05-17-2010, 03:47 AM | #1 |
11
Rep 217
gas pedal on DCT not responsive (enough)
this drive-by-wire thing on my 35iS is a point of criticism that I have: when trying to slowly accelerate, the gas pedal needs more than just a 'touch' of the pedal and that's annoying. All in normal/D mode .... S and S+ mode will probably be different/better but less suitable for slow driving
Also, reverse needs firm pedal movement before it will go anywhere Is this solveable by resetting the DCT ? Or is this a meant-to-be setup ? Anyone experiencing the same 'problem' ?
2012 - F30 - 330d M-pack - Glacier Silver
1999 - Honda S2000 - Silverstone |
05-17-2010, 05:38 AM | #2 | |
Rep 131
Yes I have all the same,
35iS, Deep Sea Blue, 19" 326 alloys, etc
05-17-2010, 08:21 AM | #3 |
381
Rep 2,588
I generally agree with these concerns but once I had the ESS Stage II tune installed on my wife's 35i - all of this went away but for the smallest amount of delay.
05-17-2010, 10:46 AM | #4 |
Go SU
33
Rep 902
I do not experience that, because other than the first 2 miles of engine warm-up I never drive in Normal and always use Sport gear shifting. I consider Normal to be "slow mode" and Sport to be my "regular" mode. Then to go faster, I use Sport + about 25% of time. I didn't buy the car to save gas. I bought it to go fast and enjoy it.
05-18-2010, 01:00 AM | #8 | |
70
Rep 343
Only Sport+ mode will shift later. Or if you use Sport mode and put the DCT controller to the left (same effect). |
05-18-2010, 02:57 AM | #9 | |
11
Rep 217
I will try the Sport mode and later on maybe also the DCT reset Sport mode will also stiffen the suspension and my wife dislikes that
05-18-2010, 11:55 AM | #12 |
Go SU
33
Rep 902
05-18-2010, 03:25 PM | #13 |
44
Rep 486
Drives: Tanzanite M4 2018
05-18-2010, 04:14 PM | #14 |
11
Rep 162
How to reset DCT
I can neither confirm nor deny, but this was pulled from an m3 forum. I don't have the guts to try it. Yet. Going over either 40 or 50mph (forget exactly which), shift into neutral then pull back both paddles for a few seconds. This reset the adaptive memory that alters shift patterns based on your driving style. It help work through some jerky clutch problems my car would occasionally develop. JZ * |
05-18-2010, 05:12 PM | #15 |
Go SU
33
Rep 902
05-18-2010, 05:20 PM | #16 | |
91
Rep 1,838
WHOAH!!! WTF!!! NO, PLEASE DON'T DO THIS!!!! here is the reset: 1. get in car, foot off brake and gas. put key in ignition, press start button (all idiot lights should be on) 2. depress gas all the way and hold for 30 seconds 3. before releasing the gas pedal after 30 seconds, press the start button so that all idiot lights turn off. 4. release gas pedal, and wait approx 2 mins for ECU to reboot. 5. without removing the key, simply start the car.
05-18-2010, 05:27 PM | #17 |
14
Rep 168
I have not reached 1200 miles on mine. About the ignition key, I have Comfort Access and I guess based on the instructions, I do not need to have the keyfob on me. Otherwise, pressing the start button with the keyfob inserted on your person starts the car.
Do I need to wait until I reach then to reset the computer? Thanks! |
05-18-2010, 06:34 PM | #19 | |
11
Rep 162
If you shift into neutral the procedure would be harmless. The paddles are controlled by electronics and your in neutral. I don't see the harm. I wouldn't try it without further verification anyway. Good input. JZ |
05-19-2010, 12:45 AM | #20 | |
11
Rep 217
You mean her E60 ....
05-19-2010, 02:39 AM | #21 |
44
Rep 486
Well........i'm a big fan of 1960-1969 american cars, mainly GM. I remember my fathers white 1966 Fleetwood convertible, an absolute monster (BIG) in Sweden at that time. Too big for our parking-lot!!! Great times!
If I had to choose between that and a 2010 E60, guess what i choose? |
