10-20-2010, 04:28 PM | #1 |
41
Rep 200
software recall
Haven't heard any local people mentioned...
I was scheduling a winter tire change and the service desk mentioned a software recall too...will be doing both. |
10-20-2010, 05:06 PM | #5 |
125
Rep 4,971
That makes sense - be sure to post up what you find out. I havent been on here quite as much as late and hadnt heard about the current DCT issues on the main board.
10-21-2010, 02:37 PM | #6 |
41
Rep 200
ahhh....called the service desk...they couldn't provide much detail.
Just a description saying its a US program recall. I guess i have to wait till my appointment to find out. |
10-22-2010, 12:42 PM | #7 |
41
Rep 200
See below thread on main board
http://www.m3post.com/forums/showthread.php?t=445556 Again not much detail but some one post this SI B28 01 10 Double-clutch Transmission with Drivelogic September 2010 Technical Service PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS AND PRIOR TO RETAIL DELIVERY. SUBJECT Service Action: Program Control Units (DCT) MODEL E82, E88, E89, E90, E92, E93 vehicles with DCT transmission produced from 1/08/2008 to 8/31/2010 SITUATION Due to errors in the diagnostic software of the DCT (Dual Clutch Transmission) module, the "Freeze frame data" of the DCT memory can not be read out when using aftermarket scan tools. CAUSE DCT software error AFFECTED VEHICLES This Service Action involves E90, E92, E93 M3 vehicles with the S65 engine and DCT transmission and E82, E88, E89, E92, E93 vehicles with N54/N54T engine and DCT transmission which were produced from 01/08/2008 up to 08/31/2010. In order to determine whether a specific vehicle has had this Service Action completed or is affected by this Service Action, first check the B-pillar label for code number 575. If code number 575 has been punched out, the campaign has already been performed. If code number 575 has not been punched out, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action. PROCEDURE Program the vehicle using ISTA/P 2.39.0 or a more recent version. E8x/E9x – Integration level (new): E89x-10-09-501 or higher. Note that ISTA/P will automatically reprogram and code all programmable control modules that do not have the latest software. For information on programming and coding with ISTA/P, refer to Centernet / Aftersales Portal / Service / Workshop Technology / Vehicle Programming. Last edited by ep99; 10-22-2010 at 12:47 PM.. Reason: extra line |
11-01-2010, 05:04 PM | #8 |
41
Rep 200
ok...did the program update.
The description is: complaint: E8X E9x US program control units (DKG control unit) cause: bulletin 28 80 10 0028010100 program DKG correction: connect to ISSS and program vehicle with CAS defect code 00 28 01 01 00 Labour operation: 00 59 718 Labour allowance: 9 FRU AMP fail and reprogram Still not sure what it is... but some of my Idrive setting had been resetted. |
11-03-2010, 04:34 AM | #10 |
41
Rep 200
The November 1 post is what actually been done to the car and on the description of my invoice.
The Oct 22 post is what i have found on some post in the main forum. I did a search on DKG control unit and i think its the DCT. |
11-12-2010, 08:15 PM | #12 |
Rep 46
Just got mine done today...
Car holds gears a little longer - that is - it doesn't want to shift right into 7th at 40kmh anymore. Also, I noticed that it downshifts more when speed slows as opposed to just before stopping. No other noticeable differences. All iDrive settings were intact other than my saved addresses in navigation.
11-12-2010, 09:55 PM | #13 | |
23
Rep 203
I noticed that too. I heard a rev blip in the drive (D) mode downshift as well which did not happen before.
