07-30-2010, 11:12 AM | #1 |
69
Rep 957
Castrol SRF + pads - where?
I spent way too much time searching for a place that sells Castrol SRF brake fluid and some good street/track pads and also ships to Canada. Hope someone could save me time and share some links.
07-30-2010, 11:20 AM | #2 |
169
Rep 3,831
07-30-2010, 11:03 PM | #4 | |
80
Rep 961
It's Vancouver but they've got good prices. |
09-23-2011, 11:25 PM | #5 | |
Supreme Allied Commander
3865
Rep 54,426
Drives: F80 M3
http://www.hpashop.com/category.sc?categoryId=223 |
09-24-2011, 01:16 PM | #8 | |
50
Rep 1,285
Drives: A Car
09-24-2011, 06:02 PM | #9 |
69
Rep 957
Thanks guys! The original post is well over a year old though . Good to hear that there are Endless pads available locally. I just received my Project Mu clubsports now, and if I don't like them, I'll try endless.
09-25-2011, 06:14 PM | #11 |
1122
Rep 7,690
12-22-2011, 02:18 AM | #12 |
924
Rep 15,818
I have Motul RBF 600 right now...
Wondering if I should change to Castrol SRG? A friend of mine drove my car and confirmed my concerns: i need to push the pedal way too far down.... seems there's "moisture" or "water" in the line? this is just a guess.. I was curious if it had anything to do with the fluid?
12-22-2011, 06:58 AM | #13 |
1578
Rep 8,077
Drives: 11 E90 M3 Individual
I've used SRF and Motul RBF 600 You will likely need to bleed motul after every weekend or 2-3 days at the track. Your mushy pedal after some track use on Motul is normal.
I kept SRF in for about 9 months and it was still good. When I finally bled the SRF out, it was super dirty but still usable. ...but Motul is still cheaper over the long run if you bleed the brakes yourself. I go through about .5L every bleed. If you pay a shop to bleed the brakes, SRF is the way to go.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-22-2011, 07:22 AM | #14 |
924
Rep 15,818
I don't know how to bleed...and the shop(s) that I trust are all a 70mile+ drive away....
12-22-2011, 08:16 AM | #15 |
1578
Rep 8,077
IMO, SRF is a no brainer. One bleed with SRF will be about $150 + labor but you'll save $$$ on the labor over the long run. In my experience, SRF recovers a lot better and you don't get that mushy pedal after a weekend at the track.
I had 4 hard track days on SRF, one of which I ran my pads down to less than 1/8". My front calipers turned brown and the brakes at all four corners were smoking. SRF was still good. I had shipped my car from Korea to Dallas and it was 9 months old so I just bled in Motul. The pedal was still good.
03-12-2012, 03:46 PM | #16 |
16
Rep 197
Guys correct me if im wrong but SRF shouldnt be mized with any other fluid, so you have to completely empty the reservoir, get air in the line then refill with SRF or you could remove most of old fluid then top with SRF and bleed till only SRF is left? Thanks
03-13-2012, 07:25 PM | #17 |
30
Rep 361
I just picked up 3 bottles of Castrol SRF from Amazon.com, the "sub store" that sold it is called Powersport Superstore and it costs $67 plus shipping.
03-13-2012, 07:28 PM | #18 |
11818
Rep 23,187
thats cheap thought it was more like 75-80
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
03-13-2012, 10:54 PM | #19 |
80
Rep 961
Your perception is incorrect. SRF is just another high performance DOT4 fluid, so it mixes and works with other DOT fluids just fine. You need to run it for a while and flush a couple of times to get all the old fluid out of the nooks and crannies, but overall every time you do a flush with SRF you gain a little performance until you're all the way there.
03-13-2012, 11:07 PM | #20 |
893
Rep 9,032
JAJ always speaks the truth.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-14-2012, 09:33 AM | #21 | |
16
Rep 197
03-14-2012, 11:02 AM | #22 |
893
Rep 9,032
Most people who run SRF just fill it and forget about fluid for the season.
One guy on Bimmerforums Track section even saw a race team do a flush on the race car after a few races and then put it in a street car for someone to run a HPDE!!! Not my story but there are a lot of racers on that board. Search SRF there and you'll find a ton of info.
