06-21-2010, 09:40 AM | #1 |
116
Rep 468
Stock Pads at Track - Not Good
I did a track even in May with stock pads, got the standard deposits, but overall it wasn't bad. They worked reasonably well.
Just got back from another event and the brakes were terrible. In the first session I had deposits and was getting brake fade at the end of the session. The fade started happening earlier and earlier over the course of the weekend, but was manageable. The deposits were terrible. On day two the car was shaking violently when I hit the brakes. They still worked, but the shaking was very distracting. I felt like much of the braking 'feel' was compromised and I started to be inconsistent. I also had less confidence that they were going to work so I started braking earlier and earlier. On the straight I brake slightly at about 145mph and the shaking was disturbing. Since I'm still a novice on the track (2nd event), I really wanted to work on improving my driving but the deposits created such a distraction, I'm a bit disappointed with the weekend. I have some in car video I will post in the video section later this week. You can actually tell in the video how bad the car is shuttering during braking. I'll be moving to track pads and fluid next time out. |
06-22-2010, 01:52 AM | #3 |
892
Rep 9,032
I've done 5 track day events with no issues with the stock pads in terms of deposits. Did you do a proper cool down each time and stay off the brakes while idle after each session? They're definitely not designed for track duty.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-22-2010, 05:21 AM | #4 |
chris
278
Rep 12,144
you should do a cool down lap (with little to no brake application at all) after each session... And make sure you dont leave your brakes on when cooling down in the pits.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
06-22-2010, 06:55 AM | #5 |
817
Rep 7,887
06-22-2010, 07:57 AM | #6 |
127
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I would even drive down and back on the pit access road to cool the brakes even further after a session and prior to parking (in addition to the cool down lap).
What track were you driving?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
06-22-2010, 08:42 AM | #7 |
116
Rep 468
I'll post the video in the next couple of days, haven't had a chance to upload it to the computer yet.
Everytime we got the last lap flag, I would do the lap with no braking at all. Then I would drive down the access road for additional cooling. No emergency brake was used. I watched part of the video last night and the vibration is harder to see than I thought, although noticeable at some points. |
06-22-2010, 10:22 AM | #8 | |
Formerly K335i
19
Rep 215
Agreed that a proper cool down is essential no matter what brakes you're using, but unless you're taking it relatively easy on the brakes or driving on a slower track, the stock pads are not up to snuff. They simply aren't designed for the temperatures seen at the track.
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
06-22-2010, 10:58 AM | #9 | |
Formerly K335i
19
Rep 215
Well said.
06-23-2010, 08:35 PM | #10 |
BMW FAN
43
Rep 723
At willow springs, I was able to get about 10 laps in a 335i on stock pads and rotors. It seems as though purchasing new pads and better rotors would definitely help me get some more track time before the brakes fade.
06-23-2010, 10:14 PM | #11 |
127
Rep 3,071
+1, it's not the rotors.
06-24-2010, 08:52 AM | #12 |
116
Rep 468
Did anyone get a chance to see the video I posted and the shuttering during braking. Just wanted validation that this is what everyone else is experiencing.
06-24-2010, 10:36 AM | #13 |
24
Rep 472
think your thread title is a bit misleading, based on your previous posts, that track you "warped" your brakes at was the fastest track in north america. I have tracked my m3 a Laguna Seca and buttonwillow with no issues, stock pads with fresh higher temp fluid. Also since you are a beginner, you might need to pull back a bit and make sure it is not the driver that is causing the issue. What group are you running with on the track, do they provide instructors?
06-24-2010, 11:04 AM | #14 |
817
Rep 7,887
One thing to remember that using the MDM will make this problem worse as it will increase the brake temps even if the light is not flashing.Was the OP using MDM?
06-24-2010, 11:14 AM | #15 | |
116
Rep 468
The title of this post is relevant to what I experienced. I am certainly not the only one who has had deposit issues with the stock pads, seems relatively common. Thought I would share my experience. For BMW I was in the C group with an instructor. No notable issues with the way I was braking from the instructor. For the PCA, I ran in group 2 with no instructor. I did use MDM, which may make the problem worse, but given my level I'm not ready to turn it off. No, I don't rely on it, I try to be very smooth with inputs. Next time out, I'll go with track pads and higher temp fluid. I'll post my experience. |
06-28-2010, 01:08 PM | #16 |
Rep 87
This thread interested me greatly. I get really bad vibrations from my brakes after a track day. I have done several and several days at the ring and it is always the same.
I was concerned that I had warped the rotors but the problem usually resolves itself so it must be this issue with deposits. Can someone explain this further to me? I was looking into upgrading the brakes to combat this issue. I am concerned that if I put track day pads on they will be squeaky or not perform well during normal road driving. What pads are recommended? I was considering one of the 2 kits here: http://www.thorneymotorsport.co.uk/t...3-brakes.shtml Will the big brake kits help with cooling? At a track day my wife and I drive the car so it gets twice as much driving than either of us so less cooling down is a good thing. Thanks
Car blog: http://mr04drs.giles.roadnight.name/
06-28-2010, 01:24 PM | #17 |
817
Rep 7,887
Here are a pic of deposits on my front brake discs after 1 track day with stock pads.I normally run Hawk HP+'s on track.They always clean up after some street driving and I am still on the orginial discs after 20+ track days & 40000 kms of street driving.
06-28-2010, 02:38 PM | #18 | |
116
Rep 468
06-28-2010, 03:48 PM | #19 |
70
Rep 1,339
I am more impressed that you run with only one lug bolt more than anything else!
06-28-2010, 04:07 PM | #20 |
817
Rep 7,887
06-28-2010, 05:12 PM | #21 | |
127
Rep 3,071
07-08-2010, 11:08 PM | #22 |
471
Rep 2,991
I've found there is a lot of technique to braking. I run in the instructor group, and I am usually not pushing my car super hard, but I do like to go fast... I try to be nice to my brakes though.
Just some tips to help eek more life out of stock pads: (and I haven't tracked my E90 M3 yet, but I have a ton of track time in my supercharged E36 M3, E46 M3, Z4 and 335i, and have done events on stock pads as well as race pads.) - brake firmly as little as possible - the longer you are on the brakes, the harder they have to work and the more heat you put in them - get as much time off the brakes as you can - don't be afraid to take a cooldown lap in the middle of a session, or come into the pits for a few minutes to cool your brakes (At thunderhill, I can usually get an entire session on stock pads, but at Laguna, I usually have to come into the hot pits for a minute or so, to cool them if I want them to last) - if you are fully threshold braking into every braking zone, your stock pads are not going to last - remember that you are still doing driving schools and that going 1 second faster isn't going to net you more prize money seriously, though, try riding with more experienced people and take note on how they brake, when they apply the brakes and when they come off them. Intermediate group is usually a really bad place for this, ride with some of the faster instructors. The M3's factory brakes are pretty good. It is a very heavy car, though, and there isn't a whole lot of brake cooling. You may end up having to go to a more aggressive pad... (and the Cool Carbons are an ok dual purpose pads, but you still need to use good technique or you will overheat them too) |
