03-06-2010, 06:50 PM | #1 |
23
Rep 148
Front Section / X-Pipe Exhaust Diameters
I have been trying to find some information on the Aftermarket vs. Stock exhaust system diameters. Needless to say I have not had much luck, mainly on the X-pipe / Front section. Some manufacturers list the rear sections specs and seem to range from 2.5"-3.0".
Any info on the front sections would be appreciated. Also I know some resonators neck down inside. If you noticed this please include. |
03-06-2010, 07:17 PM | #2 |
yodog
197
Rep 5,025
Should be 2.5" going to 3" will lose major torque.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
03-06-2010, 07:37 PM | #3 |
Automotive Industry Insider
462
Rep 1,948
QUOTED FOR TRUTH You'd be surprised how many people don't understand this basic principle. I see some brands that use 3" exhaust piping for the x-pipe section. An exhaust pipe diameter that size (on our car), will lose a lot of low to midrage torque. Yes, it reduces the back pressure restriction, but unfortunately it also KILLS the velocity of the exhaust gas flow. 2.75" is about the max for exhaust pipe diameter on the S65 engine. Anything larger than that will kill your exhaust gas flow...and your low end torque will drop off a cliff.
The best is yet to come...
03-07-2010, 08:42 PM | #4 |
23
Rep 148
I was wondering if 2.75 was currently used.
Is the loss of toque with larger pipe due to a mismatch between ECU Calibration and part. Obviously most manufactures make products that match the factory calibration (AKA Stock Vehicle) and not for max power after a proper tune. Have manufactures and tuners tried to tune with a larger system that could prove this? With only flashes available engine performance would seemingly be limited. Last edited by masitr; 03-09-2010 at 05:49 PM.. |
03-09-2010, 06:07 PM | #6 |
Rep 148
I believe AA exhaust is 3" all the way through.... and it doesn´t seem to loose torque...
03-09-2010, 10:56 PM | #7 |
894
Rep 9,034
That's what the AA is known for... loss of low end torque.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-10-2010, 12:27 AM | #8 |
yodog
197
Rep 5,025
Just from watching that S3 dinan video, seems the Dinan is 2.75" all the way.
03-14-2010, 04:40 AM | #11 |
64
Rep 1,498
On the N/A motor, too large of a dia. pipe will reduce backpressure, but in doiing so will also reduce exhaust gas velocity, which is what is important to making power in a N/A motor. This is why there are X-pipes, to create a scavenging affect. The scavenging effects creates a negative pressure at the crossing of the Xpipe which sucks the exhaust gas and increases exhaust velocity, making more power and torque.
In contrast, on a FI motor, The larger the pipe, the better, and the least backpressure is whats important.
E92 328i Jet Black / Gloss Black Grilles / 8000k D1S low beam / 6000k HID fogs / GP Thunder 8500k angels & cornering bulbs / black reflectors / gloss black vinyled window trim / tints / smoked rear turn signals / black roundels / AC Schnitzer roof spoiler / VRS style decklid spoiler / Matte black Stripes / Rear fogs / matte mirrors / 19" LM reps / APR lip |
