04-17-2010, 02:09 PM | #1 |
226
Rep 918
Eibach lowering springs for M3 e93 with EDC...
Hey guys, I think its time to lower my car now...been on my mind for ages!
I want to go with the eibach springs...however i gave EDC and all the springs for the e93 M3 dont mention EDC and all have the same product code...So the question is - does it work with both non EDC and EDC cars? Eibach Part Number: E10-20-014-18-22 Any help appreciated
BMW F80 M3 ZCP DCT | Individual Atlantis Blue Metallic | Extended Leather Opal White | CCB | M Performance Exhaust Mode Carbon GTS Front Spoiler | Mode Carbon Trophy Rear Diffuser | Mode Carbon M4 Spoiler |
04-17-2010, 02:35 PM | #2 |
Rep 475
would of thoughts they do as the EDC is just oem adjustable damper and not the spring .
I installed the Eibach lower springs on my E60 M5 with edc without any probs if that any help to you |
04-18-2010, 06:45 AM | #4 |
BMW Motorsport
237
Rep 2,225
Drives: BMW ///M4 F82 / BMW ///M5 F10
Im going to lower with the edition springs.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White |
04-18-2010, 01:20 PM | #6 | |
76
Rep 1,179
04-18-2010, 03:04 PM | #7 | |
12
Rep 111
I can assure you the handling is just fine running eibachs, they lower the car around the same as the BMW performance springs do so are you saying that BMW have buggered up the handling as well? I have read the thread you are referring to as well and still stick by the fact the eibachs are fine. TBH the above is a pretty silly comment IMO. Last edited by chrisburns; 04-18-2010 at 03:11 PM.. |
04-19-2010, 02:09 PM | #9 | |
Rep 475
04-19-2010, 02:11 PM | #10 |
60
Rep 638
04-19-2010, 02:13 PM | #11 |
230
Rep 3,899
Correct about the M3 Edition springs being 10mm lower than standard but the EDC on Edition cars has also been updated to suit. Dont know the effects of running these springs on non Edition EDC.
04-19-2010, 04:14 PM | #12 |
226
Rep 918
Thanks guys...If i lower it will be eibach....but i still dont know if for the e93 its only one type available for both EDC and non EDC?
04-19-2010, 04:28 PM | #13 | |
230
Rep 3,899
The Eibach springs listed at the bottom of this link are stated for the E93 M3 incl EDC! http://www.**********s.com/product.a...ach_E90_E92_MW |
04-19-2010, 04:36 PM | #15 |
BimmerPost Supporting Vendor
8312
Rep 18,880
Drives: BMW
Both Eibach and RD Sport springs are perfectly fine for EDC-equipped M3s.
04-20-2010, 03:48 PM | #16 | |
76
Rep 1,179
The purpose of the springs is to hold the car up at the required ride height, allow sufficient movement above and below this point, resisting excessive body roll and allow the wheels to follow the road surface. Spring travel is thus a very important part and the if there is not enough travel, the spring bottoms out. Effectively that corner of the car ceases to have suspension. If this happened when cornering or braking hard it could be very dangerous. The M3 front suspension has 0.5" of travel before hitting the bump stop. The bump stop has been dyno'd and acts progressively over the first 1" of compression. It's resistance then shoots up at which point it is not acting like a spring. The front M3 springs are rated at 160lbs, meaning it takes 160lbs of force to compress the spring by one inch. With two adults in the car you are already eating into the available spring travel. So with the Eibachs you are already riding on the bump stops, yes the springs are stiffer by ~22% but only at the maximum compression (as they are progressive) and this will potentially create a worse handling car. Below are the threads to read http://www.m3post.com/forums/showthread.php?t=370301 http://www.m3post.com/forums/showthread.php?t=360300 http://www.m3post.com/forums/showthread.php?t=343880 |
01-23-2013, 05:45 AM | #17 |
115
Rep 1,326
I want to lower for looks but can't help but think that I will ruin the comfort and forcing the dampers to work harder than they need to and that surely BMW knows what they doing after all the time they took in researching.
01-23-2013, 06:29 AM | #18 | |
*_*
812
Rep 3,160
Also, keep in mind the car's dynamics change slightly with springs that inherently "rake" the car forward to compensate for the front fender gap. This could be avoided with a sleeve kit from KW or GC. |
01-23-2013, 12:11 PM | #19 |
115
Rep 1,326
I've been trolling through many threads / forums on the Competition pack and some say it's 10mm lower springs, and some say its' the same spring and confirmed by the dealer that they are the same springs? and only the mounts or some other parts that lower it?
Also is it possible to code it the new EDC functions with the '07 cars? Ie. is it possible to install the springs / or whatever part that has to lower the car and not mess up the shocks? |
02-02-2013, 05:22 PM | #22 |
Rep 475
No I have the spring sitting in garage , as my car is still relatively new (only 13k miles on the clock ), I am waiting till when i need to change , then have them fitted along with the E36 bumpstop.
that is what most members do when fitting ebach spring as the suspension travel will be minimise by the lower springs ps ...spring do not effect the EDC, so no need to code the car |
