New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      04-11-2010, 06:21 PM   #1
ramiles
Drives: Z4 2010
Z4 Radar Detector Hard Wire Install
Today I installed a Beltronics GPS Radar Detector with the hard wire kit and wired it into the map light area. Picture below show install. Hopefully avoid the ticket I got several months ago. Got wiring info from a thread on the 3 serices forum. Cheers
Ross
      04-11-2010, 06:57 PM   #2
teagueAMX
teagueAMX's Avatar
62
Drives: Some are road worthy
Excellent!
      04-11-2010, 07:28 PM   #3
Vintage
Vintage's Avatar
381
Drives: BMW G80 (MT), 718 Spyder
some of you are so darn handy - I wish I could say the same
      04-11-2010, 10:07 PM   #4
teagueAMX
teagueAMX's Avatar
62
Does it block the passenger side sun visor?
      04-11-2010, 10:53 PM   #5
mikeinaustin
42
Drives: 2010 z4 3.0 crimson red
clean
      04-12-2010, 09:45 AM   #6
ramiles
Drives: Z4 2010
About blocking the visor movement - you can fit it so that the visor isn't restricted but it has to be set right. Also, I ordered a visor clip but think it is tucked out of way better where it is. Really want it to be unobtrusive - too bad they don't offer an ibus type interface like some folks did a while back with the Valentine1 to the older BMWs.
      12-20-2010, 04:02 PM   #7
cubby61
cubby61's Avatar
Drives: 2011 Z4 sDrive30i
I followed ramiles directions and everything went smoothly. Well except when I unplugged the connector which initiated the call to BMW Assist because it thought there was an airbag problem. Other than that it took all of 20 minutes to do and was very easy.
      12-20-2010, 08:56 PM   #8
Land_Shark
In The Flesh
Hong Kong
23
Drives: Z4 sDrive 35i
Ramiles. Why you went with this option/setup rather than a simple plug & play Valentine 1 Radar Detector?
Would Beltronics detect optical speed cameras?
      12-20-2010, 10:11 PM   #9
Drjoeb
Drjoeb's Avatar
Drives: 2011 M3
I use a escort 9500ix detector. Great detector, paid for itself a few times over already you can get the hardwire cable and route it under the dash and tap into the 12v in the passenger side. Pretty easy and you don't have to be a super handy man. You should be able to do this for any dector that has hardwire cable like the V1.
      12-20-2010, 10:36 PM   #10
ramiles
Drives: Z4 2010
I went with this radar unit because, yes, it had GPS and alterted to stop light cameras. However - after installing haven't worried about updating the data base - there are still only a few cameras in my area. The focus of starting this forum thread was to show the hard wiring stuff - use whatever unit you like - hopefully this will help with your wiring.
      12-21-2010, 01:05 AM   #11
Land_Shark
In The Flesh
Hong Kong
23
Thanks Ramiles... I think I misunderstood your photos... I thought the adapter like thing you showed in photo#1 came with your Radar detector... My mistake...
      09-09-2011, 08:30 AM   #12
ZheHbKa
ZheHbKa's Avatar
78
Drives: the Wind
2014 BMW 335 Xi  [10.00]
nice install! helpful!
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      09-18-2011, 01:26 PM   #13
shashi27
Drives: 11 Z4 35is
Was able to hook mine up but could not find a swtiched source, only 12V. Used the 12V but will need to turn it off at the radar switch.
      09-18-2011, 08:28 PM   #14
bmwmick
bmwmick's Avatar
18
Drives: '97 Z3,'11 Z4 35i,'90 C4 Vette
Find the green/white wire on the right side connector. It's the only good switched source I found .
Mick
2011 35i 6-speed, ///M Sport, Deep Sea Blue, Black leather, Carbon trim, Cold Weather package, Premium package, 6CD changer. Delivered 7/15/11. Michelin Pilot SuperSport tires 10/24/12
Tucson,AZ/Santa Paula,CA
      09-18-2011, 11:06 PM   #15
STOOF
Sunburned
STOOF's Avatar
238
Drives: '16 F83 M4 Convertible 6MT
2013 BMW 535i  [0.00]
oh nice, ive been meaning to install my hardwire kit, i already tapped a fuse on the fuse box but its def easier to tap into the wire right there.
Thanks!
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired
2011 Z4 SDrive35i 6MT- Retired
      09-19-2011, 09:39 PM   #16
shashi27
Drives: 11 Z4 35is
I dont have the green white wire. I checked three times. I tried to hook one up that seemed like switch power and it tripped the restraint warning which wouldn't allow the car to start. I had a black and green wire. Maybe we have a different optioned car and harness. I'll take a pick on sat.
      09-20-2011, 02:21 AM   #17
persian54
persian54's Avatar
923
Drives: M760/G83M4
send pics...
I've hardwired several BMWs and they have all had the green white wire
      09-23-2011, 10:15 PM   #18
SANguru
57
Drives: i8, X5 50,M550i,Tesla, MP4-12c
Originally Posted by persian54 View Post
send pics...
no green and white wire on my 35is either.
      09-23-2011, 10:23 PM   #19
ramiles
Drives: Z4 2010
When I did the original hard wire install (I'm the original poster) I did not have any schematics - just probed the wires until I could find one that was hot (powered) at the right time (ignition on). For both my Zippster and my wifes's 335 that appropriate power line was the green/white line. Maybe the wires are different for different models or configurations. Recommend you check out the voltages and use the one that works best.
      09-24-2011, 12:41 AM   #20
SANguru
57
which wire did you end up using? thanks!
      09-24-2011, 02:42 AM   #21
persian54
persian54's Avatar
923
Drives: M760/G83M4
strange the IS doesn't have it
      09-24-2011, 12:07 PM   #22
shashi27
Drives: 11 Z4 35is
Hi, The thick red one in the right (black connector) which I think feeds the main light. Thanks.
zpost
