04-24-2010, 10:06 AM | #1 |
27
Rep 676
Rubber seals maintenance
This is my first convertible, so I've never had to worry about roof seals.
What products/techniques do you guys use or recommend to maintain the various rubber seals?
2010 BMW Z4 s35i
2014 Jeep Wrangler Rubicon 2013 Volvo XC90 |
04-24-2010, 10:25 AM | #2 |
42
Rep 640
You want to use a good German product called Gummi Pflege. Many sources on the web carry it here's one.
http://www.autogeek.net/1z-einszett-...are-stick.html |
04-24-2010, 12:56 PM | #4 |
44
Rep 486
Drives: Tanzanite M4 2018
I bought BMW Gummi Pflege at the dealer. A spraycan, spraying on a piece of cloth and aply.
04-24-2010, 02:55 PM | #5 |
19
Rep 484
04-24-2010, 03:27 PM | #6 | |
44
Rep 486
The instruction is a bit vague. I did every rubber seal when the top was down and then i had do do something else, so i'm not sure if there are some more seals that hides somewhere. But I "felt" like i got them all. Have to check later. The top was in the trunk and the trunk open. It's a lot of rubber on this car. Last edited by SHADOW4; 04-24-2010 at 03:34 PM.. |
04-24-2010, 04:21 PM | #7 |
42
Rep 640
I do mine in multiple positions between parially open to nearly full stowed to get all the seals. Gummi your door, bonnet, and trunk seals as well. Keeps the squeaks and groans minimized. Wipe off the excess it will last for a month or two depending on ambient temp.
04-25-2010, 05:36 AM | #9 |
Rep 47
Rubber seals
I didn't use anything fancy. My top was squeaking while in the up position.
Used silicone spray wiped on with a rag on the roof seals that mate against the car with the top up. Worked like magic. No more squeaks. Partially lowered the top to apply to the seals. Took all of 5 minutes. |
04-26-2010, 07:14 PM | #10 | |
27
Rep 676
2010 BMW Z4 s35i
04-27-2010, 02:11 AM | #11 | |
44
Rep 486
I think 2 times per year will be enough to keep them in good condition. I hope! |
04-27-2010, 08:37 AM | #12 |
62
Rep 2,087
04-27-2010, 09:12 AM | #14 | |
Rep 71
Rubber Seals Treat only with water or rubber care products. <!> Do not use silicon-containing care products on rubber seals; otherwise, noise and damage could occur. |
