      10-25-2010, 04:21 PM   #1
bluesunit
Drives: D-Stock 135i
Autox Tire Fun (245's fit like a champ)
Check this out:
Those are 245/35 Hoosier R6s on a 7.5" Breyton. No spacers, no rubbing. All within stock limits.
Meaty:
Totally room for *at least* two sheets of paper in there:
      10-26-2010, 08:18 AM   #2
Hairy
Hairy's Avatar
Drives: 2008 135i Black
What's the offset?
      10-26-2010, 08:31 AM   #3
bluesunit
They are listed at +46mm . . . stock is +49, I believe.
Stock rules allow for a 6.3mm (1/4") offset difference from stock rims . . . which means you could technically put a 10mm space on there.
      10-26-2010, 09:29 AM   #4
Amalfitano
15
Drives: 2009 135i STEP, Future //M2012
2009 135i  [0.00]
So long as that meaty tire doesn't spill past the fender.
It all looks good, let us know if you run into any dynamic rubbing!
      10-26-2010, 12:06 PM   #5
lithium1330
Drives: fiancee's 135 when she lets me
What's the white trim/stringy looking stuff around the tire (next to strut)? Looks (to me) like tire has rubbed against strut. You may want to double check as safety precaution.
      10-26-2010, 12:18 PM   #6
nordique14
No_Country
53
Drives: SGM 135i 'vert
Too small a rim for that wide a tire. Hoosier does not recommend 245/35/18 size on a 7.5" rim. They recommend a 8"-9.5".
http://www.hoosiertire.com/rrtire.htm
Also, unless you are running more than stock camber then those will rub either on the strut or on the wheel well when the suspension compresses.
      10-26-2010, 12:50 PM   #7
bluesunit
It's not, that's just a reflection from the flash.
As for it being too wide of a tire, remember that autocrossers are mentally handicapped and will do stupid crap such as:
-Put a 285 series tire on a 6" rim
-Spend exorbitant amounts of money to make a street tire class car slower than it was in stock form.
-Stand around in the sun/rain/etc for 8 hours for the chance to drive around a parking lot for 3 minutes
I've got the pins removed for the extra camber. I've done a bit of driving on the slicks (no competition yet) and I don't detect rubbing. If it does rub it will be *rub* not *RU-OH-SHIT-THERE-GOES-MY-FENDERLINER*
Recall that someone was running a 275 on the stock rims at last years nationals. I wouldn't run it on the track or on the street, but for autocross, it should be fine.
1addicts
