BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
View Poll Results: What size - please read thread before choosing!
275/35/18 F and 295/35/18 R 2 40.00%
265/35/18 F and 295/35/18 R 1 20.00%
265/35/18 F and 275/40/18 R 0 0%
265/35/18 F and 285/35/18 R 2 40.00%
Voters: 5. You may not vote on this poll
      03-24-2010, 04:45 AM   #1
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
Drives: E92 M3 LSB/Black 6MT
2011 BMW M3  [9.34]
really need some help - I'm probably the most undecisive person ever!!
OK. I have decided to go with 9.5'' F and 10'' R wheels (custom offsets to be determined) given the fact that they are versatile sizes and, worst comes to worst, I can fit a decent selection of rubber on to them. I need help though figuring out what to go with. I have heard a great deal about the new Vredestein Ultrac Sessantas and they are so much cheaper than other tires for me (I live in Canada), so I wanted to get rims to primarily fit those tire sizes, as well as others just in case I decide to hate these.
Just some info
- 18''
- The car will be tracked (not heavily, but at least 4-5x in the summer)
- The rims/tires are also to be used on the street during the summer
- The car will NOT be lowered (that's what they all say!) mostly due to the fact that I do not want to screw with handling, I live in a city where roads are useless, and because I don't want to risk chances of rubbing.
I wanted some help on what you all think may be the best tire setup. I would REALLY like to try and keep the balance of the stock +20 setup, but still want to have wider rubber. I want try and keep speedometer readings proper (ish...) - remember, it's mostly a street car, and I also don't want the tire to look weird in the wheel well. I would also like to know if going from a +20 setup to +10 or +30 will have a noticeable effect, or would adversely affect the balance of handling.
So my choices are the following:
- 275/35/18 F and 295/35/18 R
-----slight chance of front rub
-----keeps the +20
-----close to stock sidewall height
-----vredestein = low $$
- 265/35/18 F and 295/35/18 R
-----no rub
-----+30 now
-----front a little shorter so may look weirder
- 265/35/18 F and 275/40/18 R
-----no rub
-----+10 now
-----front a little shorter and back NICE AND FAT (will screw up the speedometer by >1%)
-----no vredestein unless I mismatch the F/R which I believe is not recommended? = more $$
- 265/35/18 F and 285/35/18 R
-----no rub
-----keeps the +20
-----both a little shorter and will screw up the speedometer by >1%
-----noo vredestein unless I mismatch = more $$
Guys, honestly...ANY opinion would help. I appreciate it
Best,
G
P.S. This is for an E92 M3, not the 335i in my sig
      03-24-2010, 05:29 AM   #2
Tonybest
Enrollment Officer
Tonybest's Avatar
114
Drives: 997.2 Porsche C4S
don't use different brands of tires.
I would not go the +30 route.
      03-24-2010, 06:34 AM   #3
MrHarris
yodog
MrHarris's Avatar
197
Drives: '86 Corolla
2009 BMW  [10.00]
I would definitely go the +30 route.
The new GTS confirms this can be a great setup.
The car IMO has too much oversteer stock, and +30 is perfect IMO.
I ran 255/285 and it felt great. Much better than 245/265. I can only imagine 265/295.
The question is, can you live with such a small looking tire up front? (only looks right to me if slammed on coils)
If it were me I'd go 275/295.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      03-24-2010, 09:55 AM   #4
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
i'd go 265/285... keeps the balance of the original set up and shouldnt rub with the ride offset.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      03-24-2010, 09:28 PM   #5
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
2011 BMW M3  [9.34]
this my help in the opinion gathering:
FRONT
- 245/40/18 (stock) diameter - 25.71 in/653.03 mm
- 265/35/18 diameter - 25.30 in/642.62 mm
- 275/35/18 diameter - 25.57 in/649.47 mm
REAR
- 265/40/18 (stock) diameter - 26.34 in/669.03 mm
- 275/40/18 diameter - 26.66 in/677.16 mm
- 285/35/18 diameter - 25.85 in/656.59 mm (I honestly think this would look really weird)
- 295/35/18 diameter - 26.12 in/663.44 mm
      03-26-2010, 12:52 AM   #6
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
2011 BMW M3  [9.34]
bump!
m3post
