07-08-2010, 11:23 AM | #1 |
68
Rep 531
Hard Water Spots on Car...
Hey Guys,
I made the mistake of parking my car by the grass at my girlfriend's apt overnight and the sprinklers douched the car with some very hard water. There are a bunch on hard water spots now on the car and even after I wash the thing, they are still faintly there. What is a good way to remove hard water spots?
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
07-08-2010, 11:48 AM | #2 |
Master Chief
19
Rep 641
Try in this order:
-Claying (will most likely remove the mineral deposits; will not remove etching on clear coat) -Chemical Guys Water Spot remover (acidic base... better at removing mineral deposits, not strong enough to remove etching from clear coat) -Polishing (PC 7424XP, try using Meguiars M205 with a white pad to see if you can buff it out. If not go with a denser foam pad, like orange, or even M205) |
07-09-2010, 02:44 AM | #5 | |
37
Rep 1,168
some people doubt me, but sometimes chrome polish works wonders! just be sure to wash after and polish/wax. i doubt any harmful effects, but I am not a chemist, so I error on the side of caution |
07-09-2010, 03:59 AM | #6 |
11
Rep 770
Removing ‘Water spots’
Always start by using the least abrasive product first- 1. Use a paint surface cleaner (Z-PC Fusion Dual Action Paint Cleaner or Duragloss 501) 2. Try to dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following; a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid) b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required) c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol. 3. Clean the effected surface with Klasse All-In-One or Zaino Z-PC Fusion Dual Action Paint Cleaner 4. Use detailing clay to remove any `hard' surface granules 5. Use a machine polish (Optimum Polish, Optimum Compound) and a cutting (LC White, Orange or Yellow) foam pad (speed # 4- 5.0) to level the paint surface 6. Use the least aggressive polish/foam pad first, if this doesn’t remove the problem step-up to a more aggressive polish / foam pad set-up 7. Wet-sand with 2000, 2500 or 3000 grit finishing paper TOGWT ™ Ltd (Established 1980) © Copyright 2002-2010, all rights reserved |
07-09-2010, 08:24 AM | #7 |
Master Chief
19
Rep 641
I know that people like to use vinegar but it has never worked for me...then again, my spots were always etched into the clear coat so polishing was the only avenue left for me to do.
07-13-2010, 09:21 AM | #8 | |
Rep 290
Thanks!!! Just what I was looking for. |
