      03-24-2010, 12:26 PM   #1
flyingfortress
111
Drives: 2010 135i
stock wheels, spacers... what new tires?
ok, i tried searching for specifics, but i couldn't find anything really.
i am running the stock 264 wheels. i purchased 10mm & 12mm spacers.
i want to replace the runflats with new tires.
i am looking at either Nitto NT555, Hankook v12 or Sumitomo HTRZ III (probably these). all most likely if they fit 225/40/18 and 255/35/18
will this fit with the stock suspension set up? which tire would work better? what tire do you prefer? any suggestions? i only need a decent performing summer tire to last me about 20k miles. i have dedicated winters.
thanks for the help!
      03-25-2010, 08:33 AM   #2
flyingfortress
111
Drives: 2010 135i
no one?
      03-25-2010, 09:15 AM   #3
tgxmike
tgxmike's Avatar
18
Drives: '21 M2C 6MT, '21 Charger Scat
2021 BMW M2  [0.00]
according to the FAQ page those tires should fit without modification. You may have to ditch the spacers. (in which case let me know.... I'm looking for spacers).
I run Hankook on my 128i in a 205/50/17 (stock size for now) and they are pretty awesome.
I use to be able to break the back end of my car loose pretty much when ever I wanted with the RTF, not so any more. The tires really do preform well, even if it is really cold outside (30F this morning).
      03-25-2010, 12:22 PM   #4
SlickShift
SlickShift's Avatar
No_Country
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
I'm running the stock wheels with 225/40 Hankook v12's up front with a 12mm spacer. I'm lowered on Eibach springs and rub a little on extreme dips. I would recommend a 10mm spacer if you're lowered and don't want to rub. I still have 245/35 out back w/o spacers, so no problems there.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      03-25-2010, 01:30 PM   #5
flyingfortress
111
Drives: 2010 135i
stock suspension... you think i can get away with 225/40 and 255/35 with 12mm up front and 10mm in the back?
      03-25-2010, 01:32 PM   #6
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
what are you guys running the spacers for? trying to get flush?
      03-25-2010, 01:33 PM   #7
flyingfortress
111
Drives: 2010 135i
yeah
      03-26-2010, 11:11 AM   #8
SlickShift
SlickShift's Avatar
No_Country
323
Probably...I'm only rubbing because I have zero fender gap. I think it also depends a lot on the tire sidewall; the Hankooks have a very square sidewall which doesn't do well for "tucking" in to the fender.
To play it safe I'd get a 10mm front spacer and 8mm rear with the tire setup you listed.
-Nick
1addicts
