larger 6 pot Endless BBK and nobody knew what wheels to run so I went out and bought 3 sets of wheels...ASM Spec Prodrives, Wedsports SA90s, and BR 17s. All fit with no spacers aside from needing a 3mm for the Weds. But my point is I knew they would fit but nobody knew so I said screw it and bought them. Then Endless USA told me to bring my car down so they could check on spacing for the new Enkei line coming out back then..Now everyone knows about AME wheels. R&D my friend. Same thing goes for the NSX, Z4M, E92 M3, etc... You will have a lot of doubters out there but until you actually put the wheels up with a BBK or OEM brakes with the offsets, sizes, spoke curvature, etc..you won't really know.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 Last edited by Endless619; 12-05-2010 at 09:08 PM.. |
12-06-2010, 04:18 PM | #4 |
Rep 25
Very true, I've been down that road before as well, that's some good advice. I'm having a hard time deciding lip (SSR MS1) or no lip (ZCP's above) but plan to go aggressive with it either way and work out the kinks when they arrive.
Thanks for the help guys, look forward to contributing. |
12-06-2010, 05:55 PM | #5 |
366
Rep 1,373
They will fit..... some negitive camber is required but they will fit. A bunch of members are running 9.5" et35 with 5mm spacers in the front and 255 series tires. In fact my brother runs 10" et20 in the rear with a 275.
07 Z4 M Coupe AW/IR |
12-06-2010, 06:44 PM | #6 | |
17
Rep 409
the factory front wheel is an 8.0" x et42. if you were to install a 9.5" x et30 (essentially, with 5mm spacer) wheel, it would move the outer edge of the wheel out 31mm. is that not well past the fender line??? is this where the "some negative camber is required" comes in to play? how much camber is "some"? surely the factory suspension can't move in enough to compensate? what am i not getting here?
12-06-2010, 08:19 PM | #7 |
///M-fanatic
193
Rep 3,885
You may have to get shim kit for the front to allow for more negative camber adjustment. Either that, or perhaps aftermarket suspension such as coilovers to allow even more adjustment just in case.
12-07-2010, 12:02 PM | #8 |
20
Rep 111
i've been looking into the E9X M3 CSL Style Wheels at ModBargins:
http://www.**********s.com/M3-Compet...s-Gunmetal.htm I think if you can mix up the offered sizes and get the following, it will work: 19x8.5 Front, +35mm 19x9.5 Rear, +20mm They have a variety of options in color: silver, gunmetal and black [IMG]http://www.**********s.com/images/Products/OE%20Wheels/Better%20Watermarks/mini-bm160-1995-g-2_3.jpg[/IMG] |
12-08-2010, 09:30 PM | #9 | |
366
Rep 1,373
12-24-2010, 04:19 PM | #11 |
DHS
203
Rep 4,013
Pal is correct. I have a 19x10.5 +20 with a 275 tire and no rubbing. I may push it to 285 but I may rub with that tire.
2023 BMW M4 2016 X3 |
12-24-2010, 05:10 PM | #12 |
///M-fanatic
193
Rep 3,885
Same here. I now have 19x10.5 +22 rear wheels with 275/35/19 tires, mildly lowered on TCK D/A's @ -2.2 degrees negative camber. Tires were rubbing a bit, so I had the fenders rolled slightly. Now it only rubs the fender lining, instead of the fender itself. I'm pretty sure I won't be able to go 285's in the rear with current setup.
12-24-2010, 08:41 PM | #13 | |
DHS
203
Rep 4,013
12-24-2010, 09:18 PM | #14 |
///M-fanatic
193
Rep 3,885
Actually my rears might even be 30 height lol, I suddenly don't remember. Well regardless, I believe it's more the type of tire rather than the height so much. I came up from General Exclaim UHP's (LOL) to Nitto NT05's. The ride was obviously much harsher and there's a lot more road noise. And the heights were off by only 5 so I think it's the type of tire rubber rather than heights.
02-26-2011, 07:19 AM | #15 |
MMA fighter and F1 test driver
18
Rep 362
Will the fronts rub on a stock z4Mc with 245 tires or would this tire strech too much?
19x9 et31/19x10 et25 Thanks in advcance
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof 09 Audi Q5 THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ |
02-26-2011, 04:15 PM | #16 |
///M-fanatic
193
Rep 3,885
I'm not sure about the 9" front with +31 offset (you're going to have to do your homework on that), but 245's seem to be max tire for most people, unless you do some fender pulling (not just rolling) and some extra negative camber, etc.
245's will clear up front especially if you're on stock suspension height. If you're lowered, you may need at least -2.5* of camber just in case. |
