09-12-2010, 08:21 PM | #1 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
EZ-Key on my car
Just finished installing this today.
No keys needed, not even for doors. Give me your thoughts on it [u2b]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/kOWgprraujo&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_ US&feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/kOWgprraujo&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_ US&feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>[/u2b] Last edited by Diokaef; 09-13-2010 at 01:09 AM.. Reason: fixed video problems |
09-12-2010, 08:31 PM | #2 |
Engineer
216
Rep 2,122
some pictures
09-12-2010, 08:46 PM | #3 |
///M-fanatic
193
Rep 3,885
Go to the "Edit Video" page from your YouTube account "My Videos" tab. Then you'll see a snapshot of your video in the center & somewhat on you right-hand side of the screen. On the bottom right of this snapshot will be a little pull-up button which will provide you the proper Embed link. I haven't had any issues using the link generated by that pull-up button. G'luck!
09-12-2010, 09:49 PM | #5 |
88
Rep 1,090
^ no keys anymore. He inputs a code to start the car up.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
09-12-2010, 09:55 PM | #6 |
44
Rep 1,855
Awesome mod. I suppose you still need the key to get into the car if it's locked.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
09-12-2010, 10:15 PM | #7 |
Engineer
216
Rep 2,122
09-12-2010, 10:27 PM | #8 | |
Engineer
216
Rep 2,122
09-12-2010, 11:52 PM | #9 |
128
Rep 1,772
Drives: 2007 Z4M Coupe
wow, f'ing sweet. I would love love love to get that done to my car! road trip to East Peoria IL?
09-12-2010, 11:57 PM | #10 |
Engineer
216
Rep 2,122
System overview EZ-Key
␣ Up to 5 user codes can be easily programmed at the keypad to give temporary or permanent access to family or friends. To unlock the car system, simply enter your personalized 4 to 8 digit access code at the Keypad. After a valid code is entered, trailing digits can be used to open a trunk, storage compartment or operate any electrically controlled auxiliary device. ␣ Keypad lights at first touch for nighttime convenience. Not really a diy type device. Tamper Alarm Multiple incorrect entries trigger Tamper Alarm, lock out system for 30 seconds and flash the dome light • Easily Programmable at the Keypad Add, Modify or Delete Users from the Keypad • Vandal Resistant Design Fully encapsulated, back mounted piezoelectric keypad and main Module built with 3500 PSI impact resistant Urethane and is fully water resistant, also keypad water resistant. • Current Draw Standby < 15mA < 25mA Maximum 75 mA 100 mA • Keypad Switch Technology Solid State Piezoelectric with no moving parts • Dimensions Height Width Keypad 1” (2.5 cm) 5” (12.7 cm) • Keypad Operating Environment - 40°C to + 70°C (- 40°F to + 160°F) 100% Relative Humidity Depth 1⁄2” (1.3 cm) Last edited by Diokaef; 09-13-2010 at 01:05 AM.. Reason: corrected the text that was posted for one of my other systems, sorry |
09-13-2010, 12:00 AM | #11 |
Engineer
216
Rep 2,122
09-13-2010, 12:07 AM | #12 |
Engineer
216
Rep 2,122
I forgot to mention that I did not cut any wires on my car, all was done plug and play. only thing that I had to do was remove the tumbler lock with no damages to it and drill the dash and the sunglass holder.
09-13-2010, 12:47 AM | #14 |
23
Rep 147
I actually had to watch the video a few times. It is facinating the mods that are available in this world. I will admit it is not for me, but it looks pretty good.
09-13-2010, 12:50 AM | #15 |
Engineer
216
Rep 2,122
you can do anything that you put your head to, this system will last around 25 years if I press that button 11 times per minute during 25 years.
09-13-2010, 12:54 AM | #16 |
Engineer
216
Rep 2,122
Yes the lighter on the old ignition key hole is fully functional and I build the module with an extra output just for that.
09-13-2010, 01:07 AM | #17 |
Engineer
216
Rep 2,122
I will post a video to show how the door work's once I'm done installing it.
09-13-2010, 12:02 PM | #18 |
21
Rep 352
Surprised EZ-Key doesn't have a web site... What's up with that?
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP |
09-13-2010, 12:22 PM | #19 |
94
Rep 1,546
that's friggin SUHWEET!!!
how much, if you don't mind, did that cost and how long did it take to install?? also, that cig lighter/acc in your old ignition, is that now a second one? I only ask b/c it's inconvenient, for me, b/c I use my radar and GPS...but only one cig lighter, so I can only use one at a time, or until the GPS dies...
09-13-2010, 05:30 PM | #21 |
Rep 165
Do you have to press your code each time you stop your car? It looked in the video like the car went to accessory mode when you pressed the start/stop button with the car running, and that you had to enter your code to get all the electronics to actually shut down. Also, do you need to enter your code to lock the car or is there a quick shortcut? On my Fords I only need to press the 7 & 9 keys together on the door and it will lock all the doors.
09-13-2010, 05:41 PM | #22 | |
Smiling Politely
1381
Rep 29,118
this will makes trips to the dealer interesting
awesome mod dude
