03-23-2010, 07:13 PM | #1 |
Rep 84
Sway bars: OEM 135 VS BMW Performance
ok, I just want to know if the optionnal BMW Performance sway bar is bigger or smaller than the OEM.
Each other are black painted... When I look at my car the supposed BMW Performance sway bar look smaller than my OEM one in my hand...
No more 135i..
03-25-2010, 07:15 AM | #4 |
103
Rep 677
m3 convertable bar is 28mm, coupe and sedan m3 of 26.5mm, obviously the vert bar is the way to go.
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
03-26-2010, 09:13 AM | #6 |
40
Rep 400
do sway bars even come w/ the BMW performance suspension? Hasn't been much talk about that on here.
Black Sapphire Metallic 135i/Coral Leather Interior/ Gloss Black Grills/20% tint/M door sills/Black 135i badge, smoked LED side marker, Dinan stage II , DINAN Exhaust, performance side skirts, performance shift boot/e-brake, pedals, carbon fiber wrapped interior
03-30-2010, 01:14 AM | #10 |
701
Rep 3,268
Drives: 2010 128i
BMW Performance Suspension bars are 26.5 mm in front and 12 mm in back:
http://www.bmwusa.com/Standard/Conte...ensionKit.aspx
____________________________ |
03-30-2010, 02:37 AM | #11 | |
435
Rep 3,888
03-30-2010, 03:01 PM | #13 |
240
Rep 462
I think your reply can be found a few posts down in this same forum:
http://www.1addicts.com/forums/showthread.php?t=310496 It appears that the OEM front say bar for the 135i is also 26.5 mm, but with a 19 mm kink in it which would obviously reduce the rigidity. So same size as the Performance sway bar, but not as stiff. |
03-31-2010, 09:07 AM | #14 |
103
Rep 677
if you want it even stiffer you'll get the vert bar, its common sense..
03-31-2010, 11:00 AM | #15 |
240
Rep 462
Yeah, I was originally thinking of getting the BMW PS, but perhaps just getting the E93 M3 front swaybar might do the trick.... I'll get a better feel for the adequacy of the factory suspension once I take delivery in a month...
