01-20-2010, 08:37 PM | #1 |
ADMIRAL
Rep 33
I Hear Water Sloshing
This is the hardest rain we have had here in Los Angeles that I can remember. When I step on the brake I can hear water sloshing around. I checked the doors, nothing. I checked the roof and where the roof stores but I can not see any water. Trunk is dry. Limber holes are clean. Where else should I look?
01-21-2010, 01:16 PM | #3 |
Rep 145
I have this problem before too.
The problem is in the side skirt... Look under each side of your car and you will see two plastic piece for the jack... Push it or Pull it toward you... you should see water dripping out. The water somehow gets trapped in that area... |
01-24-2010, 10:59 AM | #4 |
ADMIRAL
Rep 33
You were 100% correct!! I could not get all the water out by moving the jack points around, so I took it to my local shop. they took the plastic rocker panel off. We could then see where the water was accummulating. We drilled a hole in the jack point pads. Hopefully this mod will allow the water to get out next time. I would like to know how the water gets in though.
03-29-2010, 08:52 PM | #5 |
Rep 62
leak
I've noticed water sloshing, too! Just noticed over the last year following a heavy rain.. Just had a heavy rain last night and we lack a garage, so the car's are exposed to the elements 24/7.. I'm going to bring our z ('03 2.5i) to the dealer and point out this rocker panel mentioned here. Thanks for the heads-up!
Lisa
03-29-2010, 08:54 PM | #6 | |
Rep 62
drain holes
Lisa
03-30-2010, 08:08 PM | #8 |
Rep 62
Bingo! For me it was the rocker panels! Thanks XG3! I took the car to the dealer, had the tech drive it around the lot with me and did some stop/starts and sharp turns and he heard the water. He drove it inside and removed the jack pad from the right side rocker panel and water gushed out! A little more poured from the left side. I was thrilled! He told me that the top absorbs water as it's raining. The water collects in drainage collection areas at the base then is channeled into the rocker panels then drains out. As this car doesn't have the benefit of a garage or even a carport, it's exposed to the elements, including debris from the trees in our yard. Will be shopping for a carport very shortly, and will also look at all areas where debris collects to prevent future cloggage.. (if that's a word..) I also enjoyed the fact that my car actually "peed"!
12-16-2010, 09:51 AM | #9 |
Rep 2
glad I went online and found this forum/thread. I've got a 2003 Z4 and just a few days ago started hearing the water sloshing beneath drivers side door. I'll check the jacking point plugs and hopefully drain water out there.
12-16-2010, 12:26 PM | #10 |
44
Rep 1,855
I assume this is only a problem with the roadsters? I haven't heard water, but am wondering if I will ever have to perform this little "mod."
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
12-16-2010, 01:31 PM | #11 |
Rep 2
I reached under, just slightly moved the jack points, and the gusher began. Surely there must be a clogged outlet somewhere in the base of the rocker panel. Need to get care on a lift for easier inspection though..... At least I don't hear that damn sloshing sound!
11-18-2015, 07:48 AM | #13 |
851
Rep 4,057
I am not familiar with that car but if it is designed in a similar way, then its possible.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
