KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
09-30-2010, 06:24 PM | #1 |
110
Rep 1,311
12mm F/R on OEM 18" to clear BBK, any chance of fender rub?
Ok, gonna have to probebly go with 12mm spacers front and back to clear a BBK. My M3 is an '08 and OEM suspension and not dropped...yet. Measuring I believe if I go with 12mm spacers front & back, I should be ok and not have any fender rubbing. But what if I drop it with a ZCP competition struts & springs or with a Dinan set up? The spacers are temperary until I decide on some new wheels when the tires on now start to meet their end. Anyone got 12mm spacers or wider with stock 18"s?
Cheers, |
10-01-2010, 09:47 AM | #2 |
2759
Rep 6,760
I am running the stock 18" setup with EDC. I installed 12mm spacers on all 4 corners and had slight rubbing in the back - I'm sure 1mm less would have been ok.
I think it rubs towards the back of the car, at the interface between fender and bumper - there's a clip or similar that holds the two together and the plastic fender liner has a small protection dome over that clip. I shaved off the plastic dome with a utility knife and it still rubbed occasionally. If I wanted to keep the 12mm spacers I'd have to give it a bit more negative camber at the rear. So I decided to get rid of the 12mm and will soon put 10mm spacers all around.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
10-01-2010, 01:26 PM | #3 | |
110
Rep 1,311
10-02-2010, 08:18 AM | #4 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
this is some good info! out of curiosity, what size BBK do you plan on running?
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
10-02-2010, 06:11 PM | #6 | |
110
Rep 1,311
Decided to go with the APracing 368/345 BBK. Style 219 18" wheels will need a minimum of 10mm from what I've read and was told by AP reps. Then I read about how 10mm is not recomended fitment and safety reasons (I don't know how true that is) so I figured I'd go with 12mm for now until I decided on the right wheels to clear the BBK. |
10-03-2010, 01:20 AM | #8 |
439
Rep 2,373
We run 15mm front 12mm rear not rubbing at all ...
18" OEM wheels with PS2 tires / Dinan Stage 2 suspension / RD Sport Sway Bars Aligned per Dinan Stage 3 specs |
10-03-2010, 05:27 AM | #9 | |
110
Rep 1,311
Awesome! I was just about to post a question conserning going with a Dinan suspension with my 18" and spacers. I may PM you for more info. Thanks, Rob |
