06-16-2010, 09:27 AM | #1 |
67
Rep 579
D-Force LTW5 wheels
Anyone have experience with these wheels with some NT01's? I'm considering getting a square set from bimmerworld as they are relatively inexpensive. My only concern is that they are weak and of low quality.
06-16-2010, 10:23 AM | #2 |
70
Rep 1,339
I have these from Bimmerworld, with NT-05 mounted. I like them, they feel very light - you notice when you take the OEMs off!.
So far, 4 track days, no sign of problems with bending and I managed to knock the alignment out on my M3 by hitting a kerb without bending a rim. The best advert I have seen that made me feel better was that a team running in a SCCA Pro IT race was using D-Force LTW-5 rims. I think Turner sells them which somehow gives me confidence in their quality. I was looking for a picture. I also figure a bent rim is cheap to replace! Last edited by LiM3y; 06-16-2010 at 10:33 AM.. |
06-16-2010, 11:03 AM | #3 |
128
Rep 1,144
The closest thing I know of are the TR MT-1s, similar weight and cost - and I have bent 2 already without going off the track. I'd probably try the Dforce if I had to do it all again. I noticed BimmerWorld has the 18x9.5xET35 on sale for $270 too (you'll need a 12mm spacer and if you want luxurious wheel changes, studs too).
06-16-2010, 12:34 PM | #4 |
234
Rep 1,508
I have the D-Force mounted with Dunlop Star Spec 275/35/18 all around. I have done 6-8 track days with them so far and I have zero complaints. They are strong and light. You will need spacers though. I use 12mm in the front and 15mm in the rear.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates Previous: 2009 E90 M3 |
06-16-2010, 12:44 PM | #5 |
70
Rep 1,339
I use 15 front/12 rear???? You must be wrong!!!!! (joke)
06-16-2010, 02:35 PM | #6 |
67
Rep 579
Thanks. I would like to get this wheel/tire setup by i may need to wait a little longer. Since i have a track day coming up, i may just use my OEM wheels/PS2's even though i know i'm going to get very frustrated with lack of grip.
Any idea how much life of the tire i will take away by using my PS2's during 3 30 min sessions? I have racing and a lot of track experience and run in the advanced group. Trying to determine if its even worth it... |
06-16-2010, 03:14 PM | #7 | |
30
Rep 915
vz
Previous Track Toy |
06-16-2010, 03:29 PM | #8 | |
67
Rep 579
Thanks. |
06-16-2010, 03:35 PM | #9 | |
70
Rep 1,339
Two more days on the docket for NJMP on Monday and Tuesday next week! |
06-22-2010, 11:05 AM | #13 |
Formerly K335i
19
Rep 215
I'm running these in 18x9.5 ET35 with Rouge 12mm spacers all around. You definitely need the spacers, otherwise the wheel is too recessed and gets too close to (even touches) the suspension assembly. These are great, strong wheels and are nice and light.
The rouge spacers are great. If you go with their 10 or 12, make sure your wheels are compatible - they must have a chamfered hub face. Most wheels (including these and the stock wheels) are fine but it's always good to double check.
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
06-22-2010, 12:39 PM | #14 | |
67
Rep 579
06-22-2010, 01:49 PM | #15 |
Formerly K335i
19
Rep 215
None with me... I just put them back on for a track day tomorrow so I will try and snap a couple pics when I get home tonight.
06-22-2010, 05:21 PM | #16 |
234
Rep 1,508
I am running my D-Force wheels with 12mm spacers up front, and 15mm in the rear. I could definitely use 12mm all around but I find the rear wheels already too tucked in for my taste. 12mm would be worse.
Plus, I am trying to go for same track width front and back. With my setup, the front track is already about .5" wider then the rear. Here are a couple of shots on my car:
06-23-2010, 01:14 AM | #17 |
892
Rep 9,032
Why not just get the Apex wheel then. 10" all around or 9.5" front and 10" rear.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-23-2010, 10:29 AM | #18 |
67
Rep 579
What is the apex wheel?
Does OZ make an 18" wheel? I had a nice set of ultrleggera track wheels for my e46 m3 that I loved and they weren't too expensive. It seems there isn't a track wheel in the price range of around 350 to 400 a wheel. It's either Really cheap or really expensive |
06-23-2010, 11:52 AM | #19 |
Formerly K335i
19
Rep 215
I've heard good things about the Apex wheels - they're light, have good offsets, and were designed to clear the Stoptech 380mm BBK. Personally, I went with the D-Force wheels since they have a proven track record.
06-23-2010, 11:57 AM | #20 |
63
Rep 672
Drives: E92 M3, E30 M3, 1M, F10 M5
I considered running the D-Force LTW5 wheels as well, they are proven but the offsets are just not built for E9x M3s.. they are excellent for regular E9X, but not the M3s.. You have to run large spacers to get it to fit properly. I am okay with running spacers and I do think I do think that the wider track with spacers make a difference but I would rather not have to run spacers if I did’t have to.
That’s why I went with APEX 18x9.5 and 18x10.. Price wise is the same and so far no issues. I track a considerable amount as well and I do have one extra wheel on each side just in case I do bent them (or tire pucnture) on the track and I need a replacement immediately during raceday. |
06-23-2010, 02:29 PM | #22 | |
892
Rep 9,032
You just missed the group buy, but they're still pretty reasonable, but a little more. The offsets are better for our car. http://www.m3post.com/forums/showthread.php?t=382667 .
