04-15-2010, 08:35 AM | #1 |
satch
39
Rep 1,040
What would you do...
If you woke up today and realized that you had a tuned 135i with sways and strut brace but were still driving around on stock wheels and runflats and stock suspension - what would you do FIRST (income tax refund restricted)
1) Buy new lighter wheels and non runflat tires 2) Buy a set of coilovers ?
"The Dingo ate your Mustang" |
04-15-2010, 09:35 AM | #3 |
18
Rep 293
Drives: '21 M2C 6MT, '21 Charger Scat
Def option #1, but....
you could splurge a bit and do tires only (non-rtf) on stock wheels, I suggest hankook v12. AND some new coilovers so that would only be about ~$500 more than just coilovers. Probably the best bang for your buck. GL |
04-15-2010, 09:40 AM | #5 |
85
Rep 1,609
I thought coil over will give you much improvement in handling than tires alone.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
04-15-2010, 09:58 AM | #6 | |
18
Rep 293
you will really see how bad the suspension is when you change the RTF, but if you just change the suspension first you won't see as big of an increase in grip (you will see a difference in the ride). |
04-15-2010, 12:08 PM | #7 | |
satch
39
Rep 1,040
Then the coilovers could really come in to play.... KW2... I just wish there was still the deal on them at $1450 for Variant 2 I believe that's what it was instead of the $1800Plus...
04-15-2010, 06:18 PM | #8 |
122
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
If you eventually plan to do both then I'd just look for deals and figure in other options. You probably won't find many deals on coilovers and a used set can be questionable. However you'll find some "wheel whores" just trading out to something else. Also you may want to use up your stock tires if you can't sell them for much anyways.
So basically I'd do coilovers if I had some spare money and then just keep my eyes out for a good trade or barely used wheel option. Plus the stock wheels look pretty good and fit better than most aftermarket options.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
04-17-2010, 08:12 AM | #9 | |
satch
39
Rep 1,040
Gill at Tire Rack did such a fantastic job putting together a great deal and worked around the delayed availability of the 8.5 Breyton's that I just had to do it. So Breyton Race GTS-R with Red Stripe, Hankook Ventus V12 evo K110 XL, new set TPMS & valves, rebates, mounting - the works. Unfortunately now I also see that Turner has a real steal of a price on Bilstein PSS10's.... So there are coilover deals out there... unfortunately for my budget...
