05-22-2010, 12:43 PM | #1 |
Rep 13
Brake Squeal
Hi All, I have an annoying squeal from my back brake on braking (naturally!). Normal? Any suggestions of how to get rid of it? Dosen't happen on hard braking only on softer braking. Car SDrive35i.
Thanks! Geo |
05-22-2010, 04:16 PM | #2 |
62
Rep 2,087
If it something minor more than likely it's some rust or similar on the rotor that will go away with use.
Otherwise, BMW have to remove the pads/rotors and replace them. .
"Political correctness is a doctrine fostered by a delusional liberal minority and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end".-- Unknown
05-23-2010, 05:00 AM | #3 |
Rep 13
05-23-2010, 05:59 PM | #6 | |
91
Rep 1,838
you gotta remember everything needs to be broken in. tires, brakes, exhaust, engine, clutch (if manual tranny).
05-24-2010, 04:30 PM | #8 |
27
Rep 676
Here's a procedure I've learned, and used, to break in new brakes (on a new car and after any brake job)
Never come to a complete stop during the procedure to avoid heat sinking and warping the hot rotors. This procedure sits the pads to the rotors and should help avoid noise or warped rotors later on.
2010 BMW Z4 s35i
2014 Jeep Wrangler Rubicon 2013 Volvo XC90 |
05-24-2010, 06:21 PM | #9 | |
41
Rep 1,531
T |
05-24-2010, 09:59 PM | #10 | |
245
Rep 2,387
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. Last edited by jparnes1; 05-24-2010 at 10:16 PM.. |
05-25-2010, 08:31 AM | #12 | |
27
Rep 676
2010 BMW Z4 s35i
06-24-2010, 07:21 AM | #14 |
76
Rep 561
My break squeal is back, and scared the living shit out of me today.
My right rear break has been making a bit of noise for a while now, but today on the highway at about 130km/h I braked a little bit.... then the right rear break sounded like it got stuck. I hard squeal noise appeared for about 15 seconds, luckily it went away after. Gonna bring my car in for a checkup today, dont want that to happen again. |
06-24-2010, 09:46 AM | #15 |
Rep 446
Drives: '09 Z4 s35i & '03 Z4 3.0i
Check for any kind of small rock or debris that can cause a squeal, otherwise get it in for a check...
( the posted sequence for breaking in the brakes is great but I save time by just doing 120mph down to 30mph ....just kidding folks , my car is "run in" just fine.)
Member ZSCCA 2009 Z4 s35i with Dinan Stage II software, Sport and Exec packages, 19" 296 rims , a stubby and mud flaps
'03 Z4 3.0i Sterling Grey (Hers) '01 Z3 3.0i Sapphire Black, M sport package (Mine) |
06-24-2010, 01:28 PM | #16 |
27
Rep 805
Drives: 2011 Z4 35is Melbourne Red
New pads are very easy to over heat and creat a glaze on the surface. If the above break in procedure does not work and there is no debris (rocks) stuck in the caliper you may need to pull the pads. Pull the pads and sand off the layer of glaze and also add a coat of anti-squeal to the back side of the backing plate. Re-install and follow the bedding procedure.
