BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      03-01-2010, 12:05 AM   #1
biglare
Bulldog
biglare's Avatar
482
Drives: BMW & Porsche
Talking Brilliant White 60-130 runs..... New Low!
I was able to get in some VBOX 60-130 runs this weekend before the rain hit Phx. The same setup was used as in my previous runs, but the temps were a little cooler. Also, check out the .75% up slope!
Setup
  • ESS Tuning VT2-575 S/C Kit
  • ESS Tuning Stage 2 DCT Software
  • DINAN Racing Mid-Pipe
  • DINAN Exhaust
  • DINAN 3.62 Diff
  • 20" Wheels
  • PS2 Tires
  • 295/25 Rear Tires
  • 91 Octane
  • Outside Temp 66 Degrees
  • .75% Up Slope
  • DCT Mode S6 used
The ESS DCT Stage 2 software is still delivering the power flawlessly and the gear shifts are lightening quick.
I am still on 20" "show" wheels, so I am toying around the idea of some 19" to have some fun and maybe go lower!
Best 60-130 time
  • 8.31
I am excited to get some more runs in and with more practice and 19's who knows!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      03-01-2010, 12:14 AM   #2
DLSJ5
DLSJ5's Avatar
504
Drives: 2016 F82 M4 ZCP
Awesome job Larry!
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP
ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ
ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ
Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH
      03-01-2010, 12:16 AM   #3
mixja
51
Drives: 2011 E90 DCT Silverstone
Gees you've got a 3.62 Diff - you must have crazy traction issues in 1st gear!
      03-01-2010, 12:20 AM   #4
Bluechipper
16
Drives: 09 M3 Vert
Don't look for 19's, get some light weight 18's and sticky rubber.
Those 20's have got to hurt your numbers.
      03-01-2010, 12:23 AM   #5
DLSJ5
DLSJ5's Avatar
504
Agreed, that elevation is not helping either.
      03-01-2010, 12:24 AM   #6
m33
m33's Avatar
115
Drives: E92 VT650 MCB Individual
Damn , your posts are the most amazing ones on this board you just keep comming out with record breaking times man .......
Put a superman logo's on your doors
Very impressive indeed but arent 20"s best as for rotating mass at those speeds rather than a smaller setup ( which in return is ideal for 1/4 mile runs )?
      03-01-2010, 12:32 AM   #7
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
what do you guys think the times will be if the diff was stock?
anyone with an ESS kit can put up some times?
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      03-01-2010, 12:33 AM   #8
TheKosherStogie
TheKosherStogie's Avatar
342
Drives: 08 M3 DCT AW/Red
nice... 8.31 is fast...getting closer to 7's
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2
ACS - 1:49:6
WSIR - 1:30:6
      03-01-2010, 12:37 AM   #9
Eugene-TAIWAN
Taiwan
249
Wow so the diff. Does help out a lot
But that is some interesting information to know
      03-01-2010, 12:51 AM   #10
TheKosherStogie
342
Originally Posted by PencilGeek View Post
I think this might help answer Sammy's question about which gear is best to launch 60-130. For 3.15 it appears 2nd gear is best; for 3.62 it appears that 3rd gear is best.
Attachment 353759
thanks robert, but it wasnt really a question for me...there is no doubt 2nd gear is much better to start in for me, its just my tires are so gone that i get better times in 3rd, cause in 2nd way too much tire spin
BW C13 - 1:57:2
ACS - 1:49:6
WSIR - 1:30:6
      03-01-2010, 08:30 AM   #11
biglare
Bulldog
biglare's Avatar
482
Originally Posted by DLSJ5 View Post
Awesome job Larry!
Thanks!
Yes, 1st gear is not even an option at full throttle on street tires. I would just shred them all day long. It takes some practice to feather the throttle to maximize power with grip.
The 20's are definitely hurting my cause here. My single rear wheel with the 295 tire weighs in at 50 pounds. Definitely hurting my numbers here.
I will look for some 19's, but I don't think that 18's will clear the BBK. If someone knows of a set of 18's I would try them out. I have a line on some 19's that are lightweight though.
Yes, the elevation doesn't help either.
Thanks!
No, the 20's just have so much more mass to get moving. Plus my 20's are pretty heavy.
Thanks Sammmy!
Even with these dings against you, you still have a great time.
  1. 20" (heavy) wheels
  2. Street tires
  3. 1600 ft elevation
Here's a graph that shows Larry's exact dyno graph in CarTest and shows the effects of 3.15 vs. 3.62 differential. I think this might help answer Sammy's question about which gear is best to launch 60-130. For 3.15 it appears 2nd gear is best; for 3.62 it appears that 3rd gear is best. Also of interest is the 1/4 mile prediction. Look how 3.62 gets better ET, but loses trap speed. But to be honest, with only 0.06 seconds difference, it's practically negligable on ET.
Larry, which gear did you launch from: 2nd or 3rd? If 2nd, maybe next time you go out, try 3rd and you should get an even better time.
Column-1: Larry+3.15
Column-2: Larry+3.62
Attachment 353759
Robert, thanks for the analysis.
I am not positive on this run, but I believe that I started from 3rd. My diff keeps the first two gears so short that when it second I have to shift so quickly that third ends up working better in my case. I'll have to really monitor this when I do more runs.
Yeah, tire spin is an issue for all the S/C cars. With better rubber on we should have some better times. I can't wait to get out there again.
Nice job Sammy lowering your time. Keep going out and lets drive all the E9x M3 times down!
GTS
      03-01-2010, 10:57 AM   #12
KiokenM3
KiokenM3's Avatar
84
Drives: LIFTED JEEP JK!
ya i would think that with his 3.62 diff, if larry went with a smaller wheel/tire setup it would hurt his topend since he would again be lowering his FD from his 20" setup. the 3.62 would be great for low end but sacrifice top end on stock tire set up
      03-01-2010, 12:57 PM   #13
LV-E92M3
LV-E92M3's Avatar
Afghanistan
20
Drives: Donkey
wow...that's fast! I think you'll get better time once you get light weight 19inch rims
      03-01-2010, 02:38 PM   #14
ONE92
ONE92's Avatar
Drives: E92 M3 DCT
Great Time!
Wow, that is very exciting that it just keeps getting better with practice; I would like to see what you do with 19". I am getting a ESS very soon, If nobody posts up some California times by than, I will be taking a trip to San Diego, it would be great to have some company. I think it would benefit everyone to see what it puts down at sea level.
Tags
60-130, brilliant white e90 m3, ess
m3post
